Thanks for your reply overeasy.
Understand. Is there a way to get more information from the device?
After some testing the state is now straight to red-red-red (or red blinking between bright and not so bright, same pace as the wifi led on the ESP-12S)
I have left it connected to usb serial and this is the current output:
rdl▒▒|▒c▒N
▒l▒
"|▒▒▒▒p▒▒|c▒B▒p~▒N▒loo▒▒"
cpp▒drlrlrllܾ▒▒$▒|▒▒l▒
c|▒▒▒▒s▒c▒
#▒▒Nn▒loo▒▒▒
#p▒$rlrlp▒o▒▒l
c
o▒|$▒l▒p
▒▒NN▒$▒▒l`▒no
l Nr▒▒▒o
▒l`r▒▒▒
▒l ▒r▒p▒
l▒{▒`▒n▒
SPI started.
4/12/20 13:37:42z Real Time Clock is running. Unix time 1586698662
4/12/20 13:37:42z Reset reason: External System
4/12/20 13:37:42z Trace: 8:2, 9:2, 1:2, 1:3, 1:4, 1:1[9], 1:2[10], 9:0[10], 9:0, 9:1, 8:2[10], 8:2, 9:2, 1:2, 1:3, 1:4, 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:2[11], 8:2, 9:2, 1:2, 1:3, 1:4, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1
4/12/20 13:37:42z ESP8266 ChipID: 2527436
4/12/20 13:37:42z IoTaWatt 4.x, Firmware version 02_05_05
4/12/20 13:37:42z SPIFFS mounted.
4/12/20 15:37:42 Local time zone: +1:00
4/12/20 15:37:42 Using Daylight Saving Time (BST) when in effect.
4/12/20 15:37:42 device name: IotaWatt
4/12/20 15:37:42 LLMNR responder started for hostname IotaWatt
4/12/20 15:37:42 HTTP server started
4/12/20 15:37:42 timeSync: service started.
4/12/20 15:37:42 statService: started.
4/12/20 15:37:42 dataLog: service started.
4/12/20 15:37:46 dataLog: Last log entry 04/12/20 15:37:35
4/12/20 15:37:46 historyLog: service started.
4/12/20 15:37:47 historyLog: Last log entry 04/12/20 15:37:00
4/12/20 15:37:47 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
4/12/20 16:37:43 WiFi disconnected more than 60 minutes, restarting.
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 1392, room 16
tail 0
chksum 0xd0
csum 0xd0
v3d128e5c
~ld
SPI started.
4/12/20 14:37:44z Real Time Clock is running. Unix time 1586702264
4/12/20 14:37:44z Reset reason: Software/System restart
4/12/20 14:37:44z Trace: 9:0[13], 9:0, 9:1, 8:2[13], 8:2, 9:2, 1:2, 1:3, 1:4, 1:1[13], 1:2[14], 9:0[14], 9:0, 9:1, 8:2[14], 8:2, 9:2, 1:2, 1:3, 1:4, 1:1[14], 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/12/20 14:37:44z ESP8266 ChipID: 2527436
4/12/20 14:37:44z IoTaWatt 4.x, Firmware version 02_05_05
4/12/20 14:37:44z SPIFFS mounted.
4/12/20 16:37:44 Local time zone: +1:00
4/12/20 16:37:44 Using Daylight Saving Time (BST) when in effect.
4/12/20 16:37:44 device name: IotaWatt
4/12/20 16:37:44 LLMNR responder started for hostname IotaWatt
4/12/20 16:37:44 HTTP server started
4/12/20 16:37:44 timeSync: service started.
4/12/20 16:37:44 statService: started.
4/12/20 16:37:44 dataLog: service started.
4/12/20 16:37:48 dataLog: Last log entry 04/12/20 16:37:40
4/12/20 16:37:48 historyLog: service started.
4/12/20 16:37:49 historyLog: Last log entry 04/12/20 16:37:00
4/12/20 16:37:49 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
Low sample count 35
The logs after march 23 is this:
3/23/20 20:12:25z Real Time Clock is running. Unix time 1584994345
3/23/20 20:12:25z Reset reason: Software/System restart
3/23/20 20:12:25z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
3/23/20 20:12:25z ESP8266 ChipID: 2527436
3/23/20 20:12:25z IoTaWatt 4.x, Firmware version 02_05_05
3/23/20 20:12:25z SPIFFS mounted.
3/23/20 21:12:25 Local time zone: +1:00
3/23/20 21:12:25 Using Daylight Saving Time (BST) when in effect.
3/23/20 21:12:25 device name: IotaWatt
3/23/20 21:12:25 LLMNR responder started for hostname IotaWatt
3/23/20 21:12:25 HTTP server started
3/23/20 21:12:25 timeSync: service started.
3/23/20 21:12:25 statService: started.
3/23/20 21:12:26 dataLog: service started.
3/23/20 21:12:29 dataLog: Last log entry 03/23/20 21:12:20
3/23/20 21:12:30 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
3/23/20 21:13:26 historyLog: service started.
3/23/20 21:13:27 historyLog: Last log entry 03/23/20 21:12:00
3/23/20 22:12:26 WiFi disconnected more than 60 minutes, restarting.
