There shouldn’t be anything else issuing queries, I’m not connected to any of the third party graphing sites. The switch to a different wifi router occurred on Sept 15. You can see the long disconnect in the log. Attaching some more into…
7/09/22 12:01:02 LLMNR responder started for hostname IotaWatt
7/09/22 12:01:02 Updater: service started. Auto-update class is MINOR
7/09/22 12:01:03 historyLog: service started.
7/09/22 12:01:03 historyLog: Last log entry 07/09/22 12:00:00
7/09/22 12:01:03 Updater: Auto-update is current for class MINOR.
7/09/22 16:01:06z Real Time Clock is running. Unix time 1657382466
7/09/22 16:01:06z Reset reason: Exception
7/09/22 16:01:06z Trace: 9:9, 1:2, 1:3, 10:50, 25:10, 25:10, 25:10, 25:10, 25:12, 25:13, 25:13, 25:13, 25:17, 25:13, 25:13, 25:18, 25:19, 25:20, 10:52, 10:55, 10:56, 25:20, 25:40, 25:41, 25:50, 25:51, 25:53, 25:54, 25:60, 25:61, 25:61, 25:64
7/09/22 16:01:06z ESP8266 ID: 15876047, RTC PCF8523 (68)
7/09/22 16:01:06z IoTaWatt 5.0, Firmware version 02_07_05
7/09/22 16:01:06z SPIFFS mounted.
7/09/22 12:01:06 Local time zone: -5:00, using DST/BST when in effect.
7/09/22 12:01:06 device name: IotaWatt
7/09/22 12:01:06 HTTP server started
7/09/22 12:01:06 timeSync: service started.
7/09/22 12:01:06 statService: started.
7/09/22 12:01:06 dataLog: service started.
7/09/22 12:01:06 dataLog: Last log entry 07/09/22 12:01:00
7/09/22 12:01:10 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -66db
7/09/22 12:01:10 MDNS responder started for hostname IotaWatt
7/09/22 12:01:10 LLMNR responder started for hostname IotaWatt
7/09/22 12:01:10 Updater: service started. Auto-update class is MINOR
7/09/22 12:01:11 historyLog: service started.
7/09/22 12:01:11 historyLog: Last log entry 07/09/22 12:01:00
7/09/22 12:01:11 Updater: Auto-update is current for class MINOR.
7/22/22 04:08:32z Real Time Clock is running. Unix time 1658462912
7/22/22 04:08:32z Reset Reason: Power-fail restart.
7/22/22 04:08:32z ESP8266 ID: 15876047, RTC PCF8523 (68)
7/22/22 04:08:32z IoTaWatt 5.0, Firmware version 02_07_05
7/22/22 04:08:32z SPIFFS mounted.
7/22/22 00:08:32 Local time zone: -5:00, using DST/BST when in effect.
7/22/22 00:08:32 device name: IotaWatt
7/22/22 00:08:35 Connecting with WiFiManager.
7/22/22 00:10:44 Did not connect after power-fail. Restarting to reset WiFi.
7/22/22 04:10:45z Real Time Clock is running. Unix time 1658463045
7/22/22 04:10:45z Reset reason: Software/System restart
7/22/22 04:10:45z Trace: 34:5, 34:6[13], 34:10[1], 34:30, 34:10[2], 34:30, 34:10[4], 34:30, 34:15, 34:30, 34:30, 34:10[5], 34:30, 34:15, 34:30, 34:5, 34:5, 34:5, 34:6[3], 34:10[1], 34:30, 34:10[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/22/22 04:10:45z ESP8266 ID: 15876047, RTC PCF8523 (68)
7/22/22 04:10:45z IoTaWatt 5.0, Firmware version 02_07_05
7/22/22 04:10:45z SPIFFS mounted.
7/22/22 00:10:45 Local time zone: -5:00, using DST/BST when in effect.
7/22/22 00:10:45 device name: IotaWatt
7/22/22 00:10:45 HTTP server started
7/22/22 00:10:45 timeSync: service started.
7/22/22 00:10:45 statService: started.
7/22/22 00:10:45 dataLog: service started.
