Here is the whole log. It has been a long time since I looked at it, as I was busy with other stuff. There is not a whole lot of interesting data, so if it got lost, it would not be that much of a loss. It does have some data on my well pump run times (which is what I was looking for when I noticed the issue). I didn’t include the first part of the log, because there was nothing that looked very interesting (other than the invalid response from server when checking for an update). There was a power outage at 6:49AM on April 7, 2018. Power came back within a min or so (backup generator). Internet was restored at 8:25AM on the same day (based on other sensors). This appears to the section of the log where the power went out and came back, but the timestamps seem somewhat confused (but it looks like this is the way it handles GMT vs local time, it might be good to make that clearer in the log). It looks like iotaWatt doesn’t automatically handle DST, which is why the clock jumped from GMT to GMT-8 instead of GMT-7. It also looks like it took 39 min from the time it started looking at the log till it found the last entry, which seems a bit excessive
No clock yet: SD initialized.
4/7/18 13:50:35 Real Time Clock is running. Unix time: 1523109035
4/7/18 13:50:35 Power failure detected.
4/7/18 13:50:35 Version: 02_02_30
4/7/18 13:50:35 Reset reason: External System
4/7/18 13:50:35 Trace: 803,19632,58597,37626,5579,22928,8523,19957,41425,59533,65505,23104,61099,15338,14985,14958,53691,9460,41050,60678,26864,42296,2659,42668,41614,51051,33051,10267,1134,22156,47736,59293
4/7/18 13:50:35 ESP8266 ChipID:2222239
4/7/18 05:50:35 device name: IotaWatt, version: 3
4/7/18 05:50:35 Local time zone: -8
4/7/18 05:50:43 checkUpdate: Invalid response from server.
4/7/18 05:50:43 MDNS responder started
4/7/18 05:50:43 You can now connect to http://IotaWatt.local
4/7/18 05:50:43 HTTP server started
4/7/18 05:50:44 dataLog: service started.
4/7/18 06:29:56 dataLog: Last log entry:3656990720
4/7/18 06:29:56 statService: started.
4/7/18 06:29:56 timeSync: service started.
4/7/18 06:29:56 WiFi connected. SSID: FrogmoreN66, IP: 192.168.0.38
2/5/18 08:09:25 device name: IotaWatt, version: 3
2/5/18 08:09:25 Local time zone: -8
2/5/18 08:09:26 MDNS responder started
2/5/18 08:09:26 You can now connect to http://IotaWatt.local
2/5/18 08:09:26 HTTP server started
2/5/18 08:09:26 dataLog: service started.
2/5/18 08:09:26 dataLog: Last log entry:1517846925
2/5/18 08:09:26 statService: started.
2/5/18 08:09:26 timeSync: service started.
2/5/18 08:09:26 WiFi connected. SSID: FrogmoreN66, IP: 192.168.0.38
2/5/18 08:09:27 historyLog: service started.
2/5/18 08:09:27 historyLog: Last log entry:1517846880
2/6/18 03:09:32 checkUpdate: Invalid response from server.
2/6/18 04:00:00 timeSync: adjusting RTC by -2
2/7/18 07:00:00 timeSync: adjusting RTC by -2
2/8/18 08:00:00 timeSync: adjusting RTC by -2
2/9/18 04:00:00 timeSync: adjusting RTC by -2
2/9/18 11:09:32 Updater: Update from 02_02_29 to 02_02_30
2/9/18 11:09:49 Updater: Update downloaded and signature verified
2/9/18 11:09:59 Updater: firmware upgraded to version 02_02_30
2/9/18 11:09:59 Firmware updated, restarting.
2/9/18 19:10:07 Real Time Clock is running. Unix time: 1518203407
2/9/18 19:10:07 Version: 02_02_30
2/9/18 19:10:07 Updater: Installing update files for version 02_02_30
2/9/18 19:10:07 Updater: Installing GRAPH.HTM
2/9/18 19:10:07 Updater: Installing GRAPH.JS
2/9/18 19:10:08 Updater: Installing INDEX.HTM
2/9/18 19:10:09 Updater: Installing TABLES.TXT
2/9/18 19:10:09 Updater: Installing CNFSTYLE.CSS
2/9/18 19:10:09 Updater: Installing EDIT.HTM
2/9/18 19:10:09 Updater: Installation complete.
2/9/18 19:10:10 Reset reason: Software/System restart
2/9/18 19:10:10 Trace: 14,13,14,13,14,13,14,13,14,13,14,13,14,13,14,13,14,13,14,13,14,13,14,11,90,84,86,88,12,13,14,15
2/9/18 19:10:10 ESP8266 ChipID:2222239
2/9/18 11:10:10 device name: IotaWatt, version: 3
2/9/18 11:10:10 Local time zone: -8
2/9/18 11:10:10 MDNS responder started
2/9/18 11:10:10 You can now connect to http://IotaWatt.local
2/9/18 11:10:10 HTTP server started
2/9/18 11:10:10 dataLog: service started.
