That’s what I am thinking too. The setup isn’t fancy, and its not a cable modem/combo. The router is an Asus AC3100. This log shows 2 different IP addresses. As part of the troubleshooting, I did do a complete reset of the wifi and device, which was when it came back as 192.168.1.137.
The other log files (histlog.log and iotalog.log), contain characters such as:
ôõÖ\ ë:£Ò¢?p$îñ=¨ÿ?
They do have a recent time stamp for today, so they are being written to. For context, the size of each is: histlog.log - 317KB and iotalog.log - 3.8MB
Also, just in looking at the sd card, the only file that appears to be an executable is /download/02_04_00.BIN. Everything else is .log, .txt, .htm, or .js. I just wanted to make sure that is what you expect to see.
Trace: 203:57[176], 213:78[238], 245:6[35], 143:129[41], 186:208[99], 87:12[150], 123:31[165], 17:123[117], 142:140[58], 235:114[94], 221:62[226], 123:98[54], 152:10[177], 44:149[31], 71:69[192], 75:111[141], 203:42[195], 119:214[124], 154:113[93], 34:120[158], 40:1[66], 188:70[153], 142:228[109], 77:61[89], 144:184[131], 163:24[251], 41:126[93], 139:47[66], 204:226[192], 2:142[162], 187:166[248], 183:83[222]
ESP8266 ChipID: 2528364
IoTaWatt 4.x, Firmware version 02_04_00
SPIFFS mounted.
Local time zone: +0:00
device name: IotaWatt
Connecting with WiFiManager.
Reset reason: Power on
Trace: 201:49[48], 221:78[238], 245:6[51], 11:129[169], 250:208[99], 87:12[150], 123:31[37], 17:125[117], 206:140[58], 239:82[94], 221:62[226], 115:114[54], 152:10[177], 44:149[15], 7:69[192], 75:109[141], 203:42[143], 119:214[124], 218:113[93], 34:120[94], 40:5[66], 184:230[153], 142:164[125], 73:29[89], 208:184[131], 163:24[251], 41:126[221], 139:47[66], 68:97[192], 2:138[162], 155:166[216], 183:83[254]
SPIFFS mounted.
Trace: 139:49[48], 213:94[238], 247:6[35], 15:129[169], 186:208[99], 87:12[150], 123:31[37], 17:123[117], 206:140[122], 235:114[94], 253:62[226], 115:98[54], 152:10[241], 44:149[95], 7:69[192], 75:109[141], 203:43[135], 119:222[125], 138:113[93], 32:120[30], 168:5[66], 184:198[153], 142:228[125], 93:61[89], 208:184[131], 163:24[251], 41:126[149], 139:47[66], 64:97[192], 2:142[162], 155:166[216], 151:83[222]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=KoopNET, IP=192.168.1.138, channel=11, RSSI -41db
timeSync: service started.
statService: started.
Updater: service started. Auto-update class is ALPHA
5/11/19 16:18:01z timeSync: RTC initalized to NTP time
5/11/19 16:18:01z dataLog: service started.
5/11/19 16:18:01z dataLog: New current log created.
5/11/19 16:18:03z Updater: Auto-update is current for class ALPHA.
5/11/19 16:20:01z historyLog: service started.
5/11/19 16:20:01z historyLog: first entry 05/11/19 16:19:00
5/11/19 16:45:43z WiFi disconnected.
5/11/19 16:48:03z WiFi connected. SSID=KoopNET, IP=192.168.1.137, channel=1, RSSI -34db
