Ok, can I check all my 240 volt plugs that same way? It seems that all of them have two wires going into the double breaker (black and red) and one going to the bar to the side with the white and some green wires.
If I see that any of the 240 volt breakers have no voltage on the white wire going to the neutral bar then I would run the ct with both red and black through it in opposite directions, and if I do see voltage I would run one wire through and just check the ‘double’ option?