2/9/18 11:10:11 dataLog: Last log entry:1518203370
2/9/18 11:10:11 statService: started.
2/9/18 11:10:11 timeSync: service started.
2/9/18 11:10:11 WiFi connected. SSID: FrogmoreN66, IP: 192.168.0.38
2/9/18 11:10:11 historyLog: service started.
2/9/18 11:10:12 historyLog: Last log entry:1518203340
2/10/18 08:00:00 timeSync: adjusting RTC by -2
2/11/18 09:00:00 timeSync: adjusting RTC by -2
2/12/18 08:00:00 timeSync: adjusting RTC by -2
2/13/18 11:00:00 timeSync: adjusting RTC by -2
2/14/18 11:00:00 timeSync: adjusting RTC by -2
2/15/18 10:00:00 timeSync: adjusting RTC by -2
2/16/18 12:00:00 timeSync: adjusting RTC by -2
2/17/18 12:00:00 timeSync: adjusting RTC by -2
2/18/18 17:00:00 timeSync: adjusting RTC by -2
2/19/18 00:10:18 checkUpdate: Invalid response from server.
2/19/18 16:00:00 timeSync: adjusting RTC by -2
2/20/18 17:00:00 timeSync: adjusting RTC by -2
2/21/18 09:10:25 checkUpdate: Invalid response from server.
2/21/18 15:00:00 timeSync: adjusting RTC by -2
2/22/18 17:00:00 timeSync: adjusting RTC by -2
2/23/18 14:00:00 timeSync: adjusting RTC by -2
2/24/18 16:00:00 timeSync: adjusting RTC by -2
2/25/18 17:00:00 timeSync: adjusting RTC by -2
2/26/18 10:10:31 checkUpdate: Invalid response from server.
2/26/18 10:34:45 WiFi disconnected.
2/26/18 10:35:26 WiFi connected. SSID: FrogmoreN66, IP: 192.168.0.38
2/26/18 17:00:00 timeSync: adjusting RTC by -2
2/27/18 12:00:00 timeSync: adjusting RTC by -2
2/28/18 19:00:00 timeSync: adjusting RTC by -2
3/1/18 07:10:37 checkUpdate: Invalid response from server.
3/1/18 14:00:00 timeSync: adjusting RTC by -2
3/2/18 14:00:00 timeSync: adjusting RTC by -2
3/3/18 12:00:00 timeSync: adjusting RTC by -2
3/3/18 17:10:43 checkUpdate: Invalid response from server.
3/4/18 10:10:49 checkUpdate: Invalid response from server.
3/4/18 17:00:00 timeSync: adjusting RTC by -2
3/4/18 18:10:54 checkUpdate: Invalid response from server.
3/5/18 14:00:00 timeSync: adjusting RTC by -2
3/6/18 08:00:08 Server: Sent less data than expected!
3/6/18 17:00:00 timeSync: adjusting RTC by -2
3/7/18 03:10:56 checkUpdate: Invalid response from server.
3/7/18 16:00:00 timeSync: adjusting RTC by -2
3/8/18 18:00:00 timeSync: adjusting RTC by -2
3/9/18 04:11:04 checkUpdate: Invalid response from server.
3/9/18 23:00:00 timeSync: adjusting RTC by -2
3/11/18 00:00:00 timeSync: adjusting RTC by -2
3/11/18 18:05:45 Server: Sent less data than expected!
3/11/18 18:34:00 Server: Sent less data than expected!
3/12/18 01:00:00 timeSync: adjusting RTC by -2
3/13/18 00:00:00 timeSync: adjusting RTC by -2
3/13/18 23:00:00 timeSync: adjusting RTC by -2
3/14/18 07:11:12 checkUpdate: Invalid response from server.
3/15/18 01:00:00 timeSync: adjusting RTC by -2
3/15/18 22:00:00 timeSync: adjusting RTC by -2
3/17/18 03:00:00 timeSync: adjusting RTC by -2
3/18/18 03:00:00 timeSync: adjusting RTC by -2
3/19/18 00:31:38 Server: Sent less data than expected!
3/19/18 09:00:00 timeSync: adjusting RTC by -2
3/20/18 08:00:00 timeSync: adjusting RTC by -2
3/21/18 05:00:00 timeSync: adjusting RTC by -2
3/22/18 06:00:00 timeSync: adjusting RTC by -2
3/23/18 07:00:00 timeSync: adjusting RTC by -2
3/24/18 12:00:00 timeSync: adjusting RTC by -2
3/25/18 10:00:00 timeSync: adjusting RTC by -2
3/26/18 10:00:00 timeSync: adjusting RTC by -2
3/26/18 19:11:25 checkUpdate: Invalid response from server.
