Problems with IotaWatt, appears to lose Wifi
Hi,
Purchased IotaWatt about 6 weeks ago and have been waiting for some renovations to install properly.
I have a metal meter box which it is currently sitting in. I originally was using my home router, but have a second wireless router within a few meters of it so I thought I would use that to improve signal and reduce any losses.
I’m not sure if the wireless is dropping out or it is freezing, but it seems to stop transmitting and cannot be pinged on network after a while.
From the log I can get this (note I changed from WWorld3 to WWorld1 router after a few runs). The power failures seem to coincide with when I turn off/on after it loses signal.
Is there something else I should be looking for? note I have setup a plastic enclosure next to the meter box and when eleco is here next I will get the CT’s run to it and have the IotaWatt box there, but wanted to see if there was anything else I could do to troubleshoot prior to him coming. Any other logs?
Blockquote
10/13/20 23:58:12 WiFi connected. SSID=WWorld3, IP=192.168.0.226, channel=6, RSSI -79db
10/13/20 23:58:12 MDNS responder started for hostname IotaWatt
10/13/20 23:58:12 LLMNR responder started for hostname IotaWatt
10/13/20 23:58:12 Updater: service started. Auto-update class is MINOR
10/13/20 23:58:13 Updater: Auto-update is current for class MINOR.
10/13/20 23:59:08 historyLog: service started.
10/13/20 23:59:08 historyLog: Last log entry 10/13/20 23:57:00
10/13/20 22:10:26z Real Time Clock is running. Unix time 1602627026
10/13/20 22:10:26z Power failure detected.
10/13/20 22:10:26z Reset reason: Power on
10/13/20 22:10:26z ESP8266 ChipID: 6147812
10/13/20 22:10:26z IoTaWatt 5.0, Firmware version 02_05_09
10/13/20 22:10:26z SPIFFS mounted.
10/14/20 09:10:26 Local time zone: +10:00
10/14/20 09:10:26 Using Daylight Saving Time (BST) when in effect.
10/14/20 09:10:26 device name: IotaWatt
10/14/20 09:10:29 Connecting with WiFiManager.
10/14/20 09:10:38 HTTP server started
10/14/20 09:10:38 WiFi connected. SSID=WWorld3, IP=192.168.0.226, channel=6, RSSI -78db
10/14/20 09:10:38 MDNS responder started for hostname IotaWatt
10/14/20 09:10:38 LLMNR responder started for hostname IotaWatt
10/14/20 09:10:38 timeSync: service started.
10/14/20 09:10:38 statService: started.
10/14/20 09:10:38 Updater: service started. Auto-update class is MINOR
10/14/20 09:10:38 dataLog: service started.
10/14/20 09:10:38 dataLog: Last log entry 10/14/20 09:10:20
10/14/20 09:10:39 Updater: Auto-update is current for class MINOR.
10/13/20 22:17:24z Real Time Clock is running. Unix time 1602627444
10/13/20 22:17:24z Power failure detected.
10/13/20 22:17:24z Reset reason: Power on
10/13/20 22:17:24z ESP8266 ChipID: 6147812
10/13/20 22:17:24z IoTaWatt 5.0, Firmware version 02_05_09
10/13/20 22:17:24z SPIFFS mounted.
10/14/20 09:17:24 Local time zone: +10:00
10/14/20 09:17:24 Using Daylight Saving Time (BST) when in effect.
10/14/20 09:17:24 device name: IotaWatt
10/14/20 09:17:27 HTTP server started
10/14/20 09:17:27 WiFi connected. SSID=WWorld3, IP=192.168.0.226, channel=6, RSSI -65db
10/14/20 09:17:27 MDNS responder started for hostname IotaWatt
10/14/20 09:17:27 LLMNR responder started for hostname IotaWatt
10/14/20 09:17:27 timeSync: service started.
10/14/20 09:17:27 statService: started.
10/14/20 09:17:27 Updater: service started. Auto-update class is MINOR
10/14/20 09:17:27 dataLog: service started.
10/14/20 09:17:27 dataLog: Last log entry 10/14/20 09:11:20
10/14/20 09:17:29 Updater: Auto-update is current for class MINOR.
10/14/20 09:18:27 historyLog: service started.
10/14/20 09:18:27 historyLog: Last log entry 10/14/20 09:10:00
10/14/20 09:24:35 Disconnect command received.
