I have just started using the “Outputs” functionality to create new data streams (i.e. adding all of the circuits together to get House_Power, House_Energy, …) that I can monitor using the Iotawatt graph module.
Unfortunately, I cant work out how to include those “Outputs” in the Influxdb upload so I can monitor them in grafana as well. The calculator doesnt seem to provide access to Outputs in the same way that you can include Inputs. As a work around, I ended up duplicating each of the Output calculations with an equivalent Measurement calculation. This works but is a bit of a hassle. Am I missing something obvious here?.
