So grid power, whether consumption or production, is what is going through you mains i.e. the sum of your three mains. As I understand it you want to break that down on whether it’s positive (consumption) or negative (production).
So the the mains total is: (Grid_3B + Grid_4C + Grid_5A)
To get only the positive values (grid consumption):
(Grid_3B + Grid_4C + Grid_5A) max 0
To get the negative values (grid production)
(Grid_3B + Grid_4C + Grid_5A) min 0
To prove this out, you can create a couple of outputs and look at them with the local graph.
@overeasy - That was super useful and what I was looking for.
I wasn’t aware of the ( sum your grid mains ) max / min 0
I am assuming I can do that with my aussie 3 phase as its reads as per above - negative when the solar is going back and positive when we are consuming.