3/27/18 02:11:27 checkUpdate: Invalid response from server.
3/27/18 12:00:00 timeSync: adjusting RTC by -2
3/28/18 00:11:32 checkUpdate: Invalid response from server.
3/28/18 09:00:00 timeSync: adjusting RTC by -2
3/29/18 10:11:37 checkUpdate: Invalid response from server.
3/29/18 11:00:00 timeSync: adjusting RTC by -2
3/29/18 22:33:28 Server: Sent less data than expected!
3/30/18 13:11:38 checkUpdate: Invalid response from server.
3/30/18 15:00:00 timeSync: adjusting RTC by -2
3/31/18 06:11:44 checkUpdate: Invalid response from server.
3/31/18 13:00:00 timeSync: adjusting RTC by -2
4/1/18 07:11:46 checkUpdate: Invalid response from server.
4/1/18 13:11:48 checkUpdate: Invalid response from server.
4/1/18 15:00:00 timeSync: adjusting RTC by -2
4/2/18 16:00:00 timeSync: adjusting RTC by -2
4/2/18 19:11:53 checkUpdate: Invalid response from server.
4/3/18 12:00:00 timeSync: adjusting RTC by -2
4/4/18 15:00:00 timeSync: adjusting RTC by -2
4/5/18 16:00:00 timeSync: adjusting RTC by -2
4/6/18 17:00:00 timeSync: adjusting RTC by -2
4/7/18 06:30:01 checkUpdate: Invalid response from server.
4/7/18 06:35:38 timeSync: Failed to get NTPtime.
4/7/18 07:05:42 timeSync: Failed to get NTPtime.
4/7/18 16:00:00 timeSync: adjusting RTC by -2
4/8/18 19:00:00 timeSync: adjusting RTC by -2
4/8/18 22:11:13 WiFi disconnected.
4/8/18 22:16:15 WiFi connected. SSID: FrogmoreN66, IP: 192.168.0.38
4/9/18 21:00:00 timeSync: adjusting RTC by -2
4/10/18 20:00:00 timeSync: adjusting RTC by -2
4/12/18 00:00:00 timeSync: adjusting RTC by -2
4/13/18 01:00:00 timeSync: adjusting RTC by -2
4/13/18 22:05:42 timeSync: Failed to get NTPtime.
4/14/18 00:02:08 timeSync: adjusting RTC by -2
4/14/18 09:05:43 timeSync: Failed to get NTPtime.
4/14/18 10:05:43 timeSync: Failed to get NTPtime.
4/14/18 11:05:42 timeSync: Failed to get NTPtime.
4/14/18 12:05:42 timeSync: Failed to get NTPtime.
4/14/18 13:05:42 timeSync: Failed to get NTPtime.
4/14/18 22:00:00 timeSync: adjusting RTC by -2
4/15/18 18:30:06 checkUpdate: Invalid response from server.
4/15/18 21:00:00 timeSync: adjusting RTC by -2
4/16/18 23:01:01 timeSync: adjusting RTC by -2
4/17/18 04:59:59 timeSync: adjusting RTC by -2
4/17/18 06:00:02 timeSync: adjusting RTC by 2
4/18/18 00:00:05 timeSync: adjusting RTC by -2
4/18/18 23:00:00 timeSync: adjusting RTC by -2
4/20/18 01:00:00 timeSync: adjusting RTC by -2
4/20/18 22:00:00 timeSync: adjusting RTC by -2
4/22/18 03:00:00 timeSync: adjusting RTC by -2
4/23/18 01:00:00 timeSync: adjusting RTC by -2
4/24/18 03:00:00 timeSync: adjusting RTC by -2
4/25/18 02:00:00 timeSync: adjusting RTC by -2
4/26/18 03:00:00 timeSync: adjusting RTC by -2
4/26/18 16:30:14 checkUpdate: Invalid response from server.
4/27/18 01:00:00 timeSync: adjusting RTC by -2
4/28/18 03:00:00 timeSync: adjusting RTC by -2
4/28/18 13:30:20 checkUpdate: Invalid response from server.
4/29/18 05:00:00 timeSync: adjusting RTC by -2
4/29/18 17:52:54 Server: Sent less data than expected!
4/29/18 17:53:18 Server: Sent less data than expected!
4/29/18 17:53:28 Server: Sent less data than expected!
4/29/18 18:33:45 Server: Sent less data than expected!
4/29/18 18:34:04 Server: Sent less data than expected!
4/29/18 19:30:26 checkUpdate: Invalid response from server.
4/30/18 02:00:00 timeSync: adjusting RTC by -2
5/1/18 01:30:27 checkUpdate: Invalid response from server.
5/1/18 03:00:00 timeSync: adjusting RTC by -2
