This seems to happen intermittently. Sometimes when I navigate to Graph+, the dropdown with my saved graphs is empty. Looking at the Chrome network inspector in dev tools, /graph/getall
does appear to have all (except maybe one) of my graphs, but the dropdown remains empty.
I don’t see any other JS or HTTP errors, and reloading the page (or just coming back later) sometimes fixes it. But sometimes I reload many times and the graphs never appear.
Is there anything I can do to troubleshoot?
Just took a look at the message log, and it seems device resets are happening with some frequency, with exceptions and hardware watchdog as the usual reasons.
11/17/19 23:24:21 Updater: service started. Auto-update class is BETA
11/17/19 23:24:22 EmonService: Start posting at 11/17/19 23:23:55
11/17/19 23:24:23 Updater: Auto-update is current for class BETA.
11/17/19 23:24:23 influxDB: Start posting at 11/17/19 23:23:20
11/17/19 23:25:14 historyLog: service started.
11/17/19 23:25:14 historyLog: Last log entry 11/17/19 23:23:00
11/17/19 23:25:14 PVoutput: started
11/17/19 23:25:14 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/17/19 23:25:15 PVoutput: Start status beginning 11/17/19 23:20:00
11/18/19 09:13:05 dataLog: datalog WDT - restarting
11/17/19 22:13:07z Real Time Clock is running. Unix time 1574028787
11/17/19 22:13:07z Reset reason: Software/System restart
11/17/19 22:13:07z Trace: 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:55, 25:56, 25:41, 25:42, 25:43, 10:57
11/17/19 22:13:07z ESP8266 ChipID: 2518879
11/17/19 22:13:07z IoTaWatt 5.0, Firmware version 02_05_01
11/17/19 22:13:07z SPIFFS mounted.
11/18/19 09:13:08 Local time zone: +10:00
11/18/19 09:13:08 Using Daylight Saving Time (BST) when in effect.
11/18/19 09:13:08 device name: IotaWatt
11/18/19 09:13:08 MDNS responder started for hostname IotaWatt
11/18/19 09:13:08 LLMNR responder started for hostname IotaWatt
11/18/19 09:13:08 HTTP server started
11/18/19 09:13:08 timeSync: service started.
11/18/19 09:13:08 statService: started.
11/18/19 09:13:09 dataLog: service started.
11/18/19 09:13:09 dataLog: Last log entry 11/18/19 09:12:35
11/18/19 09:13:13 EmonService: started. url=emoncms.org:80, node=IotaWatt, interval=5, encrypted
11/18/19 09:13:13 influxDB: started, url=hassio.home:8086, db=iotawatt, interval=10
11/18/19 09:13:28 WiFi connected. SSID=supermassive 24, IP=192.168.50.244, channel=9, RSSI -59db
11/18/19 09:13:28 Updater: service started. Auto-update class is BETA
11/18/19 09:13:30 EmonService: Start posting at 11/18/19 09:12:15
11/18/19 09:13:31 Updater: Auto-update is current for class BETA.
11/18/19 09:13:32 influxDB: Start posting at 11/18/19 09:12:10
11/18/19 09:14:08 historyLog: service started.
11/18/19 09:14:08 historyLog: Last log entry 11/18/19 09:12:00
11/18/19 09:14:08 PVoutput: started
11/18/19 09:14:09 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/18/19 09:14:09 PVoutput: Start status beginning 11/18/19 09:10:00
11/18/19 05:18:17z Real Time Clock is running. Unix time 1574054297
11/18/19 05:18:17z Reset reason: Hardware Watchdog
11/18/19 05:18:17z Trace: 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
11/18/19 05:18:17z ESP8266 ChipID: 2518879
11/18/19 05:18:17z IoTaWatt 5.0, Firmware version 02_05_01
11/18/19 05:18:17z SPIFFS mounted.
11/18/19 16:18:18 Local time zone: +10:00
11/18/19 16:18:18 Using Daylight Saving Time (BST) when in effect.
11/18/19 16:18:18 device name: IotaWatt
11/18/19 16:18:18 MDNS responder started for hostname IotaWatt
11/18/19 16:18:18 LLMNR responder started for hostname IotaWatt
11/18/19 16:18:18 HTTP server started
11/18/19 16:18:18 timeSync: service started.
11/18/19 16:18:18 statService: started.
11/18/19 16:18:19 dataLog: service started.
11/18/19 16:18:19 dataLog: Last log entry 11/18/19 16:18:05
11/18/19 16:18:23 EmonService: started. url=emoncms.org:80, node=IotaWatt, interval=5, encrypted
11/18/19 16:18:23 influxDB: started, url=hassio.home:8086, db=iotawatt, interval=10
11/18/19 16:18:34 WiFi connected. SSID=supermassive 24, IP=192.168.50.244, channel=9, RSSI -52db
11/18/19 16:18:34 Updater: service started. Auto-update class is BETA
11/18/19 16:18:35 EmonService: Start posting at 11/18/19 16:17:40
11/18/19 16:18:36 Updater: Auto-update is current for class BETA.
11/18/19 16:18:36 influxDB: Start posting at 11/18/19 16:17:40
11/18/19 16:19:18 historyLog: service started.