7/22/22 00:10:45 dataLog: Last log entry 07/22/22 00:08:15
7/22/22 00:10:49 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -64db
7/22/22 00:10:49 MDNS responder started for hostname IotaWatt
7/22/22 00:10:49 LLMNR responder started for hostname IotaWatt
7/22/22 00:10:49 Updater: service started. Auto-update class is MINOR
7/22/22 00:10:53 historyLog: service started.
7/22/22 00:10:53 historyLog: Last log entry 07/22/22 00:08:00
7/22/22 00:11:00 Updater: Invalid response from server. HTTPcode: -11
7/22/22 01:10:51 Updater: Auto-update is current for class MINOR.
7/24/22 00:15:15z Real Time Clock is running. Unix time 1658621715
7/24/22 00:15:15z Reset Reason: Power-fail restart.
7/24/22 00:15:15z ESP8266 ID: 15876047, RTC PCF8523 (68)
7/24/22 00:15:15z IoTaWatt 5.0, Firmware version 02_07_05
7/24/22 00:15:15z SPIFFS mounted.
7/23/22 20:15:15 Local time zone: -5:00, using DST/BST when in effect.
7/23/22 20:15:15 device name: IotaWatt
7/23/22 20:15:18 Connecting with WiFiManager.
7/23/22 20:17:27 Did not connect after power-fail. Restarting to reset WiFi.
7/24/22 00:17:28z Real Time Clock is running. Unix time 1658621848
7/24/22 00:17:28z Reset reason: Software/System restart
7/24/22 00:17:28z Trace: 34:5, 34:6[13], 34:10[1], 34:30, 34:10[2], 34:30, 34:10[4], 34:30, 34:15, 34:30, 34:30, 34:10[5], 34:30, 34:15, 34:30, 34:5, 34:5, 34:5, 34:6[3], 34:10[1], 34:30, 34:10[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
7/24/22 00:17:28z ESP8266 ID: 15876047, RTC PCF8523 (68)
7/24/22 00:17:28z IoTaWatt 5.0, Firmware version 02_07_05
7/24/22 00:17:28z SPIFFS mounted.
7/23/22 20:17:28 Local time zone: -5:00, using DST/BST when in effect.
7/23/22 20:17:28 device name: IotaWatt
7/23/22 20:17:28 HTTP server started
7/23/22 20:17:28 timeSync: service started.
7/23/22 20:17:28 statService: started.
7/23/22 20:17:28 dataLog: service started.
7/23/22 20:17:28 dataLog: Last log entry 07/23/22 20:15:05
7/23/22 20:17:32 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -65db
7/23/22 20:17:32 MDNS responder started for hostname IotaWatt
7/23/22 20:17:32 LLMNR responder started for hostname IotaWatt
7/23/22 20:17:32 Updater: service started. Auto-update class is MINOR
7/23/22 20:17:36 historyLog: service started.
7/23/22 20:17:36 historyLog: Last log entry 07/23/22 20:15:00
7/23/22 20:17:43 Updater: Invalid response from server. HTTPcode: -11
7/23/22 21:17:40 Updater: Auto-update is current for class MINOR.
7/31/22 21:20:25 WiFi disconnected.
7/31/22 21:21:28 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -66db
8/10/22 18:05:53z Real Time Clock is running. Unix time 1660154753
8/10/22 18:05:53z Reset Reason: Power-fail restart.
8/10/22 18:05:53z ESP8266 ID: 15876047, RTC PCF8523 (68)
8/10/22 18:05:53z IoTaWatt 5.0, Firmware version 02_07_05
8/10/22 18:05:53z SPIFFS mounted.
8/10/22 14:05:53 Local time zone: -5:00, using DST/BST when in effect.
8/10/22 14:05:53 device name: IotaWatt
8/10/22 14:05:56 Connecting with WiFiManager.
8/10/22 14:08:05 Did not connect after power-fail. Restarting to reset WiFi.
