Unit has been otherwise working okay since it was setup about three weeks ago, but I’m getting repeated hardware watchdog and exception resets. Can anyone advise on the stack trace?
8/15/22 17:21:55z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/15/22 17:21:55z IoTaWatt 5.0, Firmware version 02_07_05
8/15/22 17:21:55z SPIFFS mounted.
8/15/22 13:21:55 Local time zone: -5:00, using DST/BST when in effect.
8/15/22 13:21:55 device name: IotaWatt
8/15/22 13:21:55 HTTP server started
8/15/22 13:21:55 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/15/22 13:21:55 timeSync: service started.
8/15/22 13:21:55 statService: started.
8/15/22 13:21:55 dataLog: service started.
8/15/22 13:21:55 dataLog: Last log entry 08/15/22 13:21:50
8/15/22 13:22:00 historyLog: service started.
8/15/22 13:22:00 historyLog: Last log entry 08/15/22 13:21:00
8/15/22 13:22:00 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -72db
8/15/22 13:22:00 MDNS responder started for hostname IotaWatt
8/15/22 13:22:00 LLMNR responder started for hostname IotaWatt
8/15/22 13:22:00 Updater: service started. Auto-update class is MAJOR
8/15/22 13:22:00 Updater: Auto-update is current for class MAJOR.
8/15/22 13:22:02 influxDB_v1: Start posting at 08/15/22 13:21:25
8/16/22 20:26:14z Real Time Clock is running. Unix time 1660681574
8/16/22 20:26:14z Reset reason: Hardware Watchdog
8/16/22 20:26:14z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/16/22 20:26:14z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/16/22 20:26:14z IoTaWatt 5.0, Firmware version 02_07_05
8/16/22 20:26:14z SPIFFS mounted.
8/16/22 16:26:14 Local time zone: -5:00, using DST/BST when in effect.
8/16/22 16:26:14 device name: IotaWatt
8/16/22 16:26:14 HTTP server started
8/16/22 16:26:14 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/16/22 16:26:14 timeSync: service started.
8/16/22 16:26:14 statService: started.
8/16/22 16:26:14 dataLog: service started.
8/16/22 16:26:14 dataLog: Last log entry 08/16/22 16:26:00
8/16/22 16:26:19 historyLog: service started.
8/16/22 16:26:19 historyLog: Last log entry 08/16/22 16:25:00
8/16/22 16:26:19 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -71db
8/16/22 16:26:19 MDNS responder started for hostname IotaWatt
8/16/22 16:26:19 LLMNR responder started for hostname IotaWatt
8/16/22 16:26:19 Updater: service started. Auto-update class is MAJOR
8/16/22 16:26:21 Updater: Auto-update is current for class MAJOR.
8/16/22 16:26:22 influxDB_v1: Start posting at 08/16/22 16:25:40
8/16/22 23:05:36z Real Time Clock is running. Unix time 1660691136
8/16/22 23:05:36z Reset reason: Exception
8/16/22 23:05:36z Trace: 32:65, 32:63, 32:64, 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 32:63, 32:64, 32:64, 32:65, 31:1, 1:6[6], 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/16/22 23:05:36z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/16/22 23:05:36z IoTaWatt 5.0, Firmware version 02_07_05
8/16/22 23:05:36z SPIFFS mounted.
8/16/22 19:05:36 Local time zone: -5:00, using DST/BST when in effect.
8/16/22 19:05:36 device name: IotaWatt
8/16/22 19:05:36 HTTP server started
8/16/22 19:05:36 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/16/22 19:05:36 timeSync: service started.
8/16/22 19:05:36 statService: started.
8/16/22 19:05:36 dataLog: service started.
8/16/22 19:05:36 dataLog: Last log entry 08/16/22 19:05:35
8/16/22 19:05:41 historyLog: service started.
8/16/22 19:05:41 historyLog: Last log entry 08/16/22 19:05:00
8/16/22 19:05:41 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -71db
8/16/22 19:05:41 MDNS responder started for hostname IotaWatt
8/16/22 19:05:41 LLMNR responder started for hostname IotaWatt
8/16/22 19:05:41 Updater: service started. Auto-update class is MAJOR
8/16/22 19:05:42 Updater: Auto-update is current for class MAJOR.
8/16/22 19:05:43 influxDB_v1: Start posting at 08/16/22 19:05:05
8/17/22 01:22:24z Real Time Clock is running. Unix time 1660699344
8/17/22 01:22:24z Reset reason: Hardware Watchdog
8/17/22 01:22:24z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/17/22 01:22:24z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/17/22 01:22:24z IoTaWatt 5.0, Firmware version 02_07_05
8/17/22 01:22:24z SPIFFS mounted.
8/16/22 21:22:24 Local time zone: -5:00, using DST/BST when in effect.
8/16/22 21:22:24 device name: IotaWatt
8/16/22 21:22:24 HTTP server started
8/16/22 21:22:24 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/16/22 21:22:24 timeSync: service started.
8/16/22 21:22:24 statService: started.
8/16/22 21:22:24 dataLog: service started.
