Crashing when enabling Influxdb V2 Cloud using reverse SSL proxy.
I have been using iotawatt for almost 3 years now with everything getting pushed into influx 1.x db. I just enabled the 2.x stuff using the influx cloud. I set it to upload just a couple of items from Oct 1, 2022. As soon as I enable it I can see it uploading throught he proxy logs, however it keeps crashing iotawatt If I stop the proxy server I can get logged back in. Here is a snippet of the logs:
10/30/22 08:22:22z Real Time Clock is running. Unix time 1667118142
10/30/22 08:22:22z Reset reason: Exception
10/30/22 08:22:22z Trace: 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[5], 31:120, 21:100[31], 21:101, 31:120, 31:122, 31:123, 31:124, 32:95, 32:95, 31:126, 31:1
10/30/22 08:22:22z ESP8266 ID: 2518078, RTC PCF8523 (68)
10/30/22 08:22:22z IoTaWatt 4.x, Firmware version 02_07_05
10/30/22 08:22:22z SPIFFS mounted.
10/30/22 01:22:22 Local time zone: -8:00, using DST/BST when in effect.
10/30/22 01:22:22 device name: IotaWatt
10/30/22 01:22:22 HTTP server started
10/30/22 01:22:22 influxDB_v1: Starting, interval:5, url:http://192.168.50.20:8086
10/30/22 01:22:22 influxDB_v2: Starting, interval:10, url:https://us-west-2-2.aws.cloud2.influxdata.com
10/30/22 01:22:22 timeSync: service started.
10/30/22 01:22:22 statService: started.
10/30/22 01:22:22 dataLog: service started.
10/30/22 01:22:24 dataLog: Last log entry 10/30/22 01:22:20
10/30/22 01:22:27 historyLog: service started.
10/30/22 01:22:28 historyLog: Last log entry 10/30/22 01:22:00
10/30/22 01:22:28 WiFi connected. SSID=CrzyWifi, IP=192.168.50.26, channel=6, RSSI -69db
10/30/22 01:22:28 MDNS responder started for hostname IotaWatt
10/30/22 01:22:28 LLMNR responder started for hostname IotaWatt
10/30/22 01:22:28 Updater: service started. Auto-update class is BETA
10/30/22 01:22:28 grid: Started
10/30/22 01:22:28 grid: Last log entry 10/30/22 01:22:20
10/30/22 08:22:29z Real Time Clock is running. Unix time 1667118149
10/30/22 08:22:29z Reset reason: Exception
10/30/22 08:22:29z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[9], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2
10/30/22 08:22:29z ESP8266 ID: 2518078, RTC PCF8523 (68)
10/30/22 08:22:29z IoTaWatt 4.x, Firmware version 02_07_05
10/30/22 08:22:29z SPIFFS mounted.
10/30/22 01:22:29 Local time zone: -8:00, using DST/BST when in effect.
10/30/22 01:22:29 device name: IotaWatt
10/30/22 01:22:29 HTTP server started
10/30/22 01:22:29 influxDB_v1: Starting, interval:5, url:http://192.168.50.20:8086
10/30/22 01:22:29 influxDB_v2: Starting, interval:10, url:https://us-west-2-2.aws.cloud2.influxdata.com
10/30/22 01:22:29 timeSync: service started.
10/30/22 01:22:29 statService: started.
10/30/22 01:22:29 dataLog: service started.
10/30/22 01:22:31 dataLog: Last log entry 10/30/22 01:22:25
10/30/22 01:22:34 historyLog: service started.
10/30/22 01:22:35 historyLog: Last log entry 10/30/22 01:22:00
10/30/22 01:22:35 WiFi connected. SSID=CrzyWifi, IP=192.168.50.26, channel=6, RSSI -69db
10/30/22 01:22:35 MDNS responder started for hostname IotaWatt
10/30/22 01:22:35 LLMNR responder started for hostname IotaWatt
10/30/22 01:22:35 Updater: service started. Auto-update class is BETA
10/30/22 01:22:35 grid: Started
10/30/22 01:22:36 grid: Last log entry 10/30/22 01:22:25
10/30/22 08:22:37z Real Time Clock is running. Unix time 1667118157
10/30/22 08:22:37z Reset reason: Exception
10/30/22 08:22:37z Trace: 32:95, 31:126, 31:1, 1:6[6], 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
10/30/22 08:22:37z ESP8266 ID: 2518078, RTC PCF8523 (68)
10/30/22 08:22:37z IoTaWatt 4.x, Firmware version 02_07_05
10/30/22 08:22:37z SPIFFS mounted.
10/30/22 01:22:37 Local time zone: -8:00, using DST/BST when in effect.
10/30/22 01:22:37 device name: IotaWatt
10/30/22 01:22:37 HTTP server started
10/30/22 01:22:37 influxDB_v1: Starting, interval:5, url:http://192.168.50.20:8086
10/30/22 01:22:37 influxDB_v2: Starting, interval:10, url:https://us-west-2-2.aws.cloud2.influxdata.com
10/30/22 01:22:37 timeSync: service started.
10/30/22 01:22:37 statService: started.
10/30/22 01:22:37 dataLog: service started.
10/30/22 01:22:39 dataLog: Last log entry 10/30/22 01:22:35
10/30/22 01:22:42 historyLog: service started.
10/30/22 01:22:43 historyLog: Last log entry 10/30/22 01:22:00
10/30/22 01:22:43 WiFi connected. SSID=CrzyWifi, IP=192.168.50.26, channel=6, RSSI -68db
10/30/22 01:22:43 MDNS responder started for hostname IotaWatt
10/30/22 01:22:43 LLMNR responder started for hostname IotaWatt
10/30/22 01:22:43 Updater: service started. Auto-update class is BETA
10/30/22 01:22:43 grid: Started
10/30/22 01:22:43 grid: Last log entry 10/30/22 01:22:35
10/30/22 01:22:46 Updater: Auto-update is current for class BETA.
10/30/22 01:22:46 influxDB_v1: Start posting at 10/30/22 01:11:35
