I have both sides of my range breaker monitored with CT clamps. When looking at the status page only one side of the breaker show a measurement.
This normal or am I messing something up?
Don’t know. Could be normal. Older electric ranges used both 120V and 240V to get different power output. If your range is three-wire, that could be the case. I would think there would be power on both legs if a burner is on high.
You could swap the two CTs on the breakers and see if the measurement remains on that CT (there is a problem) or moves to the other CT (there is no problem)
Common problems with CTs not reading are that the jack is not plugged into the IoTaWatt all the way, or the CT is not closed.
