Hi Bob,
do you have a clue why this Iotawatt (alpha version) has not recorded any readings since April 6? Today I tried to access it, at first there was no reaction, when I tried it again later it was accessible again and has been recording values again since then.
Edit1: It is possible that I accidentally rebooted the iotawatt just as I was checking to see why it was not running, or that the power plug was not plugged in correctly, and it may have actually just been off.
Edit2: Just checked the plug, it sits firmly in the socket, so it is unlikely that it was actually off.
4/05/20 03:42:38z Real Time Clock is running. Unix time 1586058158
4/05/20 03:42:38z Reset reason: Software/System restart
4/05/20 03:42:38z Trace: 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/05/20 03:42:38z ESP8266 ChipID: 7283597
4/05/20 03:42:38z IoTaWatt 4.x, Firmware version 02_05_07
4/05/20 03:42:38z SPIFFS mounted.
4/05/20 03:42:39z Local time zone: +0:00
4/05/20 03:42:39z device name: IotaWatt
4/05/20 03:42:39z HTTP server started
4/05/20 03:42:39z timeSync: service started.
4/05/20 03:42:39z statService: started.
4/05/20 03:42:39z dataLog: service started.
4/05/20 03:42:41z dataLog: Last log entry 04/05/20 03:42:35
4/05/20 03:42:41z historyLog: service started.
4/05/20 03:42:42z historyLog: Last log entry 04/05/20 03:42:00
4/05/20 03:42:44z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/05/20 04:00:15z WiFi connected. SSID=Keks, IP=192.168.11.117, channel=6, RSSI -70db
4/05/20 04:00:15z MDNS responder started for hostname IotaWatt
4/05/20 04:00:15z LLMNR responder started for hostname IotaWatt
4/05/20 04:00:15z Updater: service started. Auto-update class is ALPHA
4/05/20 04:00:16z EmonService: Start posting at 04/04/20 23:41:10
4/05/20 04:00:16z Updater: Auto-update is current for class ALPHA.
4/05/20 21:00:04z WiFi disconnected.
4/05/20 22:00:05z WiFi disconnected more than 60 minutes, restarting.
4/05/20 22:00:08z Real Time Clock is running. Unix time 1586124008
4/05/20 22:00:08z Reset reason: Software/System restart
4/05/20 22:00:08z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/05/20 22:00:08z ESP8266 ChipID: 7283597
4/05/20 22:00:08z IoTaWatt 4.x, Firmware version 02_05_07
4/05/20 22:00:08z SPIFFS mounted.
4/05/20 22:00:09z Local time zone: +0:00
4/05/20 22:00:09z device name: IotaWatt
4/05/20 22:00:09z HTTP server started
4/05/20 22:00:09z timeSync: service started.
4/05/20 22:00:09z statService: started.
4/05/20 22:00:09z dataLog: service started.
4/05/20 22:00:11z dataLog: Last log entry 04/05/20 22:00:05
4/05/20 22:00:11z historyLog: service started.
4/05/20 22:00:12z historyLog: Last log entry 04/05/20 22:00:00
4/05/20 22:00:14z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/05/20 23:00:10z WiFi disconnected more than 60 minutes, restarting.
4/05/20 23:00:11z Real Time Clock is running. Unix time 1586127611
4/05/20 23:00:11z Reset reason: Software/System restart
4/05/20 23:00:11z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/05/20 23:00:11z ESP8266 ChipID: 7283597
4/05/20 23:00:11z IoTaWatt 4.x, Firmware version 02_05_07
4/05/20 23:00:11z SPIFFS mounted.
4/05/20 23:00:12z Local time zone: +0:00
4/05/20 23:00:12z device name: IotaWatt
4/05/20 23:00:12z HTTP server started
4/05/20 23:00:12z timeSync: service started.
4/05/20 23:00:12z statService: started.
4/05/20 23:00:12z dataLog: service started.
4/05/20 23:00:14z dataLog: Last log entry 04/05/20 23:00:10
4/05/20 23:00:14z historyLog: service started.
4/05/20 23:00:15z historyLog: Last log entry 04/05/20 23:00:00
4/05/20 23:00:17z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/06/20 00:00:13z WiFi disconnected more than 60 minutes, restarting.
4/06/20 00:00:14z Real Time Clock is running. Unix time 1586131214
4/06/20 00:00:14z Reset reason: Software/System restart
4/06/20 00:00:14z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/06/20 00:00:14z ESP8266 ChipID: 7283597
4/06/20 00:00:14z IoTaWatt 4.x, Firmware version 02_05_07
4/06/20 00:00:14z SPIFFS mounted.
4/06/20 00:00:15z Local time zone: +0:00
4/06/20 00:00:15z device name: IotaWatt
4/06/20 00:00:15z HTTP server started
4/06/20 00:00:15z timeSync: service started.
4/06/20 00:00:15z statService: started.
4/06/20 00:00:15z dataLog: service started.
4/06/20 00:00:17z dataLog: Last log entry 04/06/20 00:00:10
4/06/20 00:00:17z historyLog: service started.
4/06/20 00:00:18z historyLog: Last log entry 04/06/20 00:00:00
4/06/20 00:00:20z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/06/20 01:00:16z WiFi disconnected more than 60 minutes, restarting.
