Getting Exceptions
My original IoTaWatt seems to be getting exceptions more frequently than I would expect.
1/02/19 17:28:56z Real Time Clock is running. Unix time 1546450136
1/02/19 17:28:56z Version 02_03_20
1/02/19 17:28:56z Updater: Installing update files for version 02_03_20
1/02/19 17:28:56z Updater: Installing GRAPH.HTM
1/02/19 17:28:56z Updater: Installing GRAPH.JS
1/02/19 17:28:57z Updater: Installing INDEX.HTM
1/02/19 17:28:58z Updater: Installing TABLES.TXT
1/02/19 17:28:59z Updater: Installing CNFSTYLE.CSS
1/02/19 17:28:59z Updater: Installing EDIT.HTM
1/02/19 17:29:00z Updater: Installation complete.
1/02/19 17:29:00z Reset reason: Software/System restart
1/02/19 17:29:00z Trace: 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5]
1/02/19 17:29:00z ESP8266 ChipID: 2222239
1/02/19 17:29:00z SPIFFS mounted.
1/02/19 09:29:01 Local time zone: -8:00
1/02/19 09:29:01 device name: IotaWatt
1/02/19 09:29:01 MDNS responder started for hostname IotaWatt
1/02/19 09:29:01 LLMNR responder started for hostname IotaWatt
1/02/19 09:29:01 HTTP server started
1/02/19 09:29:01 timeSync: service started.
1/02/19 09:29:01 statService: started.
1/02/19 09:29:01 Updater: service started. Auto-update class is MINOR
1/02/19 09:29:01 dataLog: service started.
1/02/19 09:29:01 dataLog: Last log entry 01/02/19 09:28:25
1/02/19 09:29:02 historyLog: service started.
1/02/19 09:29:02 historyLog: Last log entry 01/02/19 09:28:00
1/02/19 09:29:02 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=6, RSSI -61db
1/02/19 09:29:03 Updater: Auto-update is current for class MINOR.
1/05/19 10:21:42 WiFi disconnected.
1/05/19 10:21:45 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=1, RSSI -63db
1/06/19 10:06:19z Real Time Clock is running. Unix time 1546769179
1/06/19 10:06:19z Power failure detected.
1/06/19 10:06:19z Version 02_03_20
1/06/19 10:06:19z Reset reason: External System
1/06/19 10:06:19z ESP8266 ChipID: 2222239
1/06/19 10:06:19z SPIFFS mounted.
1/06/19 02:06:20 Local time zone: -8:00
1/06/19 02:06:20 device name: IotaWatt
1/06/19 02:06:23 MDNS responder started for hostname IotaWatt
1/06/19 02:06:23 LLMNR responder started for hostname IotaWatt
1/06/19 02:06:23 HTTP server started
1/06/19 02:06:23 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=1, RSSI -68db
1/06/19 02:06:23 timeSync: service started.
1/06/19 02:06:23 statService: started.
1/06/19 02:06:23 Updater: service started. Auto-update class is MINOR
1/06/19 02:06:23 dataLog: service started.
1/06/19 02:06:24 dataLog: Last log entry 01/06/19 02:06:15
1/06/19 02:06:24 historyLog: service started.
1/06/19 02:06:24 historyLog: Last log entry 01/06/19 02:06:00
1/06/19 02:06:25 Updater: Auto-update is current for class MINOR.
1/06/19 10:18:16z Real Time Clock is running. Unix time 1546769896
1/06/19 10:18:16z Power failure detected.
1/06/19 10:18:16z Version 02_03_20
1/06/19 10:18:16z Reset reason: External System
1/06/19 10:18:16z ESP8266 ChipID: 2222239
1/06/19 10:18:16z SPIFFS mounted.
1/06/19 02:18:17 Local time zone: -8:00
1/06/19 02:18:17 device name: IotaWatt
1/06/19 02:18:20 MDNS responder started for hostname IotaWatt
1/06/19 02:18:20 LLMNR responder started for hostname IotaWatt
1/06/19 02:18:20 HTTP server started
1/06/19 02:18:20 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=1, RSSI -68db
1/06/19 02:18:20 timeSync: service started.
1/06/19 02:18:26 statService: started.
1/06/19 02:18:26 Updater: service started. Auto-update class is MINOR
1/06/19 02:18:27 dataLog: service started.
1/06/19 02:18:27 dataLog: Last log entry 01/06/19 02:17:55
1/06/19 02:18:27 historyLog: service started.
1/06/19 02:18:27 historyLog: Last log entry 01/06/19 02:17:00
1/06/19 03:18:48 Updater: Invalid response from server. HTTPcode: -4
1/07/19 02:18:23 timeSync: No time update in last 24 hours.
1/07/19 07:20:29 Updater: Auto-update is current for class MINOR.
1/10/19 16:28:47 Updater: Invalid response from server. HTTPcode: -4
1/11/19 18:28:59 WiFi disconnected.
1/11/19 19:22:33 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=6, RSSI -66db
1/14/19 06:11:41 WiFi disconnected.
