@overeasy, I’m in the process of planning to re-IP my home network due to a few other issues my current IP scope has; long story. I had two quick questions below I was hoping you could thumbs up or let me know if you see any issues.
Current Setup:
- One IoTaWatt with a reserved DHCP IP (192.168.1.15)
- EmonCMS locally installed on a Raspberry Pi with a reserved DHCP (192.168.1.54)
- IP Scope changing from 192.168.1.x to 192.168.99.x
Questions:
Do you see any issues internally with the IoTaWatt when the scope changes and I reboot it to get the new IP address?
I do know I have to modify the EmonCMS (webserver) configuration on the IopTaWatt to the new ip as the the current is set for the IP (http://ip_address/api_call), but do you see anything else that may be impacted?
Or, if you can think of any other areas related to the IoTaWatt/EmonCMS when I flip the switch?
Thanks.
Quella
