All of a sudden I am seeing my IoTaWatt rebooting every few minutes. Here’s what the Message Log looks like:
3/15/21 08:29:34 historyLog: service started.
3/15/21 08:29:35 historyLog: Last log entry 03/15/21 08:28:00
3/15/21 08:29:43 PVoutput: started
3/15/21 08:30:01 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:30:29 PVoutput: Start status beginning 03/15/21 08:25:00
3/15/21 08:31:29 Heap memory has degraded below safe minimum, restarting.
3/15/21 12:31:30z Real Time Clock is running. Unix time 1615811490
3/15/21 12:31:30z Reset reason: Software/System restart
3/15/21 12:31:30z Trace: 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:5, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
3/15/21 12:31:30z ESP8266 ChipID: 6308187
3/15/21 12:31:30z IoTaWatt 5.0, Firmware version 02_05_12
3/15/21 12:31:30z SPIFFS mounted.
3/15/21 08:31:30 Local time zone: -5:00
3/15/21 08:31:31 Using Daylight Saving Time (BST) when in effect.
3/15/21 08:31:31 device name: IotaWatt
3/15/21 08:31:31 HTTP server started
3/15/21 08:31:31 timeSync: service started.
3/15/21 08:31:31 statService: started.
3/15/21 08:31:31 dataLog: service started.
3/15/21 08:31:34 dataLog: Last log entry 03/15/21 08:31:25
3/15/21 08:31:36 EmonService: started. url=HTTP://192.168.1.105:8081, node=IotaWatt, interval=10, encrypted
3/15/21 08:31:36 influxDB: started, url=HTTP://192.168.1.105:8086, db=iotawatt_db, interval=10
3/15/21 08:31:37 WiFi connected. SSID=Automation, IP=192.168.1.224, channel=11, RSSI -71db
3/15/21 08:31:37 MDNS responder started for hostname IotaWatt
3/15/21 08:31:37 LLMNR responder started for hostname IotaWatt
3/15/21 08:31:37 Updater: service started. Auto-update class is ALPHA
3/15/21 08:31:39 EmonService: Start posting at 03/15/21 08:31:20
3/15/21 08:31:44 Updater: Auto-update is current for class ALPHA.
3/15/21 08:32:32 historyLog: service started.
3/15/21 08:32:33 historyLog: Last log entry 03/15/21 08:31:00
3/15/21 08:32:41 PVoutput: started
3/15/21 08:32:49 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:33:06 PVoutput: Start status beginning 03/15/21 08:30:00
3/15/21 08:33:30 influxDB: Start posting at 03/15/21 08:27:30
3/15/21 08:34:12 Heap memory has degraded below safe minimum, restarting.
3/15/21 12:34:13z Real Time Clock is running. Unix time 1615811653
3/15/21 12:34:13z Reset reason: Software/System restart
3/15/21 12:34:13z Trace: 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:9, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
3/15/21 12:34:13z ESP8266 ChipID: 6308187
3/15/21 12:34:13z IoTaWatt 5.0, Firmware version 02_05_12
3/15/21 12:34:13z SPIFFS mounted.
3/15/21 08:34:13 Local time zone: -5:00
3/15/21 08:34:13 Using Daylight Saving Time (BST) when in effect.
3/15/21 08:34:14 device name: IotaWatt
3/15/21 08:34:14 HTTP server started
3/15/21 08:34:14 timeSync: service started.
3/15/21 08:34:14 statService: started.
3/15/21 08:34:14 dataLog: service started.
