Sorry if this is covered elsewhere but I didn’t find it.
I set up the IoTaWatt according to the manual and added an integrator “grid_int” for main_1 + main_2. (I have solar, so I would expect negative values often.) I can see “grid_int.pos” etc in the available inputs when constructing an output.
In HASS, I can see all my inputs and outputs as expected, as well as “_wh” and “_wh_accumulated” for each one. However, I cannot see any variations of the integrator grid_int.
It’s my understanding that I should not use the _wh and _wh_accumulated entities for the HASS energy dashboard - correct? (If not, why do they exist? Are they created by HASS?)
I remember reading somewhere in the forums that there is a HACS integration that you prefer. I could not find that one with confidence – I gather there is an “old” and “new” HACS integration and I shouldn’t use the “old” one?
Thanks,
Brad
