Hi, got my first IotaWatt yesterday - I’m loving the concept but I think I might have a slightly defective unit.
On first setup, I got it connected and booted up fine, wifi configured and connected but on the next restart I got a GRR. Took the sdcard out, it reads fine in my laptop, plugged everything back in - still GRR and I could see it connect not as “IotaWatt” but as “ESP-C1D998” but same IP as previously.
Took the card out again to check the logs a little more carefully, but couldn’t see anything obvious. I decided to try once more making sure the card was seated fully (I have no reason to think it wasn’t earlier but I know this time I did).
This time it booted up to green, and I finished the config (set TZ and update more to NONE for now) and I could get started connecting CTs - after a couple fun hours of this and playing around with the app/graphs/outputs, I went to bed.
This morning, the unit was still showing readings on the status page, but I could no longer move around to other scenes, graphs and file readers etc - everything reported as url not found. I did a restart from the web interface and it came back GRR again and I have not been able to get it running.
Please let me know if there is anything I can provide from the logs that would help you.
Actually let me paste in the bottom of the log for now:
5/04/21 17:58:26z Real Time Clock is running. Unix time 1620151106
5/04/21 17:58:26z Power failure detected.
5/04/21 17:58:26z Reset reason: External System
5/04/21 17:58:26z ESP8266 ChipID: 12704152
5/04/21 17:58:26z IoTaWatt 5.0, Firmware version 02_06_02
5/04/21 17:58:26z SPIFFS mounted.
5/04/21 17:58:26z Local time zone: +0:00
5/04/21 17:58:26z device name: IotaWatt
5/04/21 17:58:29z Connecting with WiFiManager.
5/04/21 17:58:32z HTTP server started
5/04/21 17:58:32z WiFi connected. SSID=xxxx, IP=192.168.xxxx, channel=7, RSSI -48db
5/04/21 17:58:32z MDNS responder started for hostname IotaWatt
5/04/21 17:58:32z LLMNR responder started for hostname IotaWatt
5/04/21 17:58:35z timeSync: service started.
5/04/21 17:58:35z statService: started.
5/04/21 17:58:35z Updater: service started. Auto-update class is MINOR
5/04/21 17:58:35z dataLog: service started.
5/04/21 17:58:35z dataLog: Last log entry 05/04/21 15:21:05
5/04/21 17:58:36z Updater: Auto-update is current for class MINOR.
5/04/21 17:58:41z historyLog: service started.
5/04/21 17:58:41z historyLog: first entry 05/04/21 15:21:00
5/04/21 15:24:31 Updater: Auto-update class changed to NONE
5/05/21 01:14:07z Real Time Clock is running. Unix time 1620177247
5/05/21 01:14:07z Power failure detected.
5/05/21 01:14:07z Reset reason: External System
5/05/21 01:14:07z ESP8266 ChipID: 12704152
5/05/21 01:14:07z IoTaWatt 5.0, Firmware version 02_06_02
5/05/21 01:14:07z SPIFFS mounted.
5/04/21 22:14:07 Local time zone: -4:00
5/04/21 22:14:07 Using Daylight Saving Time (BST) when in effect.
5/04/21 22:14:07 device name: IotaWatt
5/04/21 22:14:10 Connecting with WiFiManager.
5/04/21 22:14:19 HTTP server started
5/04/21 22:14:19 WiFi connected. SSID=xxxx, IP=192.168.xxxx, channel=7, RSSI -64db
5/04/21 22:14:19 MDNS responder started for hostname IotaWatt
5/04/21 22:14:19 LLMNR responder started for hostname IotaWatt
5/04/21 22:14:19 timeSync: service started.
5/04/21 22:14:19 statService: started.
5/04/21 22:14:19 Updater: service started. Auto-update class is NONE
5/04/21 22:14:19 dataLog: service started.
5/04/21 22:14:19 dataLog: Last log entry 05/04/21 22:12:30
5/04/21 22:14:19 historyLog: service started.
5/04/21 22:14:19 historyLog: Last log entry 05/04/21 22:12:00
5/05/21 01:22:29z Updater: Auto-update class changed to MINOR
5/05/21 01:22:30z Updater: Auto-update is current for class MINOR.
