Hey all,
Purchased an IotaWatt a few months ago and finally got around to installing it. I installed the CT’s, did initial connection to wifi yesterday, configured a few things and everything was working well.
Today I was testing a few circuits in the house (just plugging a heater in) to make sure my CT’s were properly picking up each circuit. Lost connection to the web interface all of a sudden, so I went to the unit and it was flashing green. Restarted a couple of times but still couldn’t get to the interface. Had not yet had a chance to set a static IP on the unit, but checked out my router, confirmed IP and hostname. Getting timeouts and destination host unreachable when trying to get to the interface.
I searched and found a couple of references to the LED flashing, but this didn’t seem to be my issue. In any case, pulling the SD card to poke around seemed to be the best option. I didn’t see anything odd in the config file (namely the “server” tag referenced in some of the other threads)
Log file shows that my unit updated to 02_06_02 yesterday, looked to have been successful. Only thing odd in the last few entries that I see is the hardware watchdog. Please let me know if any thoughts, thanks:
7/23/21 15:38:51z Real Time Clock is running. Unix time 1627054731
7/23/21 15:38:51z Reset reason: Hardware Watchdog
7/23/21 15:38:51z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3
7/23/21 15:38:51z ESP8266 ChipID: 12672349
7/23/21 15:38:51z IoTaWatt 5.0, Firmware version 02_06_02
7/23/21 15:38:51z SPIFFS mounted.
7/23/21 11:38:51 Local time zone: -5:00
7/23/21 11:38:51 Using Daylight Saving Time (BST) when in effect.
7/23/21 11:38:51 device name: IotaWatt
7/23/21 11:38:51 HTTP server started
7/23/21 11:38:51 timeSync: service started.
7/23/21 11:38:51 statService: started.
7/23/21 11:38:51 dataLog: service started.
7/23/21 11:38:51 dataLog: Last log entry 07/23/21 11:38:40
7/23/21 11:38:55 WiFi connected. SSID=mynetwork, IP=192.168.125.117, channel=11, RSSI -57db
7/23/21 11:38:55 MDNS responder started for hostname IotaWatt
7/23/21 11:38:55 LLMNR responder started for hostname IotaWatt
7/23/21 11:38:55 Updater: service started. Auto-update class is MINOR
7/23/21 11:38:56 historyLog: service started.
7/23/21 11:38:56 historyLog: Last log entry 07/23/21 11:38:00
7/23/21 11:38:56 Updater: Auto-update is current for class MINOR.
7/23/21 17:02:49z Real Time Clock is running. Unix time 1627059769
7/23/21 17:02:49z Power failure detected.
7/23/21 17:02:49z Reset reason: External System
7/23/21 17:02:49z ESP8266 ChipID: 12672349
7/23/21 17:02:49z IoTaWatt 5.0, Firmware version 02_06_02
7/23/21 17:02:49z SPIFFS mounted.
7/23/21 13:02:49 Local time zone: -5:00
7/23/21 13:02:49 Using Daylight Saving Time (BST) when in effect.
7/23/21 13:02:49 device name: IotaWatt
7/23/21 13:02:52 HTTP server started
7/23/21 13:02:52 WiFi connected. SSID=mynetwork, IP=192.168.125.117, channel=11, RSSI -60db
7/23/21 13:02:52 MDNS responder started for hostname IotaWatt
7/23/21 13:02:52 LLMNR responder started for hostname IotaWatt
7/23/21 13:02:52 timeSync: service started.
7/23/21 13:02:52 statService: started.
7/23/21 13:02:52 Updater: service started. Auto-update class is MINOR
7/23/21 13:02:52 dataLog: service started.
7/23/21 13:02:52 dataLog: Last log entry 07/23/21 13:02:40
7/23/21 13:02:53 Updater: Auto-update is current for class MINOR.
7/23/21 13:02:57 historyLog: service started.
7/23/21 13:02:57 historyLog: Last log entry 07/23/21 13:02:00
7/23/21 17:07:51z Real Time Clock is running. Unix time 1627060071
7/23/21 17:07:51z Power failure detected.
7/23/21 17:07:51z Reset reason: External System
7/23/21 17:07:51z ESP8266 ChipID: 12672349
7/23/21 17:07:51z IoTaWatt 5.0, Firmware version 02_06_02
7/23/21 17:07:51z SPIFFS mounted.
7/23/21 13:07:51 Local time zone: -5:00
7/23/21 13:07:51 Using Daylight Saving Time (BST) when in effect.
7/23/21 13:07:51 device name: IotaWatt
7/23/21 13:07:54 HTTP server started
7/23/21 13:07:54 WiFi connected. SSID=mynetwork, IP=192.168.125.117, channel=11, RSSI -56db
7/23/21 13:07:54 MDNS responder started for hostname IotaWatt
7/23/21 13:07:54 LLMNR responder started for hostname IotaWatt
7/23/21 13:07:54 timeSync: service started.
7/23/21 13:07:54 statService: started.
7/23/21 13:07:54 Updater: service started. Auto-update class is MINOR
7/23/21 13:07:54 dataLog: service started.
7/23/21 13:07:55 dataLog: Last log entry 07/23/21 13:07:30
7/23/21 13:07:55 Updater: Auto-update is current for class MINOR.
7/23/21 13:07:59 historyLog: service started.
7/23/21 13:07:59 historyLog: Last log entry 07/23/21 13:07:00
7/23/21 17:15:50z Real Time Clock is running. Unix time 1627060550
7/23/21 17:15:50z Power failure detected.
7/23/21 17:15:50z Reset reason: External System
7/23/21 17:15:50z ESP8266 ChipID: 12672349
7/23/21 17:15:50z IoTaWatt 5.0, Firmware version 02_06_02
7/23/21 17:15:50z SPIFFS mounted.
7/23/21 13:15:50 Local time zone: -5:00
7/23/21 13:15:50 Using Daylight Saving Time (BST) when in effect.
7/23/21 13:15:50 device name: IotaWatt
7/23/21 13:15:53 HTTP server started
7/23/21 13:15:53 WiFi connected. SSID=mynetwork, IP=192.168.125.117, channel=11, RSSI -70db
7/23/21 13:15:53 MDNS responder started for hostname IotaWatt
7/23/21 13:15:53 LLMNR responder started for hostname IotaWatt
7/23/21 13:15:53 timeSync: service started.
7/23/21 13:15:53 statService: started.
7/23/21 13:15:53 Updater: service started. Auto-update class is MINOR
7/23/21 13:15:53 dataLog: service started.
7/23/21 13:15:53 dataLog: Last log entry 07/23/21 13:15:40
7/23/21 13:15:54 Updater: Auto-update is current for class MINOR.
7/23/21 13:15:58 historyLog: service started.
7/23/21 13:15:58 historyLog: Last log entry 07/23/21 13:15:00