10/14/20 09:24:36 WiFi disconnected.
10/13/20 22:35:26z Real Time Clock is running. Unix time 1602628526
10/13/20 22:35:26z Power failure detected.
10/13/20 22:35:26z Reset reason: Power on
10/13/20 22:35:26z ESP8266 ChipID: 6147812
10/13/20 22:35:26z IoTaWatt 5.0, Firmware version 02_05_09
10/13/20 22:35:26z SPIFFS mounted.
10/14/20 09:35:26 Local time zone: +10:00
10/14/20 09:35:26 Using Daylight Saving Time (BST) when in effect.
10/14/20 09:35:26 device name: IotaWatt
10/14/20 09:35:29 Connecting with WiFiManager.
10/14/20 09:36:18 HTTP server started
10/14/20 09:36:18 WiFi connected. SSID=WWorld1, IP=192.168.0.226, channel=11, RSSI -71db
10/14/20 09:36:18 MDNS responder started for hostname IotaWatt
10/14/20 09:36:18 LLMNR responder started for hostname IotaWatt
10/14/20 09:36:18 timeSync: service started.
10/14/20 09:36:18 statService: started.
10/14/20 09:36:18 Updater: service started. Auto-update class is MINOR
10/14/20 09:36:18 dataLog: service started.
10/14/20 09:36:18 dataLog: Last log entry 10/14/20 09:35:10
10/14/20 09:36:19 Updater: Auto-update is current for class MINOR.
10/14/20 09:37:18 historyLog: service started.
10/14/20 09:37:18 historyLog: Last log entry 10/14/20 09:35:00
10/13/20 23:36:23z Real Time Clock is running. Unix time 1602632183
10/13/20 23:36:23z Power failure detected.
10/13/20 23:36:23z Reset reason: Power on
10/13/20 23:36:23z ESP8266 ChipID: 6147812
10/13/20 23:36:23z IoTaWatt 5.0, Firmware version 02_05_09
10/13/20 23:36:23z SPIFFS mounted.
10/14/20 10:36:23 Local time zone: +10:00
10/14/20 10:36:23 Using Daylight Saving Time (BST) when in effect.
10/14/20 10:36:23 device name: IotaWatt
10/14/20 10:36:26 Connecting with WiFiManager.
10/14/20 10:36:29 HTTP server started
10/14/20 10:36:29 WiFi connected. SSID=WWorld1, IP=192.168.0.226, channel=11, RSSI -85db
10/14/20 10:36:29 MDNS responder started for hostname IotaWatt
10/14/20 10:36:29 LLMNR responder started for hostname IotaWatt
10/14/20 10:36:29 timeSync: service started.
10/14/20 10:36:30 statService: started.
10/14/20 10:36:30 Updater: service started. Auto-update class is MINOR
10/14/20 10:36:30 dataLog: service started.
10/14/20 10:36:30 dataLog: Last log entry 10/14/20 10:34:25
10/14/20 10:36:31 Updater: Auto-update is current for class MINOR.
10/14/20 10:37:30 historyLog: service started.
10/14/20 10:37:30 historyLog: Last log entry 10/14/20 10:34:00
10/14/20 13:36:54 Updater: Update from 02_05_09 to 02_05_11
10/14/20 13:36:54 Updater: download 02_05_11
10/14/20 13:37:07 Updater: Release downloaded 12969ms, size 813168
10/14/20 13:37:34 Updater: signature verified
10/14/20 13:37:42 Updater: firmware upgraded to version 02_05_11
10/14/20 13:37:42 Updater: Firmware updated, restarting.
10/14/20 02:37:51z Real Time Clock is running. Unix time 1602643071
10/14/20 02:37:51z Reset reason: Software/System restart
10/14/20 02:37:51z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[14], 14:0, 14:4, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:7
10/14/20 02:37:51z ESP8266 ChipID: 6147812
10/14/20 02:37:51z IoTaWatt 5.0, Firmware version 02_05_11
10/14/20 02:37:51z Updater: Installing update files for version 02_05_11
10/14/20 02:37:51z Updater: Installing GRAPH.HTM
10/14/20 02:37:51z Updater: Installing GRAPH.JS
10/14/20 02:37:51z Updater: Installing GRAPH2.HTM
10/14/20 02:37:51z Updater: Installing GRAPH2.JS
10/14/20 02:37:52z Updater: Installing INDEX.HTM
10/14/20 02:37:53z Updater: Installing TABLES.TXT
10/14/20 02:37:53z Updater: Installing CNFSTYLE.CSS
10/14/20 02:37:53z Updater: Installing EDIT.HTM
10/14/20 02:37:53z Updater: Installation complete.