8/10/22 18:08:06z Real Time Clock is running. Unix time 1660154886
8/10/22 18:08:06z Reset reason: Software/System restart
8/10/22 18:08:06z Trace: 34:5, 34:6[13], 34:10[1], 34:30, 34:10[2], 34:30, 34:10[4], 34:30, 34:15, 34:30, 34:30, 34:10[5], 34:30, 34:15, 34:30, 34:5, 34:5, 34:5, 34:6[3], 34:10[1], 34:30, 34:10[2], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
8/10/22 18:08:06z ESP8266 ID: 15876047, RTC PCF8523 (68)
8/10/22 18:08:06z IoTaWatt 5.0, Firmware version 02_07_05
8/10/22 18:08:06z SPIFFS mounted.
8/10/22 14:08:06 Local time zone: -5:00, using DST/BST when in effect.
8/10/22 14:08:06 device name: IotaWatt
8/10/22 14:08:06 HTTP server started
8/10/22 14:08:06 timeSync: service started.
8/10/22 14:08:06 statService: started.
8/10/22 14:08:06 dataLog: service started.
8/10/22 14:08:06 dataLog: Last log entry 08/10/22 14:02:35
8/10/22 14:08:10 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -61db
8/10/22 14:08:10 MDNS responder started for hostname IotaWatt
8/10/22 14:08:10 LLMNR responder started for hostname IotaWatt
8/10/22 14:08:10 Updater: service started. Auto-update class is MINOR
8/10/22 14:08:11 historyLog: service started.
8/10/22 14:08:11 historyLog: Last log entry 08/10/22 14:02:00
8/10/22 14:08:11 Updater: Auto-update is current for class MINOR.
8/24/22 03:40:50 Updater: update tables from 0.0.5 to 0.0.6
8/31/22 20:33:18 WiFi disconnected.
8/31/22 20:34:23 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -61db
9/11/22 16:21:00 WiFi disconnected.
9/11/22 16:46:45 WiFi connected. SSID=Lulu_2.4, IP=192.168.0.53, channel=10, RSSI -65db
9/11/22 16:46:52 Updater: Invalid response from server. HTTPcode: -4
9/15/22 09:25:15 WiFi disconnected.
9/15/22 10:25:15 WiFi disconnected more than 60 minutes, restarting.
9/15/22 14:25:17z Real Time Clock is running. Unix time 1663251917
9/15/22 14:25:17z Reset reason: Software/System restart
9/15/22 14:25:17z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:2
9/15/22 14:25:17z ESP8266 ID: 15876047, RTC PCF8523 (68)
9/15/22 14:25:17z IoTaWatt 5.0, Firmware version 02_07_05
9/15/22 14:25:17z SPIFFS mounted.
9/15/22 10:25:17 Local time zone: -5:00, using DST/BST when in effect.
9/15/22 10:25:17 device name: IotaWatt
9/15/22 10:25:17 HTTP server started
9/15/22 10:25:17 timeSync: service started.
9/15/22 10:25:17 statService: started.
9/15/22 10:25:17 dataLog: service started.
9/15/22 10:25:17 dataLog: Last log entry 09/15/22 10:25:15
9/15/22 10:25:22 historyLog: service started.
9/15/22 10:25:22 historyLog: Last log entry 09/15/22 10:25:00
9/15/22 11:06:17 WiFi connected. SSID=Lulu_2.4, IP=192.168.1.100, channel=6, RSSI -64db
9/15/22 11:06:17 MDNS responder started for hostname IotaWatt
9/15/22 11:06:17 LLMNR responder started for hostname IotaWatt
9/15/22 11:06:17 Updater: service started. Auto-update class is MINOR
9/15/22 11:06:18 Updater: Auto-update is current for class MINOR.
9/15/22 11:26:49 WiFi disconnected.
9/15/22 11:27:15 WiFi connected. SSID=Lulu_2.4, IP=192.168.1.100, channel=6, RSSI -67db
9/18/22 16:37:10 WiFi disconnected.
9/18/22 16:59:34 WiFi connected. SSID=Lulu_2.4, IP=192.168.1.100, channel=1, RSSI -55db
9/22/22 11:49:54 WiFi disconnected.
9/22/22 12:01:19 WiFi connected. SSID=Lulu_2.4, IP=192.168.1.100, channel=6, RSSI -52db
