The relevant parts of the message logs -
6/30/22 07:19:22z Real Time Clock is running. Unix time 1656573562
6/30/22 07:19:22z Reset reason: Exception
6/30/22 07:19:22z Trace: 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
6/30/22 07:19:22z ESP8266 ID: 15907426, RTC PCF8523 (68)
6/30/22 07:19:22z IoTaWatt 5.0, Firmware version 02_07_05
6/30/22 07:19:22z SPIFFS mounted.
6/30/22 08:19:22z Local time zone: +0:00, using DST/BST when in effect.
6/30/22 08:19:22z device name: GarageIW
6/30/22 08:19:22z HTTP server started
6/30/22 08:19:22z emoncms: Starting, interval:10, url:http://192.168.0.199
6/30/22 08:19:22z timeSync: service started.
6/30/22 08:19:22z statService: started.
6/30/22 08:19:22z dataLog: service started.
6/30/22 08:19:22z dataLog: Last log entry 06/30/22 08:19:20
6/30/22 08:19:26z WiFi connected. SSID=HML-GGE, IP=192.168.0.65, channel=3, RSSI -60db
6/30/22 08:19:26z MDNS responder started for hostname GarageIW
6/30/22 08:19:26z LLMNR responder started for hostname GarageIW
6/30/22 08:19:26z Updater: service started. Auto-update class is MINOR
6/30/22 08:19:26z emoncms: Start posting at 06/30/22 08:18:50
6/30/22 08:19:27z historyLog: service started.
6/30/22 08:19:27z historyLog: Last log entry 06/30/22 08:19:00
6/30/22 08:19:28z Updater: Auto-update is current for class MINOR.
7/06/22 13:12:05z dataLog: datalog WDT - restarting
7/06/22 12:12:07z Real Time Clock is running. Unix time 1657109527
7/06/22 12:12:07z Reset reason: Software/System restart
7/06/22 12:12:07z Trace: 9:5, 9:9, 1:2, 1:3, 10:13, 1:3, 1:1[5], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:13, 10:20, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
7/06/22 12:12:07z ESP8266 ID: 15907426, RTC PCF8523 (68)
7/06/22 12:12:07z IoTaWatt 5.0, Firmware version 02_07_05
7/06/22 12:12:07z SPIFFS mounted.
7/06/22 13:12:07z Local time zone: +0:00, using DST/BST when in effect.
7/06/22 13:12:07z device name: GarageIW
7/06/22 13:12:07z HTTP server started
7/06/22 13:12:07z emoncms: Starting, interval:10, url:http://192.168.0.199
7/06/22 13:12:07z timeSync: service started.
7/06/22 13:12:07z statService: started.
7/06/22 13:12:07z dataLog: service started.
7/06/22 13:12:07z dataLog: Last log entry 07/06/22 13:07:05
7/06/22 13:12:11z WiFi connected. SSID=HML-GGE, IP=192.168.0.65, channel=3, RSSI -61db
7/06/22 13:12:11z MDNS responder started for hostname GarageIW
7/06/22 13:12:11z LLMNR responder started for hostname GarageIW
7/06/22 13:12:11z Updater: service started. Auto-update class is MINOR
7/06/22 13:12:11z emoncms: Start posting at 07/06/22 13:07:00
7/06/22 13:12:12z historyLog: service started.
7/06/22 13:12:12z historyLog: Last log entry 07/06/22 13:07:00
7/06/22 13:12:12z Updater: Auto-update is current for class MINOR.
7/04/22 19:54:55z Real Time Clock is running. Unix time 1656964495
7/04/22 19:54:55z Reset reason: Software/System restart
7/04/22 19:54:55z Trace: 9:2, 1:2, 1:3, 1:3, 1:1[7], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
7/04/22 19:54:55z ESP8266 ID: 12686222, RTC PCF8523 (68)
7/04/22 19:54:56z IoTaWatt 5.0, Firmware version 02_07_05
7/04/22 19:54:56z SPIFFS mounted.
7/04/22 19:54:56z Local time zone: +0:00
7/04/22 19:54:56z device name: IotaHML
7/04/22 19:54:56z HTTP server started
7/04/22 19:54:56z emoncms: Starting, interval:10, url:http://192.168.0.199/emoncms
7/04/22 19:54:57z timeSync: service started.
7/04/22 19:54:57z statService: started.
7/04/22 19:54:57z dataLog: service started.
7/04/22 19:55:00z dataLog: Last log entry 07/04/22 19:54:50
7/04/22 19:55:01z SB1200wh: Started
7/04/22 19:55:01z SB1200wh: Last log entry 07/04/22 19:54:50
7/04/22 19:55:01z SB4000kWh: Started
7/04/22 19:55:01z SB4000kWh: Last log entry 07/04/22 19:54:50
7/04/22 19:55:02z historyLog: service started.
7/04/22 19:55:02z historyLog: Last log entry 07/04/22 19:54:00
7/04/22 19:55:03z SB5000WH: Started
7/04/22 19:55:03z SB5000WH: Last log entry 07/04/22 19:54:50
7/04/22 19:55:06z WiFi connected. SSID=Ubiquiti HML, IP=192.168.0.54, channel=11, RSSI -46db
7/04/22 19:55:06z MDNS responder started for hostname IotaHML
7/04/22 19:55:06z LLMNR responder started for hostname IotaHML
7/04/22 19:55:06z Updater: service started. Auto-update class is MINOR
7/04/22 19:55:07z emoncms: Start posting at 07/04/22 19:54:50
7/04/22 19:55:10z Updater: Auto-update is current for class MINOR.
