OK, thanks! Pasted below.
What I see for the 10th is that starts reporting the -11 from emoncms, and keeps reporting that in every retry since then (although emoncms whas online and working normally).
12/09/20 21:42:48z Real Time Clock is running. Unix time 1607550168
12/09/20 21:42:48z Reset reason: Software Watchdog
12/09/20 21:42:48z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
12/09/20 21:42:48z ESP8266 ChipID: 2528519
12/09/20 21:42:48z IoTaWatt 4.x, Firmware version 02_05_11
12/09/20 21:42:48z SPIFFS mounted.
12/09/20 22:42:49 Local time zone: +1:00
12/09/20 22:42:49 Using Daylight Saving Time (BST) when in effect.
12/09/20 22:42:49 device name: IoTWGrge
12/09/20 22:42:49 HTTP server started
12/09/20 22:42:49 timeSync: service started.
12/09/20 22:42:49 statService: started.
12/09/20 22:42:50 dataLog: service started.
12/09/20 22:42:56 dataLog: Last log entry 12/09/20 22:42:40
12/09/20 22:42:56 Updater: service started. Auto-update class is MINOR
12/09/20 22:42:57 WiFi connected. SSID=guifi.net-ElSerratFW, IP=192.168.19.188, channel=1, RSSI -65db
12/09/20 22:42:57 MDNS responder started for hostname IoTWGrge
12/09/20 22:42:57 LLMNR responder started for hostname IoTWGrge
12/09/20 22:42:57 EmonService: started. url=HTTP://emoncms.elserrat.cat/emoncms, node=IoTWGrge, interval=10
12/09/20 22:42:57 influxDB: started, url=HTTP://192.168.19.147:8086, db=iotawatt, interval=10
12/09/20 22:42:58 Updater: Auto-update is current for class MINOR.
12/09/20 22:43:00 EmonService: Start posting at 12/09/20 22:42:50
12/09/20 22:43:02 influxDB: Start posting at 12/09/20 22:42:50
12/09/20 22:43:50 historyLog: service started.
12/09/20 22:43:52 historyLog: Last log entry 12/09/20 22:42:00
12/09/20 22:43:59 PVoutput: started
12/09/20 22:43:59 PVoutput: System El Serrat del SerÃ, interval 5, donator mode
12/09/20 22:44:00 PVoutput: Start status beginning 12/09/20 22:40:00
12/10/20 00:50:09 EmonService: HTTP response -11, retrying.
12/10/20 06:11:46 WiFi disconnected.
12/10/20 06:11:49 WiFi connected. SSID=guifi.net-ElSerratFW, IP=192.168.19.188, channel=1, RSSI -65db
12/10/20 05:57:50z Real Time Clock is running. Unix time 1607579870
12/10/20 05:57:50z Reset reason: Software Watchdog
12/10/20 05:57:50z Trace: 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
12/10/20 05:57:50z ESP8266 ChipID: 2528519
12/10/20 05:57:50z IoTaWatt 4.x, Firmware version 02_05_11
12/10/20 05:57:50z SPIFFS mounted.
12/10/20 06:57:51 Local time zone: +1:00
12/10/20 06:57:51 Using Daylight Saving Time (BST) when in effect.
12/10/20 06:57:51 device name: IoTWGrge
12/10/20 06:57:51 HTTP server started
12/10/20 06:57:51 timeSync: service started.
12/10/20 06:57:51 statService: started.
12/10/20 06:57:52 dataLog: service started.
12/10/20 06:57:57 dataLog: Last log entry 12/10/20 06:57:45
12/10/20 06:57:57 Updater: service started. Auto-update class is MINOR
12/10/20 06:57:57 WiFi connected. SSID=guifi.net-ElSerratFW, IP=192.168.19.188, channel=1, RSSI -63db
12/10/20 06:57:57 MDNS responder started for hostname IoTWGrge
12/10/20 06:57:57 LLMNR responder started for hostname IoTWGrge
12/10/20 06:57:58 EmonService: started. url=HTTP://emoncms.elserrat.cat/emoncms, node=IoTWGrge, interval=10
12/10/20 06:57:58 influxDB: started, url=HTTP://192.168.19.147:8086, db=iotawatt, interval=10
12/10/20 06:57:59 Updater: Auto-update is current for class MINOR.
12/10/20 06:58:01 EmonService: Start posting at 12/10/20 00:49:10
12/10/20 06:58:05 influxDB: Start posting at 12/10/20 06:57:50
12/10/20 06:58:53 historyLog: service started.
12/10/20 06:58:54 historyLog: Last log entry 12/10/20 06:57:00
12/10/20 06:59:01 PVoutput: started
12/10/20 06:59:02 PVoutput: System El Serrat del SerÃ, interval 5, donator mode
12/10/20 06:59:02 PVoutput: Start status beginning 12/10/20 06:55:00
12/10/20 07:00:31 EmonService: HTTP response -11, retrying.
12/10/20 10:41:46 WiFi disconnected.
12/10/20 10:41:49 WiFi connected. SSID=guifi.net-ElSerratFW, IP=192.168.19.188, channel=1, RSSI -67db
12/10/20 11:11:50z Real Time Clock is running. Unix time 1607598710
12/10/20 11:11:50z Reset reason: Software Watchdog
12/10/20 11:11:50z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
12/10/20 11:11:50z ESP8266 ChipID: 2528519
12/10/20 11:11:50z IoTaWatt 4.x, Firmware version 02_05_11
12/10/20 11:11:50z SPIFFS mounted.
12/10/20 12:11:51 Local time zone: +1:00
12/10/20 12:11:51 Using Daylight Saving Time (BST) when in effect.
12/10/20 12:11:51 device name: IoTWGrge
12/10/20 12:11:51 HTTP server started
12/10/20 12:11:51 timeSync: service started.
12/10/20 12:11:52 statService: started.
12/10/20 12:11:52 dataLog: service started.
12/10/20 12:11:57 dataLog: Last log entry 12/10/20 12:11:45
12/10/20 12:11:57 Updater: service started. Auto-update class is MINOR
12/10/20 12:11:57 WiFi connected. SSID=guifi.net-ElSerratFW, IP=192.168.19.188, channel=1, RSSI -70db
12/10/20 12:11:57 MDNS responder started for hostname IoTWGrge
12/10/20 12:11:57 LLMNR responder started for hostname IoTWGrge
12/10/20 12:11:58 EmonService: started. url=HTTP://emoncms.elserrat.cat/emoncms, node=IoTWGrge, interval=10
12/10/20 12:11:58 influxDB: started, url=HTTP://192.168.19.147:8086, db=iotawatt, interval=10
12/10/20 12:11:59 Updater: Auto-update is current for class MINOR.
12/10/20 12:12:00 EmonService: Start posting at 12/10/20 00:53:10
12/10/20 12:12:04 influxDB: Start posting at 12/10/20 12:11:50
12/10/20 12:12:53 historyLog: service started.
12/10/20 12:12:54 historyLog: Last log entry 12/10/20 12:11:00
12/10/20 12:13:01 PVoutput: started
12/10/20 12:13:02 PVoutput: System El Serrat del SerÃ, interval 5, donator mode
12/10/20 12:13:02 PVoutput: Start status beginning 12/10/20 12:10:00
12/10/20 12:14:30 EmonService: HTTP response -11, retrying.
