I bought the IoTaWatt kit with just the two 100A CTs and have been enjoying it so far. I decided I would like to monitor a few individual circuits and for… reasons… decided to order the CTs directly from AccuEnergy rather than through the IoTaWatt store. What I didn’t realize is that the AccuCT-H040-50 from IoTaWatt is actually a custom build; not only does the stock version not come with the jack, it is the voltage type with the built-in burden resistor rather than the current type.
What’s the best way for me to proceed? I can solder some jacks on easily enough. Can the CTs I bought be easily modified to remove the burden resistor? Should I remove the burden resistor from the IoTaWatt? Or should I see if AccuEnergy will accept a return and buy the CTs from the IoTaWatt store like I should have to begin with?