4/06/20 01:00:17z Real Time Clock is running. Unix time 1586134817
4/06/20 01:00:17z Reset reason: Software/System restart
4/06/20 01:00:17z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/06/20 01:00:17z ESP8266 ChipID: 7283597
4/06/20 01:00:17z IoTaWatt 4.x, Firmware version 02_05_07
4/06/20 01:00:17z SPIFFS mounted.
4/06/20 01:00:18z Local time zone: +0:00
4/06/20 01:00:18z device name: IotaWatt
4/06/20 01:00:18z HTTP server started
4/06/20 01:00:18z timeSync: service started.
4/06/20 01:00:18z statService: started.
4/06/20 01:00:18z dataLog: service started.
4/06/20 01:00:20z dataLog: Last log entry 04/06/20 01:00:15
4/06/20 01:00:20z historyLog: service started.
4/06/20 01:00:21z historyLog: Last log entry 04/06/20 01:00:00
4/06/20 01:00:23z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/06/20 02:00:19z WiFi disconnected more than 60 minutes, restarting.
4/06/20 02:00:21z Real Time Clock is running. Unix time 1586138421
4/06/20 02:00:21z Reset reason: Software/System restart
4/06/20 02:00:21z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/06/20 02:00:21z ESP8266 ChipID: 7283597
4/06/20 02:00:21z IoTaWatt 4.x, Firmware version 02_05_07
4/06/20 02:00:21z SPIFFS mounted.
4/06/20 02:00:22z Local time zone: +0:00
4/06/20 02:00:22z device name: IotaWatt
4/06/20 02:00:22z HTTP server started
4/06/20 02:00:22z timeSync: service started.
4/06/20 02:00:22z statService: started.
4/06/20 02:00:22z dataLog: service started.
4/06/20 02:00:24z dataLog: Last log entry 04/06/20 02:00:15
4/06/20 02:00:24z historyLog: service started.
4/06/20 02:00:25z historyLog: Last log entry 04/06/20 02:00:00
4/06/20 02:00:27z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/06/20 03:00:23z WiFi disconnected more than 60 minutes, restarting.
4/06/20 03:00:24z Real Time Clock is running. Unix time 1586142024
4/06/20 03:00:24z Reset reason: Software/System restart
4/06/20 03:00:24z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:2
4/06/20 03:00:24z ESP8266 ChipID: 7283597
4/06/20 03:00:24z IoTaWatt 4.x, Firmware version 02_05_07
4/06/20 03:00:24z SPIFFS mounted.
4/06/20 03:00:25z Local time zone: +0:00
4/06/20 03:00:25z device name: IotaWatt
4/06/20 03:00:25z HTTP server started
4/06/20 03:00:25z timeSync: service started.
4/06/20 03:00:25z statService: started.
4/06/20 03:00:25z dataLog: service started.
4/06/20 03:00:27z dataLog: Last log entry 04/06/20 03:00:20
4/06/20 03:00:27z historyLog: service started.
4/06/20 03:00:28z historyLog: Last log entry 04/06/20 03:00:00
4/06/20 03:00:30z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/06/20 04:00:13z WiFi connected. SSID=Keks, IP=192.168.11.117, channel=6, RSSI -77db
4/06/20 04:00:13z MDNS responder started for hostname IotaWatt
4/06/20 04:00:13z LLMNR responder started for hostname IotaWatt
4/06/20 04:00:13z Updater: service started. Auto-update class is ALPHA
4/06/20 04:00:14z EmonService: Start posting at 04/05/20 20:58:40
4/06/20 04:00:15z Updater: Auto-update is current for class ALPHA.
4/15/20 20:08:38z Real Time Clock is running. Unix time 1586981318
4/15/20 20:08:38z Power failure detected.
4/15/20 20:08:38z Reset reason: External System
4/15/20 20:08:38z ESP8266 ChipID: 7283597
4/15/20 20:08:38z IoTaWatt 4.x, Firmware version 02_05_07
4/15/20 20:08:38z SPIFFS mounted.
4/15/20 20:08:38z Local time zone: +0:00
4/15/20 20:08:38z device name: IotaWatt
4/15/20 20:08:41z HTTP server started
4/15/20 20:08:42z WiFi connected. SSID=Keks, IP=192.168.11.117, channel=6, RSSI -72db
4/15/20 20:08:42z MDNS responder started for hostname IotaWatt
4/15/20 20:08:42z LLMNR responder started for hostname IotaWatt
4/15/20 20:08:42z timeSync: service started.
4/15/20 20:08:42z statService: started.
4/15/20 20:08:42z Updater: service started. Auto-update class is ALPHA
4/15/20 20:08:43z dataLog: service started.
4/15/20 20:08:44z dataLog: Last log entry 04/06/20 11:46:40
4/15/20 20:08:44z historyLog: service started.
4/15/20 20:08:45z historyLog: Last log entry 04/06/20 11:46:00
4/15/20 20:08:46z Updater: Auto-update is current for class ALPHA.
4/15/20 20:08:47z EmonService: started. url=HTTP://my.rexometer.de, node=IotaWatt, interval=10, encrypted
4/15/20 20:08:48z EmonService: Start posting at 04/06/20 11:45:30
