Real Time Clock not running.
Reset reason: Software/System restart
Trace: 139:3[140], 254:151[251], 224:47[92], 53:5[60], 225:98[50], 225:53[145], 146:197[157], 185:113[147], 8:11[89], 210:128[115], 120:147[6], 144:167[41], 142:20[59], 80:48[47], 229:35[231], 252:5[145], 78:136[222], 112:233[49], 160:25[252], 132:180[35], 248:118[176], 165:83[14], 46:145[80], 200:73[86], 77:29[65], 250:4[168], 10:233[94], 176:145[150], 58:79[71], 62:114[150], 179:210[96], 237:93[222]
ESP8266 ID: 14638527, RTC PCF8523 (68)
IoTaWatt 5.0, Firmware version 02_08_02
SPIFFS mounted.
Local time zone: +0:00
device name: IotaWatt
Connecting with WiFiManager.
Reset reason: Power on
Trace: 203:2[28], 254:131[251], 192:43[28], 53:7[60], 225:98[50], 225:55[145], 138:133[141], 185:97[177], 24:11[81], 210:193[119], 120:163[38], 144:183[41], 142:20[59], 80:16[47], 229:35[231], 252:7[145], 76:136[222], 112:249[57], 162:25[252], 132:60[35], 216:118[176], 160:83[28], 62:193[64], 200:77[95], 77:59[64], 248:20[232], 10:233[94], 176:146[151], 50:78[71], 62:242[214], 179:210[96], 237:125[222]
SPIFFS mounted.
HTTP server started
WiFi connected. SSID=LeeBaeCraigLane, IP=192.168.7.245, channel=5, RSSI -71db
timeSync: service started.
statService: started.
5/05/23 00:47:05z timeSync: RTC initalized to NTP time
5/05/23 00:47:05z dataLog: service started.
5/05/23 00:47:05z dataLog: New current log created.
5/05/23 00:47:08z Updater: Auto-update is current for class MINOR.
5/05/23 00:48:10z historyLog: service started.
5/05/23 00:48:10z historyLog: first entry 05/05/23 00:48:00
5/04/23 22:00:54 Updater: Auto-update class changed to MAJOR
5/04/23 22:00:55 Updater: Update from 02_08_02 to 02_07_05
5/04/23 22:00:55 Updater: download 02_07_05
5/04/23 22:00:59 Updater: Release downloaded 4194ms, size 951104
5/04/23 22:01:06 Updater: signature verified
5/04/23 22:01:14 Updater: firmware upgraded to version 02_07_05
5/04/23 22:01:14 Updater: Firmware updated, restarting.
5/05/23 01:01:23z Real Time Clock is running. Unix time 1683248483
5/05/23 01:01:23z Reset reason: Software/System restart
5/05/23 01:01:23z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:20, 21:21, 21:30, 21:99, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
5/05/23 01:01:23z ESP8266 ID: 14638527, RTC PCF8523 (68)
5/05/23 01:01:23z IoTaWatt 5.0, Firmware version 02_07_05
5/05/23 01:01:23z Updater: Installing update files for version 02_07_05
5/05/23 01:01:23z Updater: Installing GRAPH.HTM
5/05/23 01:01:23z Updater: Installing GRAPH.JS
5/05/23 01:01:23z Updater: Installing GRAPH2.HTM
5/05/23 01:01:23z Updater: Installing GRAPH2.JS
5/05/23 01:01:23z Updater: Installing INDEX.HTM
5/05/23 01:01:24z Updater: Installing TABLES.TXT
5/05/23 01:01:24z Updater: Installing CNFSTYLE.CSS
5/05/23 01:01:24z Updater: Installing EDIT.HTM
5/05/23 01:01:24z Updater: Installing FAVICON.ICO
5/05/23 01:01:24z Updater: Installation complete.
5/05/23 01:01:25z SPIFFS mounted.
5/04/23 22:01:25 Local time zone: -4:00, using DST/BST when in effect.
5/04/23 22:01:25 device name: IotaWatt
5/04/23 22:01:25 HTTP server started
5/04/23 22:01:25 timeSync: service started.
