Yes, it was changed in my attempts to resolve the issue. Trying to see if alphabetic characters were a problem.
A bit of playing with direct urls reveals some inconsistency.
This
http://192.168.0.3/emoncms/input/post.json?node=IotaWatt&json={1:0}
creates a node called IotaWatt.
This
http://192.168.0.3/emoncms/input/bulk.json?data=[[0,60,1,2,3,4,5,6,7,8,9,10]]
creates a node called 60 with 10 entries.
This
http://192.168.0.3/emoncms/input/bulk.json?data=[[0,IotaWatt,1,2,3,4,5,6,7,8,9,10]]
generates an error message - Error: Format error, json string supplied is not valid
Having created Node 60 I tried changing the IotaWatt setup to use node 60 to see if it would use those, but it’s not looking good.
2/01/19 22:12:16z Real Time Clock is running. Unix time 1549059136
2/01/19 22:12:16z Reset reason: Software/System restart
2/01/19 22:12:16z Trace: 8:8, 8:9, 1:2, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 10:2, 10:3
2/01/19 22:12:16z ESP8266 ChipID: 2518145
2/01/19 22:12:16z IoTaWatt revision 4.8, firmware version 02_03_21
2/01/19 22:12:16z SPIFFS mounted.
2/01/19 22:12:17z Local time zone: +0:00
2/01/19 22:12:17z device name: IotaWatt
2/01/19 22:12:17z MDNS responder started for hostname IotaWatt
2/01/19 22:12:17z LLMNR responder started for hostname IotaWatt
2/01/19 22:12:17z HTTP server started
2/01/19 22:12:17z timeSync: service started.
2/01/19 22:12:18z statService: started.
2/01/19 22:12:18z Updater: service started. Auto-update class is ALPHA
2/01/19 22:12:18z dataLog: service started.
2/01/19 22:12:18z dataLog: Last log entry 02/01/19 22:12:15
2/01/19 22:12:18z historyLog: service started.
2/01/19 22:12:18z historyLog: Last log entry 02/01/19 22:12:00
2/01/19 22:12:18z WiFi connected. SSID=Whitwell-Unifi, IP=192.168.0.193, channel=11, RSSI -56db
2/01/19 22:12:20z Updater: Auto-update is current for class ALPHA.
2/01/19 22:12:22z EmonService: started. url=192.168.0.3:80/emoncms, node=60, interval=10
2/01/19 22:12:23z EmonService: Start posting at 02/01/19 22:12:30
2/01/19 22:17:20z EmonService: Invalid response, retrying.
