DaveinFL here… still having a problem with the message “get input list failing, code 302” when attempting to get data to emoncms.org from the Iotawatt. A week or so ago I had the same message, but it suddenly cleared up and I enjoyed using emoncms for a week before suddenly, my data stopped uploading.
Attached is the restart message log from Iotawatt. Any help would be greatly appreciated.
Dave
9/22/19 04:44:25z Real Time Clock is running. Unix time 1569127465
9/22/19 04:44:25z Reset reason: Software/System restart
9/22/19 04:44:25z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
9/22/19 04:44:25z ESP8266 ChipID: 2528612
9/22/19 04:44:25z IoTaWatt 5.0, Firmware version 02_04_00
9/22/19 04:44:25z SPIFFS mounted.
9/22/19 00:44:26 Local time zone: -4:00
9/22/19 00:44:26 device name: IotaWatt
9/22/19 00:44:26 MDNS responder started for hostname IotaWatt
9/22/19 00:44:26 LLMNR responder started for hostname IotaWatt
9/22/19 00:44:26 HTTP server started
9/22/19 00:44:26 timeSync: service started.
9/22/19 00:44:27 statService: started.
9/22/19 00:44:27 dataLog: service started.
9/22/19 00:44:27 dataLog: Last log entry 09/22/19 00:44:20
9/22/19 00:44:27 historyLog: service started.
9/22/19 00:44:28 historyLog: Last log entry 09/22/19 00:44:00
9/22/19 00:44:32 EmonService: started. url:80=emoncms.org/, node=IotaWatt, interval=10, encrypted
9/22/19 00:44:32 WiFi connected. SSID=Colston Asus_2.4G, IP=192.168.2.201, channel=10, RSSI -67db
9/22/19 00:44:32 Updater: service started. Auto-update class is MAJOR
9/22/19 00:44:33 Updater: Auto-update is current for class MAJOR.
9/22/19 00:44:52 EmonService: get input list failing, code: 302
