Hi All. Love the product. My installation has been up about a month. Stopped working about 2 days ago. I have pasted a log snippet below. I have tried a different SD Card and used the config.txt from the SPIFFS. Not very complicated installation: 6 CT’s, one integrator for WH and I experimented with an influxDB uploader but that is not going to a valid location and I think it is not in the config that I copied from the SPIFFs.
Lot’s of stuff works. Just does not seem to be collecting any data . I am ready for some help. I have done ESP8266 work in the past, though I doubt the problem goes that deep.
5/05/22 18:55:09z Real Time Clock is running. Unix time 1651776909
5/05/22 18:55:09z Reset reason: Exception
5/05/22 18:55:09z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
5/05/22 18:55:09z ESP8266 ID: 541587, RTC M41T81 (68)
5/05/22 18:55:09z IoTaWatt 5.0, Firmware version 02_07_05
5/05/22 18:55:09z SPIFFS mounted.
5/05/22 11:55:09 Local time zone: -8:00, using DST/BST when in effect.
5/05/22 11:55:09 device name: IotaWatt
5/05/22 11:55:09 HTTP server started
5/05/22 11:55:09 timeSync: service started.
5/05/22 11:55:09 statService: started.
5/05/22 11:55:09 dataLog: service started.
5/05/22 11:55:10 dataLog: Last log entry 05/04/22 13:11:35
