It’s possible I cleared the log on that day while troubleshooting, I don’t remember. Here’s the log, there is nothing newer than this:
2/06/23 17:11:16z Real Time Clock is running. Unix time 1675703476
2/06/23 17:11:16z Reset Reason: Power-fail restart.
2/06/23 17:11:16z ESP8266 ID: 14622328, RTC PCF8523 (68)
2/06/23 17:11:16z IoTaWatt 5.0, Firmware version 02_07_05
2/06/23 17:11:16z SPIFFS mounted.
2/06/23 09:11:16 Local time zone: -8:00, using DST/BST when in effect.
2/06/23 09:11:16 device name: IotaWatt
2/06/23 09:11:19 HTTP server started
2/06/23 09:11:19 WiFi connected. SSID=IoT, IP=192.168.20.32, channel=1, RSSI -74db
2/06/23 09:11:19 MDNS responder started for hostname IotaWatt
2/06/23 09:11:19 LLMNR responder started for hostname IotaWatt
2/06/23 09:11:19 timeSync: service started.
2/06/23 09:11:19 statService: started.
2/06/23 09:11:19 Updater: service started. Auto-update class is MINOR
2/06/23 09:11:19 dataLog: service started.
2/06/23 09:11:19 dataLog: Last log entry 02/06/23 09:11:05
2/06/23 09:11:23 Updater: Auto-update is current for class MINOR.
2/06/23 09:11:24 historyLog: service started.
2/06/23 09:11:24 historyLog: Last log entry 02/06/23 09:11:00
2/06/23 09:11:24 Grid: Started
2/06/23 09:11:24 Grid: Last log entry 02/06/23 09:11:05
2/06/23 09:11:29 PVoutput: started
2/06/23 09:11:29 PVoutput: System desert-llama, interval 5, freeload mode
2/06/23 09:11:29 PVoutput: Start status beginning 02/06/23 09:10:00
2/06/23 09:15:19 deletelog=both command received.
2/06/23 17:15:21z Real Time Clock is running. Unix time 1675703721
2/06/23 17:15:21z Reset reason: Software/System restart
2/06/23 17:15:21z Trace: 1:2, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:21, 10:23
2/06/23 17:15:21z ESP8266 ID: 14622328, RTC PCF8523 (68)
2/06/23 17:15:21z IoTaWatt 5.0, Firmware version 02_07_05
2/06/23 17:15:21z SPIFFS mounted.
2/06/23 09:15:21 Local time zone: -8:00, using DST/BST when in effect.
2/06/23 09:15:21 device name: IotaWatt
2/06/23 09:15:21 HTTP server started
2/06/23 09:15:21 timeSync: service started.
2/06/23 09:15:21 statService: started.
2/06/23 09:15:21 dataLog: service started.
2/06/23 09:15:21 dataLog: New current log created.
2/06/23 09:15:26 Grid: Started
2/06/23 09:15:26 Grid: Last log entry 02/06/23 09:15:15
2/06/23 09:15:31 PVoutput: started
2/06/23 09:15:31 WiFi connected. SSID=IoT, IP=192.168.20.32, channel=1, RSSI -75db
2/06/23 09:15:31 MDNS responder started for hostname IotaWatt
2/06/23 09:15:31 LLMNR responder started for hostname IotaWatt
2/06/23 09:15:31 Updater: service started. Auto-update class is MINOR
2/06/23 09:15:32 PVoutput: System desert-llama, interval 5, freeload mode
2/06/23 09:15:34 Updater: Auto-update is current for class MINOR.
2/06/23 09:15:34 PVoutput: Start status beginning 02/05/06 22:35:00
2/06/23 09:16:28 historyLog: service started.
2/06/23 09:16:28 historyLog: first entry 02/06/23 09:16:00
2/06/23 20:34:05z Real Time Clock is running. Unix time 1675715645
2/06/23 20:34:05z Reset Reason: Power-fail restart.
2/06/23 20:34:05z ESP8266 ID: 14622328, RTC PCF8523 (68)
2/06/23 20:34:05z IoTaWatt 5.0, Firmware version 02_07_05
2/06/23 20:34:05z SPIFFS mounted.
2/06/23 12:34:05 Local time zone: -8:00, using DST/BST when in effect.
2/06/23 12:34:05 device name: IotaWatt
2/06/23 12:34:08 HTTP server started
2/06/23 12:34:08 WiFi connected. SSID=IoT, IP=192.168.20.32, channel=1, RSSI -75db
2/06/23 12:34:08 MDNS responder started for hostname IotaWatt
2/06/23 12:34:08 LLMNR responder started for hostname IotaWatt
2/06/23 12:34:08 timeSync: service started.
2/06/23 12:34:08 statService: started.
2/06/23 12:34:08 Updater: service started. Auto-update class is MINOR
2/06/23 12:34:08 dataLog: service started.
2/06/23 12:34:08 dataLog: Last log entry 02/06/23 12:33:50
2/06/23 12:34:10 Updater: Auto-update is current for class MINOR.
2/06/23 12:34:13 historyLog: service started.
2/06/23 12:34:13 historyLog: Last log entry 02/06/23 12:33:00
2/06/23 12:34:13 Grid: Started
2/06/23 12:34:13 Grid: Last log entry 02/06/23 12:33:45
2/06/23 12:34:18 PVoutput: started
2/06/23 12:34:18 PVoutput: System desert-llama, interval 5, freeload mode
2/06/23 12:34:18 PVoutput: Start status beginning 02/06/23 09:25:00
I just recreated the integrator and now it’s showing zero for both import and export, even on the status page.