3/23/20 21:12:27z Real Time Clock is running. Unix time 1584997947
3/23/20 21:12:27z Reset reason: Software/System restart
3/23/20 21:12:27z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
3/23/20 21:12:27z ESP8266 ChipID: 2527436
3/23/20 21:12:27z IoTaWatt 4.x, Firmware version 02_05_05
3/23/20 21:12:27z SPIFFS mounted.
3/23/20 22:12:27 Local time zone: +1:00
3/23/20 22:12:27 Using Daylight Saving Time (BST) when in effect.
3/23/20 22:12:27 device name: IotaWatt
3/23/20 22:12:27 LLMNR responder started for hostname IotaWatt
3/23/20 22:12:27 HTTP server started
3/23/20 22:12:27 timeSync: service started.
3/23/20 22:12:27 statService: started.
3/23/20 22:12:28 dataLog: service started.
3/23/20 22:12:31 dataLog: Last log entry 03/23/20 22:12:25
3/23/20 22:12:32 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
3/23/20 22:13:28 historyLog: service started.
3/23/20 22:13:29 historyLog: Last log entry 03/23/20 22:12:00
3/23/20 23:12:28 WiFi disconnected more than 60 minutes, restarting.
3/23/20 22:12:29z Real Time Clock is running. Unix time 1585001549
3/23/20 22:12:29z Reset reason: Software/System restart
3/23/20 22:12:29z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
3/23/20 22:12:29z ESP8266 ChipID: 2527436
3/23/20 22:12:29z IoTaWatt 4.x, Firmware version 02_05_05
3/23/20 22:12:29z SPIFFS mounted.
3/23/20 23:12:29 Local time zone: +1:00
3/23/20 23:12:29 Using Daylight Saving Time (BST) when in effect.
3/23/20 23:12:29 device name: IotaWatt
3/23/20 23:12:29 LLMNR responder started for hostname IotaWatt
3/23/20 23:12:29 HTTP server started
3/23/20 23:12:29 timeSync: service started.
3/23/20 23:12:29 statService: started.
3/23/20 23:12:30 dataLog: service started.
3/23/20 23:12:33 dataLog: Last log entry 03/23/20 23:12:25
3/23/20 23:12:34 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
3/23/20 23:13:30 historyLog: service started.
3/23/20 23:13:31 historyLog: Last log entry 03/23/20 23:12:00
3/24/20 00:12:30 WiFi disconnected more than 60 minutes, restarting.
3/23/20 23:12:31z Real Time Clock is running. Unix time 1585005151
3/23/20 23:12:31z Reset reason: Software/System restart
3/23/20 23:12:31z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
3/23/20 23:12:31z ESP8266 ChipID: 2527436
3/23/20 23:12:31z IoTaWatt 4.x, Firmware version 02_05_05
3/23/20 23:12:31z SPIFFS mounted.
3/24/20 00:12:31 Local time zone: +1:00
3/24/20 00:12:31 Using Daylight Saving Time (BST) when in effect.
3/24/20 00:12:31 device name: IotaWatt
3/24/20 00:12:31 LLMNR responder started for hostname IotaWatt
3/24/20 00:12:31 HTTP server started
3/24/20 00:12:31 timeSync: service started.
3/24/20 00:12:31 statService: started.
3/24/20 00:12:32 dataLog: service started.
3/24/20 00:12:35 dataLog: Last log entry 03/24/20 00:12:30
3/24/20 00:12:36 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
3/24/20 00:13:32 historyLog: service started.
3/24/20 00:13:33 historyLog: Last log entry 03/24/20 00:12:00
3/24/20 01:12:32 WiFi disconnected more than 60 minutes, restarting.
3/24/20 00:12:33z Real Time Clock is running. Unix time 1585008753
3/24/20 00:12:33z Reset reason: Software/System restart
3/24/20 00:12:33z Trace: 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:5[21], 21:0, 21:2
3/24/20 00:12:33z ESP8266 ChipID: 2527436
3/24/20 00:12:33z IoTaWatt 4.x, Firmware version 02_05_05
3/24/20 00:12:33z SPIFFS mounted.
3/24/20 01:12:33 Local time zone: +1:00
3/24/20 01:12:33 Using Daylight Saving Time (BST) when in effect.
3/24/20 01:12:33 device name: IotaWatt
3/24/20 01:12:33 LLMNR responder started for hostname IotaWatt
3/24/20 01:12:33 HTTP server started
3/24/20 01:12:33 timeSync: service started.
3/24/20 01:12:33 statService: started.
3/24/20 01:12:34 dataLog: service started.
3/24/20 01:12:36 dataLog: Last log entry 03/24/20 01:12:30
3/24/20 01:12:38 influxDB: started, url=http://192.168.1.21:8086, db=iotawatt, interval=10
3/24/20 01:13:34 historyLog: service started.
3/24/20 01:13:35 historyLog: Last log entry 03/24/20 01:12:00
3/24/20 02:12:34 WiFi disconnected more than 60 minutes, restarting.
Basically just a loop with restaring after wifi disconnected for 60 minutes. I also uploaded the file since I can’t paste all the content here. (Also I could not find any sensitive information other than my ssid and ip in the logs)
IOTAMSGS.TXT (563.4 KB)
Thanks
