This all started early this morning with data stopping at around 2:14am with the following message in the log.
11/02/22 02:14:21 dataLog: datalog WDT - restarting.
it did it again at 4:24am but no data was logged inbetween.
11/02/22 02:14:24 statService: started.
11/02/22 03:25:58 dataLog: service started.
11/02/22 03:25:58 dataLog: Last log entry 11/02/22 02:09:20
11/02/22 03:25:58 WiFi connected. SSID=WIFI, IP=192.168.1.98, channel=6, RSSI -68db
11/02/22 03:25:58 MDNS responder started for hostname IotaWatt
11/02/22 03:25:59 LLMNR responder started for hostname IotaWatt
11/02/22 03:25:59 Updater: service started. Auto-update class is NONE
11/02/22 03:25:59 historyLog: service started.
11/02/22 03:25:59 historyLog: Last log entry 11/02/22 02:09:00
11/02/22 04:42:39 dataLog: datalog WDT - restarting
Now all I get is the following in the log.
11/01/22 21:55:07z Real Time Clock is running. Unix time 1667339707
11/01/22 21:55:07z Reset reason: Exception
11/01/22 21:55:07z Trace: 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[2], 10:17, 31:110, 31:110, 10:17, 10:18, 10:23, 10:17
11/01/22 21:55:07z ESP8266 ID: 14663699, RTC PCF8523 (68)
11/01/22 21:55:07z IoTaWatt 5.0, Firmware version 02_07_05
11/01/22 21:55:07z SPIFFS mounted.
11/02/22 08:55:07 Local time zone: +10:00, using DST/BST when in effect.
11/02/22 08:55:07 device name: IotaWatt
11/02/22 08:55:07 HTTP server started
Steps taken so far :
Powered down and restarted. - no change
Removed and backed up the SD card. - no change
Tried reloading firmware ( version 02_07_05) - no change
What other information do you guys want to help me troubleshoot this ?
Anthony
UPDATE: After deleting all my Outputs and Intergrators I get the following.
Blockquote
11/01/22 22:52:16z Real Time Clock is running. Unix time 1667343136
11/01/22 22:52:16z Reset reason: Software/System restart
11/01/22 22:52:16z Trace: 1:2, 1:3, 1:3, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
11/01/22 22:52:16z ESP8266 ID: 14663699, RTC PCF8523 (68)
11/01/22 22:52:16z IoTaWatt 5.0, Firmware version 02_07_05
11/01/22 22:52:16z SPIFFS mounted.
11/02/22 09:52:16 Local time zone: +10:00, using DST/BST when in effect.
11/02/22 09:52:16 device name: IotaWatt
11/02/22 09:52:16 HTTP server started
11/02/22 09:52:16 timeSync: service started.
11/02/22 09:52:16 statService: started.
Blockquote