3/15/21 08:34:17 dataLog: Last log entry 03/15/21 08:34:10
3/15/21 08:34:19 EmonService: started. url=HTTP://192.168.1.105:8081, node=IotaWatt, interval=10, encrypted
3/15/21 08:34:19 influxDB: started, url=HTTP://192.168.1.105:8086, db=iotawatt_db, interval=10
3/15/21 08:34:23 WiFi connected. SSID=Automation, IP=192.168.1.224, channel=11, RSSI -71db
3/15/21 08:34:23 MDNS responder started for hostname IotaWatt
3/15/21 08:34:23 LLMNR responder started for hostname IotaWatt
3/15/21 08:34:23 Updater: service started. Auto-update class is ALPHA
3/15/21 08:34:26 EmonService: Start posting at 03/15/21 08:34:20
3/15/21 08:34:38 Updater: Auto-update is current for class ALPHA.
3/15/21 08:35:14 historyLog: service started.
3/15/21 08:35:15 historyLog: Last log entry 03/15/21 08:34:00
3/15/21 08:35:24 PVoutput: started
3/15/21 08:35:44 influxDB: Start posting at 03/15/21 08:30:30
3/15/21 08:35:46 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:35:56 PVoutput: Start status beginning 03/15/21 08:30:00
3/15/21 08:36:01 Heap memory has degraded below safe minimum, restarting.
3/15/21 12:36:02z Real Time Clock is running. Unix time 1615811762
3/15/21 12:36:02z Reset reason: Software/System restart
3/15/21 12:36:02z Trace: 7:9, 1:6, 1:3, 1:4, 1:5[14], 14:0, 14:4, 14:5, 14:7, 14:8, 14:9, 1:6, 1:1[9], 1:2[10], 9:0[10], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
3/15/21 12:36:02z ESP8266 ChipID: 6308187
3/15/21 12:36:02z IoTaWatt 5.0, Firmware version 02_05_12
3/15/21 12:36:02z SPIFFS mounted.
3/15/21 08:36:02 Local time zone: -5:00
3/15/21 08:36:03 Using Daylight Saving Time (BST) when in effect.
3/15/21 08:36:03 device name: IotaWatt
3/15/21 08:36:03 HTTP server started
3/15/21 08:36:03 timeSync: service started.
3/15/21 08:36:03 statService: started.
3/15/21 08:36:03 dataLog: service started.
3/15/21 08:36:06 dataLog: Last log entry 03/15/21 08:36:00
3/15/21 08:36:08 EmonService: started. url=HTTP://192.168.1.105:8081, node=IotaWatt, interval=10, encrypted
3/15/21 08:36:08 influxDB: started, url=HTTP://192.168.1.105:8086, db=iotawatt_db, interval=10
3/15/21 08:36:16 WiFi connected. SSID=Automation, IP=192.168.1.224, channel=6, RSSI -92db
3/15/21 08:36:16 MDNS responder started for hostname IotaWatt
3/15/21 08:36:16 LLMNR responder started for hostname IotaWatt
3/15/21 08:36:16 Updater: service started. Auto-update class is ALPHA
3/15/21 08:36:19 EmonService: Start posting at 03/15/21 08:36:00
3/15/21 08:36:20 Updater: Auto-update is current for class ALPHA.
3/15/21 08:37:04 historyLog: service started.
3/15/21 08:37:05 historyLog: Last log entry 03/15/21 08:36:00
3/15/21 08:37:05 influxDB: Start posting at 03/15/21 08:30:30
3/15/21 08:37:13 PVoutput: started
3/15/21 08:37:13 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:37:16 PVoutput: Start status beginning 03/15/21 08:30:00
3/15/21 08:37:51 Heap memory has degraded below safe minimum, restarting.
3/15/21 12:37:51z Real Time Clock is running. Unix time 1615811871
3/15/21 12:37:51z Reset reason: Software/System restart
3/15/21 12:37:51z Trace: 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:9, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:2, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
3/15/21 12:37:51z ESP8266 ChipID: 6308187
3/15/21 12:37:51z IoTaWatt 5.0, Firmware version 02_05_12
3/15/21 12:37:51z SPIFFS mounted.
3/15/21 08:37:51 Local time zone: -5:00
3/15/21 08:37:52 Using Daylight Saving Time (BST) when in effect.