1/14/19 06:11:49 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -70db
1/14/19 08:10:44 WiFi disconnected.
1/14/19 08:10:52 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -72db
1/15/19 06:31:03 Updater: Invalid response from server. HTTPcode: -4
1/16/19 18:03:17 WiFi disconnected.
1/16/19 18:03:21 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -72db
1/20/19 04:30:06z Real Time Clock is running. Unix time 1547958606
1/20/19 04:30:06z Version 02_03_20
1/20/19 04:30:06z Reset reason: Hardware Watchdog
1/20/19 04:30:06z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3
1/20/19 04:30:06z ESP8266 ChipID: 2222239
1/20/19 04:30:06z SPIFFS mounted.
1/19/19 20:30:07 Local time zone: -8:00
1/19/19 20:30:07 device name: IotaWatt
1/19/19 20:30:07 MDNS responder started for hostname IotaWatt
1/19/19 20:30:07 LLMNR responder started for hostname IotaWatt
1/19/19 20:30:07 HTTP server started
1/19/19 20:30:07 timeSync: service started.
1/19/19 20:30:10 statService: started.
1/19/19 20:30:10 Updater: service started. Auto-update class is MINOR
1/19/19 20:30:10 dataLog: service started.
1/19/19 20:30:11 dataLog: Last log entry 01/19/19 20:29:55
1/19/19 20:30:11 historyLog: service started.
1/19/19 20:30:11 historyLog: Last log entry 01/19/19 20:29:00
1/19/19 20:30:11 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -69db
1/19/19 20:30:13 Updater: Auto-update is current for class MINOR.
1/22/19 07:03:00z Real Time Clock is running. Unix time 1548140580
1/22/19 07:03:00z Version 02_03_20
1/22/19 07:03:00z Reset reason: Exception
1/22/19 07:03:00z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:4
1/22/19 07:03:00z ESP8266 ChipID: 2222239
1/22/19 07:03:00z SPIFFS mounted.
1/21/19 23:03:01 Local time zone: -8:00
1/21/19 23:03:01 Using Daylight Saving Time (BST) when in effect.
1/21/19 23:03:01 device name: IotaWatt
1/21/19 23:03:01 MDNS responder started for hostname IotaWatt
1/21/19 23:03:01 LLMNR responder started for hostname IotaWatt
1/21/19 23:03:01 HTTP server started
1/21/19 23:03:01 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -69db
1/21/19 23:03:01 timeSync: service started.
1/21/19 23:03:04 statService: started.
1/21/19 23:03:04 Updater: service started. Auto-update class is MINOR
1/21/19 23:03:04 dataLog: service started.
1/21/19 23:03:05 dataLog: Last log entry 01/21/19 23:02:55
1/21/19 23:03:05 historyLog: service started.
1/21/19 23:03:05 historyLog: Last log entry 01/21/19 23:02:00
1/21/19 23:03:07 Updater: Auto-update is current for class MINOR.
1/22/19 07:03:18z Real Time Clock is running. Unix time 1548140598
1/22/19 07:03:18z Version 02_03_20
1/22/19 07:03:18z Reset reason: Exception
1/22/19 07:03:18z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:4
1/22/19 07:03:18z ESP8266 ChipID: 2222239
1/22/19 07:03:18z SPIFFS mounted.
1/21/19 23:03:19 Local time zone: -8:00
1/21/19 23:03:19 Using Daylight Saving Time (BST) when in effect.
1/21/19 23:03:19 device name: IotaWatt
1/21/19 23:03:19 MDNS responder started for hostname IotaWatt
1/21/19 23:03:19 LLMNR responder started for hostname IotaWatt
1/21/19 23:03:19 HTTP server started
1/21/19 23:03:19 timeSync: service started.
1/21/19 23:03:19 statService: started.
1/21/19 23:03:19 Updater: service started. Auto-update class is MINOR
1/21/19 23:03:19 dataLog: service started.
1/21/19 23:03:20 dataLog: Last log entry 01/21/19 23:03:15
1/21/19 23:03:20 historyLog: service started.
1/21/19 23:03:20 historyLog: Last log entry 01/21/19 23:03:00
1/21/19 23:03:20 WiFi connected. SSID=FrogmoreN66, IP=192.168.0.38, channel=5, RSSI -67db
1/21/19 23:03:22 Updater: Auto-update is current for class MINOR.
It is one room over from the Wi-Fi router. The Wi-Fi on it does go out every once in awhile, so maybe that is causing IoTaWatt to have an issue.
The trace says that’s happening in the web server handler for the vtphase command. I’d look further into it but you are on 02_03_20 that has the old handler. I installed a new handler in 02_03_21, now in ALPHA, so no sense fixing something that’s obsolete. The exceptions are pretty harmless as the reboot takes a couple of seconds.
Okay, I set up that one to get ALPHA. I was using vtphase for the two most recent restarts. The one before that was a hardware watchdog, but that does not appear to be frequent. I’ll keep an eye on it.
