My Config
"format": 2,
"timezone": "10",
"update": "NONE",
"device": {
"name": "IotaWatt",
"version": 3,
"refvolts": 1,
"channels": "15",
"burden": [
0,
24,
24,
24,
24,
24,
24,
24,
24,
24,
24,
24,
24,
24,
24
"inputs": [
"channel": 0,
"name": "Input_0",
"type": "VT",
"model": "generic240V",
"phase": 2,
"cal": 21.7
"channel": 1,
"name": "Main_In_Red",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"cal": 41.666666666666664
"channel": 2,
"name": "Main_In_White",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"cal": 41.666666666666664,
"vphase": 120
"channel": 3,
"name": "Main_In_Blue",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"vphase": 240
"channel": 4,
"name": "RCD_A",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"channel": 5,
"name": "RCD_B",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"vphase": 120
"channel": 6,
"name": "RCD_C",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"vphase": 240
null,
"channel": 8,
"name": "Solar_In_Red",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"channel": 9,
"name": "Solar_In_White",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"vphase": 120
"channel": 10,
"name": "Solar_In_Blue",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"cal": "41.67",
"vphase": 240
null,
null,
null,
null
"outputs": [
"name": "House",
"units": "Watts",
"script": "@4+@5+@6"
"name": "MainsIn",
"units": "Watts",
"script": "@1+@2+@3"
"name": "SolarIn",
"units": "Watts",
"script": "@8+@9+@10"
"server": {
"type": "none"
"derive3ph": true,
"pvoutput": {
"type": "pvoutput",
"revision": 3,
"interval": 300,
"apikey": "xxxxxxx",
"systemid": "xxxxx",
"outputs": [
"name": "consumption",
"units": "Watts",
"name": "generation",
"units": "Watts",
"name": "voltage",
"units": "Volts",
"script": "@0"
"stop": true,
"begdate": 1555372800,
"reload": true
"dstrule": {
"adj": 60,
"utc": false,
"begin": {
"month": 10,
"weekday": 1,
"instance": 1,
"time": 120
"end": {
"month": 4,
"weekday": 1,
"instance": 1,
"time": 180