8/16/22 21:22:24 dataLog: Last log entry 08/16/22 21:22:10
8/16/22 21:22:28 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -72db
8/16/22 21:22:28 MDNS responder started for hostname IotaWatt
8/16/22 21:22:28 LLMNR responder started for hostname IotaWatt
8/16/22 21:22:28 Updater: service started. Auto-update class is MAJOR
8/16/22 21:22:29 historyLog: service started.
8/16/22 21:22:29 historyLog: Last log entry 08/16/22 21:22:00
8/16/22 21:22:30 Updater: Auto-update is current for class MAJOR.
8/16/22 21:22:31 influxDB_v1: Start posting at 08/16/22 21:21:50
8/17/22 11:55:10z Real Time Clock is running. Unix time 1660737310
8/17/22 11:55:10z Reset reason: Hardware Watchdog
8/17/22 11:55:10z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/17/22 11:55:10z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/17/22 11:55:10z IoTaWatt 5.0, Firmware version 02_07_05
8/17/22 11:55:10z SPIFFS mounted.
8/17/22 07:55:10 Local time zone: -5:00, using DST/BST when in effect.
8/17/22 07:55:10 device name: IotaWatt
8/17/22 07:55:10 HTTP server started
8/17/22 07:55:10 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/17/22 07:55:10 timeSync: service started.
8/17/22 07:55:10 statService: started.
8/17/22 07:55:10 dataLog: service started.
8/17/22 07:55:10 dataLog: Last log entry 08/17/22 07:54:50
8/17/22 07:55:14 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -72db
8/17/22 07:55:14 MDNS responder started for hostname IotaWatt
8/17/22 07:55:14 LLMNR responder started for hostname IotaWatt
8/17/22 07:55:14 Updater: service started. Auto-update class is MAJOR
8/17/22 07:55:15 historyLog: service started.
8/17/22 07:55:15 historyLog: Last log entry 08/17/22 07:54:00
8/17/22 07:55:15 Updater: Auto-update is current for class MAJOR.
8/17/22 07:55:16 influxDB_v1: Start posting at 08/17/22 07:54:30
8/17/22 14:25:40z Real Time Clock is running. Unix time 1660746340
8/17/22 14:25:40z Reset reason: Hardware Watchdog
8/17/22 14:25:40z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/17/22 14:25:40z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/17/22 14:25:40z IoTaWatt 5.0, Firmware version 02_07_05
8/17/22 14:25:40z SPIFFS mounted.
8/17/22 10:25:40 Local time zone: -5:00, using DST/BST when in effect.
8/17/22 10:25:40 device name: IotaWatt
8/17/22 10:25:40 HTTP server started
8/17/22 10:25:40 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/17/22 10:25:40 timeSync: service started.
8/17/22 10:25:40 statService: started.
8/17/22 10:25:40 dataLog: service started.
8/17/22 10:25:40 dataLog: Last log entry 08/17/22 10:25:20
8/17/22 10:25:45 historyLog: service started.
8/17/22 10:25:45 historyLog: Last log entry 08/17/22 10:25:00
8/17/22 10:25:45 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -72db
8/17/22 10:25:45 MDNS responder started for hostname IotaWatt
8/17/22 10:25:45 LLMNR responder started for hostname IotaWatt
8/17/22 10:25:45 Updater: service started. Auto-update class is MAJOR
8/17/22 10:25:47 Updater: Auto-update is current for class MAJOR.
8/17/22 10:25:48 influxDB_v1: Start posting at 08/17/22 10:25:00
8/17/22 23:48:26z Real Time Clock is running. Unix time 1660780106
8/17/22 23:48:26z Reset reason: Exception
8/17/22 23:48:26z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
8/17/22 23:48:26z ESP8266 ID: 15842055, RTC PCF8523 (68)
8/17/22 23:48:26z IoTaWatt 5.0, Firmware version 02_07_05
8/17/22 23:48:26z SPIFFS mounted.
8/17/22 19:48:26 Local time zone: -5:00, using DST/BST when in effect.
8/17/22 19:48:26 device name: IotaWatt
8/17/22 19:48:26 HTTP server started
8/17/22 19:48:26 influxDB_v1: Starting, interval:5, *dumb forum url rule*xxx.xxx.xxx.xxx:8086
8/17/22 19:48:26 timeSync: service started.
8/17/22 19:48:26 statService: started.
8/17/22 19:48:26 dataLog: service started.
8/17/22 19:48:26 dataLog: Last log entry 08/17/22 19:48:20
8/17/22 19:48:31 historyLog: service started.
8/17/22 19:48:31 historyLog: Last log entry 08/17/22 19:48:00
8/17/22 19:48:31 WiFi connected. SSID=XXXXXX, IP=xxx.xxx.xxx.xxx, channel=2, RSSI -72db
8/17/22 19:48:31 MDNS responder started for hostname IotaWatt
8/17/22 19:48:31 LLMNR responder started for hostname IotaWatt
8/17/22 19:48:31 Updater: service started. Auto-update class is MAJOR
8/17/22 19:48:33 Updater: Auto-update is current for class MAJOR.
8/17/22 19:48:34 influxDB_v1: Start posting at 08/17/22 19:48:00