5/04/23 22:01:25 statService: started.
5/04/23 22:01:25 dataLog: service started.
5/04/23 22:01:25 dataLog: Last log entry 05/04/23 22:00:55
5/04/23 22:01:25 historyLog: service started.
5/04/23 22:01:25 historyLog: Last log entry 05/04/23 22:00:00
5/04/23 22:01:30 WiFi connected. SSID=LeeBaeCraigLane, IP=192.168.7.245, channel=5, RSSI -61db
5/04/23 22:01:30 MDNS responder started for hostname IotaWatt
5/04/23 22:01:30 LLMNR responder started for hostname IotaWatt
5/04/23 22:01:30 Updater: service started. Auto-update class is MAJOR
5/04/23 22:01:31 Updater: Auto-update is current for class MAJOR.
5/04/23 22:01:31 Updater: update tables from 0.0.4 to 0.0.7
5/05/23 22:36:47 Updater: Auto-update class changed to MINOR
5/05/23 22:36:48 Updater: Update from 02_07_05 to 02_08_02
5/05/23 22:36:48 Updater: download 02_08_02
5/05/23 22:36:52 Updater: Release downloaded 4121ms, size 964192
5/05/23 22:36:59 Updater: signature verified
5/05/23 22:37:08 Updater: firmware upgraded to version 02_08_02
5/05/23 22:37:08 Updater: Firmware updated, restarting.
5/06/23 01:37:19z Real Time Clock is running. Unix time 1683337039
5/06/23 01:37:19z Reset reason: Software/System restart
5/06/23 01:37:19z Trace: 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:20, 21:21, 21:30, 21:99, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
5/06/23 01:37:19z ESP8266 ID: 14638527, RTC PCF8523 (68)
5/06/23 01:37:19z IoTaWatt 5.0, Firmware version 02_08_02
5/06/23 01:37:19z Updater: Installing update files for version 02_08_02
5/06/23 01:37:19z Updater: Installing EDIT.HTM
5/06/23 01:37:19z Updater: Installing FAVICON.ICO
5/06/23 01:37:19z Updater: Installing GRAPH.HTM
5/06/23 01:37:19z Updater: Installing GRAPH.JS
5/06/23 01:37:19z Updater: Installing GRAPH2.HTM
5/06/23 01:37:19z Updater: Installing GRAPH2.JS
5/06/23 01:37:20z Updater: Installing INDEX.HTM
5/06/23 01:37:20z Updater: Installing TABLES.TXT
5/06/23 01:37:20z Updater: Installing CNFSTYLE.CSS
5/06/23 01:37:20z Updater: Installation complete.
5/06/23 01:37:21z SPIFFS mounted.
5/05/23 22:37:21 Local time zone: -4:00, using DST/BST when in effect.
5/05/23 22:37:21 device name: IotaWatt
5/05/23 22:37:21 HTTP server started
5/05/23 22:37:21 timeSync: service started.
5/05/23 22:37:21 statService: started.
5/05/23 22:37:21 dataLog: service started.
5/05/23 22:37:21 dataLog: Last log entry 05/05/23 22:36:50
5/05/23 22:37:26 historyLog: service started.
5/05/23 22:37:26 historyLog: Last log entry 05/05/23 22:36:00
5/05/23 22:37:26 WiFi connected. SSID=LeeBaeCraigLane, IP=192.168.7.245, channel=5, RSSI -60db
5/05/23 22:37:26 Updater: service started. Auto-update class is MINOR
5/05/23 22:37:27 Updater: Auto-update is current for class MINOR.
5/05/23 22:41:09 grid: Started
5/05/23 22:41:09 grid: New log starting 05/04/23 22:41:05
5/06/23 08:45:19 PVoutput: started
5/06/23 08:45:19 PVoutput: System BlueMarblePA-Haverford, interval 5, freeload mode
5/06/23 08:45:19 PVoutput: Start status beginning 05/05/23 00:05:00
5/06/23 10:34:25 WiFi disconnected.
5/06/23 10:35:32 WiFi connected. SSID=LeeBaeCraigLane, IP=192.168.7.245, channel=5, RSSI -68db
