Have set up iotawatt successfully, but now stuck trying to define outputs. On both my iphone and ipad, when I select Setup and then Outputs, the dropdown menu does not disappear. It covers the Add Output button, so I’m stuck on these devices.
I know there is an Add button, because I can see it when I use my desktop PC. Here, the dropdown menu disappears, but once I define an output, there is no SAVE button!
Got rid of space in name, and SAVE appeared, so was able to set up the output.
Browser situation seems to be finicky. I can make the dropdown disappear in Chrome by touching outside the dropdown, and then proceed. I also downloaded and tried Firefox focus. This had the same problem as Safari, which I was using originally - as you had surmised.
You note that you can “live with” Safari. How do you proceed in Safari if the dropdown persists?
I have enough outputs defined that the list extends beyond the drop down. So I select one of those, or the add at the bottom. The drop down goes away and an edit appears. I than cancel that to get the unobstructed outputs list.
