Hi, I just connected my first iota watt and everything was very simple and easy following the documentation. Now I’m looking to the data and it give me measurements that are not OK. I use the CT
You’re going to have to explain your issue in more detail.
Hi, sorry for the message. From my phone it created this message with this standard text. I didn’t found how to create a new topic. Sorry. What I really wanted to post is if there is any plan for adding ethernet port to the iotawatt. I like very much the iotawatt and will be great to have the ethernet so inside a electric panel you can connect it using a cable and not wifi.
Sorry, that’s not electrically possible.