7/06/22 05:58:45z dataLog: datalog WDT - restarting
7/06/22 05:58:47z Real Time Clock is running. Unix time 1657087127
7/06/22 05:58:47z Reset reason: Software/System restart
7/06/22 05:58:47z Trace: 1:3, 10:13, 1:3, 1:1[2], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:13, 1:3, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
7/06/22 05:58:47z ESP8266 ID: 12686222, RTC PCF8523 (68)
7/06/22 05:58:48z IoTaWatt 5.0, Firmware version 02_07_05
7/06/22 05:58:48z SPIFFS mounted.
7/06/22 05:58:48z Local time zone: +0:00
7/06/22 05:58:48z device name: IotaHML
7/06/22 05:58:48z HTTP server started
7/06/22 05:58:48z emoncms: Starting, interval:10, url:http://192.168.0.199/emoncms
7/06/22 05:58:49z timeSync: service started.
7/06/22 05:58:49z statService: started.
7/06/22 05:58:49z dataLog: service started.
7/06/22 05:58:52z dataLog: Last log entry 07/06/22 05:53:45
7/06/22 05:58:54z historyLog: service started.
7/06/22 05:58:55z historyLog: Last log entry 07/06/22 05:53:00
7/06/22 05:58:55z WiFi connected. SSID=Ubiquiti HML, IP=192.168.0.54, channel=11, RSSI -45db
7/06/22 05:58:55z MDNS responder started for hostname IotaHML
7/06/22 05:58:56z LLMNR responder started for hostname IotaHML
7/06/22 05:58:56z Updater: service started. Auto-update class is MINOR
7/06/22 05:58:56z emoncms: Start posting at 07/06/22 05:53:40
7/06/22 05:58:57z Updater: Auto-update is current for class MINOR.
7/06/22 05:58:58z SB1200wh: Started
7/06/22 05:58:58z SB1200wh: Last log entry 07/06/22 05:53:45
7/06/22 05:58:58z SB4000kWh: Started
7/06/22 05:58:59z SB4000kWh: Last log entry 07/06/22 05:53:45
7/06/22 05:58:59z SB5000WH: Started
7/06/22 05:58:59z SB5000WH: Last log entry 07/06/22 05:53:45
7/04/22 19:46:21z Real Time Clock is running. Unix time 1656963981
7/04/22 19:46:21z Reset reason: Software/System restart
7/04/22 19:46:21z Trace: 8:4, 8:6, 8:8, 8:9, 9:2, 1:2, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2, 1:3, 1:3, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2
7/04/22 19:46:21z ESP8266 ID: 9109337, RTC PCF8523 (68)
7/04/22 19:46:21z IoTaWatt 5.0, Firmware version 02_07_05
7/04/22 19:46:21z SPIFFS mounted.
7/04/22 20:46:21z Local time zone: +0:00, using DST/BST when in effect.
7/04/22 20:46:21z device name: PumpHse
7/04/22 20:46:21z HTTP server started
7/04/22 20:46:21z emoncms: Starting, interval:10, url:http://192.168.0.199/emoncms
7/04/22 20:46:22z timeSync: service started.
7/04/22 20:46:22z statService: started.
7/04/22 20:46:22z dataLog: service started.
7/04/22 20:46:24z dataLog: Last log entry 07/04/22 20:41:20
7/04/22 20:46:27z historyLog: service started.
7/04/22 20:46:28z historyLog: Last log entry 07/04/22 20:41:00
7/04/22 20:46:30z WiFi connected. SSID=HML-PumpHouse, IP=192.168.0.55, channel=9, RSSI -48db
7/04/22 20:46:30z MDNS responder started for hostname PumpHse
7/04/22 20:46:30z LLMNR responder started for hostname PumpHse
7/04/22 20:46:30z Updater: service started. Auto-update class is MINOR
7/04/22 20:46:31z emoncms: Start posting at 07/04/22 20:41:20
7/04/22 20:46:31z Updater: Auto-update is current for class MINOR.
7/05/22 08:49:25z dataLog: datalog WDT - restarting
7/05/22 07:49:26z Real Time Clock is running. Unix time 1657007366
7/05/22 07:49:26z Reset reason: Software/System restart
7/05/22 07:49:26z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2, 1:3, 10:13, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2
7/05/22 07:49:26z ESP8266 ID: 9109337, RTC PCF8523 (68)
7/05/22 07:49:26z IoTaWatt 5.0, Firmware version 02_07_05
7/05/22 07:49:26z SPIFFS mounted.
7/05/22 08:49:26z Local time zone: +0:00, using DST/BST when in effect.
7/05/22 08:49:26z device name: PumpHse
7/05/22 08:49:26z HTTP server started
7/05/22 08:49:26z emoncms: Starting, interval:10, url:http://192.168.0.199/emoncms
7/05/22 08:49:27z timeSync: service started.
7/05/22 08:49:27z statService: started.
7/05/22 08:49:27z dataLog: service started.
7/05/22 08:49:29z dataLog: Last log entry 07/05/22 08:44:30
7/05/22 08:49:32z historyLog: service started.
7/05/22 08:49:33z historyLog: Last log entry 07/05/22 08:44:00
7/05/22 08:49:33z WiFi connected. SSID=HML-PumpHouse, IP=192.168.0.55, channel=9, RSSI -47db
7/05/22 08:49:33z MDNS responder started for hostname PumpHse
7/05/22 08:49:33z LLMNR responder started for hostname PumpHse
7/05/22 08:49:33z Updater: service started. Auto-update class is MINOR
7/05/22 08:49:33z emoncms: Start posting at 07/05/22 08:44:20
7/05/22 08:49:35z Updater: Auto-update is current for class MINOR.
These are taken from the web page. I don’t seem to be able to download files from the Iotawatts, they always fail.
