Hi,
My IotaWatt has been working a treat for many months and I’ve been very happy with it. Unfortunately, something happened a week ago that has stopped it communicating with emoncms.org and I don’t seem to be able to resolve the problem. The message log is as follows:
6/5/18 18:39:10 Real Time Clock is running. Unix time: 1528223950
6/5/18 18:39:10 Version: 02_02_30
6/5/18 18:39:10 Reset reason: Software/System restart
6/5/18 18:39:10 Trace: 14,11,90,12,13,14,11,90,12,13,14,11,90,12,13,14,11,90,12,13,14,11,90,84,86,88,12,13,14,13,102,103
6/5/18 18:39:10 ESP8266 ChipID:2222318
6/5/18 18:39:10 device name: IotaWatt, version: 3
6/5/18 18:39:10 Local time zone: 0
6/5/18 18:39:15 checkUpdate: Invalid response from server.
6/5/18 18:39:15 MDNS responder started
6/5/18 18:39:15 You can now connect to xxx IotaWatt.local
6/5/18 18:39:15 HTTP server started
6/5/18 18:39:15 dataLog: service started.
6/5/18 18:39:16 dataLog: Last log entry:1528223945
6/5/18 18:39:16 statService: started.
6/5/18 18:39:16 timeSync: service started.
6/5/18 18:39:16 WiFi connected. SSID: XXXXXX, IP: X.X.X.X
6/5/18 18:39:18 checkUpdate: Invalid response from server.
6/5/18 18:39:19 historyLog: service started.
6/5/18 18:39:19 historyLog: Last log entry:1528223940
6/5/18 18:39:25 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 5, encrypted POST
6/5/18 18:39:28 EmonService: input/get failed.
6/5/18 18:40:03 EmonService: input/get failed.
6/5/18 18:40:38 EmonService: input/get failed.
6/5/18 18:41:13 EmonService: input/get failed.
6/5/18 18:41:48 EmonService: input/get failed.
6/5/18 18:42:23 EmonService: input/get failed.
6/5/18 18:42:58 EmonService: input/get failed.
6/5/18 18:43:33 EmonService: input/get failed.
6/5/18 18:44:08 EmonService: input/get failed.
6/5/18 18:44:43 EmonService: input/get failed.
The things I’ve tried to so far are:
- Hard reboot of the device
- Several soft reboots of the device
- Reboot of my router
- Removing the emoncms id and restarting
I can see the device appears to be successfully logging data, as the data logs appear to be updating. My post interval is 5 secs and I’ve got bulk send set at 10. I’ve double checked my api key is correct.
Is there anything else I can try?
Many thanks for your help,
Tim