10/14/20 02:37:53z SPIFFS mounted.
10/14/20 13:37:54 Local time zone: +10:00
10/14/20 13:37:54 Using Daylight Saving Time (BST) when in effect.
10/14/20 13:37:54 device name: IotaWatt
10/14/20 13:37:54 HTTP server started
10/14/20 13:37:54 timeSync: service started.
10/14/20 13:37:54 statService: started.
10/14/20 13:37:54 dataLog: service started.
10/14/20 13:37:54 dataLog: Last log entry 10/14/20 13:36:55
10/14/20 13:37:58 WiFi connected. SSID=WWorld1, IP=192.168.0.226, channel=11, RSSI -85db
10/14/20 13:37:58 MDNS responder started for hostname IotaWatt
10/14/20 13:37:58 LLMNR responder started for hostname IotaWatt
10/14/20 13:37:58 Updater: service started. Auto-update class is MINOR
10/14/20 13:37:59 Updater: Auto-update is current for class MINOR.
10/14/20 13:38:55 historyLog: service started.
10/14/20 13:38:55 historyLog: Last log entry 10/14/20 13:36:00
10/14/20 03:45:45z Real Time Clock is running. Unix time 1602647145
10/14/20 03:45:45z Power failure detected.
10/14/20 03:45:45z Reset reason: Power on
10/14/20 03:45:45z ESP8266 ChipID: 6147812
10/14/20 03:45:45z IoTaWatt 5.0, Firmware version 02_05_11
10/14/20 03:45:45z SPIFFS mounted.
10/14/20 14:45:45 Local time zone: +10:00
10/14/20 14:45:45 Using Daylight Saving Time (BST) when in effect.
10/14/20 14:45:45 device name: IotaWatt
10/14/20 14:45:48 HTTP server started
10/14/20 14:45:48 WiFi connected. SSID=WWorld1, IP=192.168.0.226, channel=11, RSSI -86db
10/14/20 14:45:48 MDNS responder started for hostname IotaWatt
10/14/20 14:45:48 LLMNR responder started for hostname IotaWatt
10/14/20 14:45:48 timeSync: service started.
10/14/20 14:45:48 statService: started.
10/14/20 14:45:48 Updater: service started. Auto-update class is MINOR
10/14/20 14:45:48 dataLog: service started.
10/14/20 14:45:48 dataLog: Last log entry 10/14/20 14:45:35
10/14/20 14:45:49 Updater: Auto-update is current for class MINOR.
10/14/20 14:46:48 historyLog: service started.
10/14/20 14:46:48 historyLog: Last log entry 10/14/20 14:45:00
10/14/20 03:49:42z Real Time Clock is running. Unix time 1602647382
10/14/20 03:49:42z Power failure detected.
10/14/20 03:49:42z Reset reason: External System
10/14/20 03:49:42z ESP8266 ChipID: 6147812
10/14/20 03:49:42z IoTaWatt 5.0, Firmware version 02_05_11
10/14/20 03:49:42z SPIFFS mounted.
10/14/20 14:49:42 Local time zone: +10:00
10/14/20 14:49:42 Using Daylight Saving Time (BST) when in effect.
10/14/20 14:49:42 device name: IotaWatt
10/14/20 14:49:45 HTTP server started
10/14/20 14:49:45 WiFi connected. SSID=WWorld1, IP=192.168.0.226, channel=11, RSSI -88db
10/14/20 14:49:45 MDNS responder started for hostname IotaWatt
10/14/20 14:49:45 LLMNR responder started for hostname IotaWatt
10/14/20 14:49:45 timeSync: service started.
10/14/20 14:49:53 statService: started.
10/14/20 14:49:53 Updater: service started. Auto-update class is MINOR
10/14/20 14:49:53 dataLog: service started.
10/14/20 14:49:53 dataLog: Last log entry 10/14/20 14:49:20
10/14/20 14:49:54 Updater: Auto-update is current for class MINOR.
10/14/20 14:50:53 historyLog: service started.
10/14/20 14:50:53 historyLog: Last log entry 10/14/20 14:49:00
Blockquote
any help appreciated.