3/15/21 08:37:52 device name: IotaWatt
3/15/21 08:37:52 HTTP server started
3/15/21 08:37:52 timeSync: service started.
3/15/21 08:37:52 statService: started.
3/15/21 08:37:52 dataLog: service started.
3/15/21 08:37:55 dataLog: Last log entry 03/15/21 08:37:50
3/15/21 08:37:57 EmonService: started. url=HTTP://192.168.1.105:8081, node=IotaWatt, interval=10, encrypted
3/15/21 08:37:57 influxDB: started, url=HTTP://192.168.1.105:8086, db=iotawatt_db, interval=10
3/15/21 08:38:03 WiFi connected. SSID=Automation, IP=192.168.1.224, channel=11, RSSI -74db
3/15/21 08:38:03 MDNS responder started for hostname IotaWatt
3/15/21 08:38:03 LLMNR responder started for hostname IotaWatt
3/15/21 08:38:03 Updater: service started. Auto-update class is ALPHA
3/15/21 08:38:05 EmonService: Start posting at 03/15/21 08:37:50
3/15/21 08:38:08 Updater: Auto-update is current for class ALPHA.
3/15/21 08:38:53 historyLog: service started.
3/15/21 08:38:54 historyLog: Last log entry 03/15/21 08:37:00
3/15/21 08:39:02 PVoutput: started
3/15/21 08:39:07 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:39:30 PVoutput: Start status beginning 03/15/21 08:35:00
3/15/21 08:39:44 Heap memory has degraded below safe minimum, restarting.
3/15/21 12:39:45z Real Time Clock is running. Unix time 1615811985
3/15/21 12:39:45z Reset reason: Software/System restart
3/15/21 12:39:45z Trace: 7:0, 7:5, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:5, 1:6, 1:3, 1:4, 1:5[22], 22:0, 22:1, 22:0, 22:90, 22:92, 22:2, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
3/15/21 12:39:45z ESP8266 ChipID: 6308187
3/15/21 12:39:45z IoTaWatt 5.0, Firmware version 02_05_12
3/15/21 12:39:45z SPIFFS mounted.
3/15/21 08:39:45 Local time zone: -5:00
3/15/21 08:39:45 Using Daylight Saving Time (BST) when in effect.
3/15/21 08:39:46 device name: IotaWatt
3/15/21 08:39:46 HTTP server started
3/15/21 08:39:46 timeSync: service started.
3/15/21 08:39:46 statService: started.
3/15/21 08:39:46 dataLog: service started.
3/15/21 08:39:49 dataLog: Last log entry 03/15/21 08:39:40
3/15/21 08:39:51 EmonService: started. url=HTTP://192.168.1.105:8081, node=IotaWatt, interval=10, encrypted
3/15/21 08:39:51 influxDB: started, url=HTTP://192.168.1.105:8086, db=iotawatt_db, interval=10
3/15/21 08:39:53 WiFi connected. SSID=Automation, IP=192.168.1.224, channel=11, RSSI -74db
3/15/21 08:39:53 MDNS responder started for hostname IotaWatt
3/15/21 08:39:53 LLMNR responder started for hostname IotaWatt
3/15/21 08:39:53 Updater: service started. Auto-update class is ALPHA
3/15/21 08:39:58 EmonService: Start posting at 03/15/21 08:39:20
3/15/21 08:40:01 Updater: Auto-update is current for class ALPHA.
3/15/21 08:40:47 historyLog: service started.
3/15/21 08:40:48 historyLog: Last log entry 03/15/21 08:39:00
3/15/21 08:40:53 influxDB: Start posting at 03/15/21 08:32:30
3/15/21 08:40:56 PVoutput: started
3/15/21 08:40:58 PVoutput: System Xxxxxxx-1838, interval 5, freeload mode
3/15/21 08:41:00 PVoutput: Start status beginning 03/15/21 08:35:00