11/18/19 16:19:18 historyLog: Last log entry 11/18/19 16:18:00
11/18/19 16:19:18 PVoutput: started
11/18/19 16:19:18 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/18/19 16:19:19 PVoutput: Start status beginning 11/18/19 16:15:00
11/18/19 20:15:20z Real Time Clock is running. Unix time 1574108120
11/18/19 20:15:20z Reset reason: Hardware Watchdog
11/18/19 20:15:20z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10
11/18/19 20:15:20z ESP8266 ChipID: 2518879
11/18/19 20:15:20z IoTaWatt 5.0, Firmware version 02_05_01
11/18/19 20:15:20z SPIFFS mounted.
11/19/19 07:15:21 Local time zone: +10:00
11/19/19 07:15:21 Using Daylight Saving Time (BST) when in effect.
11/19/19 07:15:21 device name: IotaWatt
11/19/19 07:15:21 MDNS responder started for hostname IotaWatt
11/19/19 07:15:21 LLMNR responder started for hostname IotaWatt
11/19/19 07:15:21 HTTP server started
11/19/19 07:15:21 timeSync: service started.
11/19/19 07:15:21 statService: started.
11/19/19 07:15:21 Updater: service started. Auto-update class is BETA
11/19/19 07:15:22 WiFi connected. SSID=supermassive 24, IP=192.168.50.244, channel=9, RSSI -54db
11/19/19 07:15:22 dataLog: service started.
11/19/19 07:15:22 dataLog: Last log entry 11/19/19 07:15:10
11/19/19 07:15:23 Updater: Auto-update is current for class BETA.
11/19/19 07:15:26 EmonService: started. url=emoncms.org:80, node=IotaWatt, interval=5, encrypted
11/19/19 07:15:26 influxDB: started, url=hassio.home:8086, db=iotawatt, interval=10
11/19/19 07:15:27 EmonService: Start posting at 11/19/19 07:14:55
11/19/19 07:15:28 influxDB: Start posting at 11/19/19 07:14:30
11/19/19 07:16:21 historyLog: service started.
11/19/19 07:16:21 historyLog: Last log entry 11/19/19 07:15:00
11/19/19 07:16:21 PVoutput: started
11/19/19 07:16:21 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/19/19 07:16:22 PVoutput: Start status beginning 11/19/19 07:15:00
11/19/19 21:24:57z Real Time Clock is running. Unix time 1574198697
11/19/19 21:24:57z Reset reason: Exception
11/19/19 21:24:57z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[12], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2
11/19/19 21:24:57z ESP8266 ChipID: 2518879
11/19/19 21:24:57z IoTaWatt 5.0, Firmware version 02_05_01
11/19/19 21:24:57z SPIFFS mounted.
11/20/19 08:24:58 Local time zone: +10:00
11/20/19 08:24:58 Using Daylight Saving Time (BST) when in effect.
11/20/19 08:24:58 device name: IotaWatt
11/20/19 08:24:58 MDNS responder started for hostname IotaWatt
11/20/19 08:24:58 LLMNR responder started for hostname IotaWatt
11/20/19 08:24:58 HTTP server started
11/20/19 08:24:58 timeSync: service started.
11/20/19 08:24:58 statService: started.
11/20/19 08:24:59 dataLog: service started.
11/20/19 08:24:59 dataLog: Last log entry 11/20/19 08:24:50
11/20/19 08:25:03 EmonService: started. url=emoncms.org:80, node=IotaWatt, interval=5, encrypted
11/20/19 08:25:03 influxDB: started, url=hassio.home:8086, db=iotawatt, interval=10
11/20/19 08:25:04 WiFi connected. SSID=supermassive 24, IP=192.168.50.244, channel=9, RSSI -54db
11/20/19 08:25:04 Updater: service started. Auto-update class is BETA
11/20/19 08:25:05 EmonService: Start posting at 11/20/19 08:24:45
11/20/19 08:25:06 influxDB: Start posting at 11/20/19 08:24:40
11/20/19 08:25:07 Updater: Auto-update is current for class BETA.
11/20/19 08:25:58 historyLog: service started.
11/20/19 08:25:58 historyLog: Last log entry 11/20/19 08:24:00
11/20/19 08:25:58 PVoutput: started
11/20/19 08:25:59 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/20/19 08:25:59 PVoutput: Start status beginning 11/20/19 08:20:00
11/19/19 21:44:08z Real Time Clock is running. Unix time 1574199848
11/19/19 21:44:08z Reset reason: Hardware Watchdog
11/19/19 21:44:08z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
11/19/19 21:44:08z ESP8266 ChipID: 2518879
11/19/19 21:44:08z IoTaWatt 5.0, Firmware version 02_05_01
11/19/19 21:44:08z SPIFFS mounted.
11/20/19 08:44:09 Local time zone: +10:00
11/20/19 08:44:09 Using Daylight Saving Time (BST) when in effect.
11/20/19 08:44:09 device name: IotaWatt
11/20/19 08:44:09 MDNS responder started for hostname IotaWatt
11/20/19 08:44:09 LLMNR responder started for hostname IotaWatt
11/20/19 08:44:09 HTTP server started
11/20/19 08:44:09 timeSync: service started.
11/20/19 08:44:09 statService: started.
11/20/19 08:44:10 dataLog: service started.
11/20/19 08:44:10 dataLog: Last log entry 11/20/19 08:43:55
11/20/19 08:44:14 EmonService: started. url=emoncms.org:80, node=IotaWatt, interval=5, encrypted
11/20/19 08:44:14 influxDB: started, url=hassio.home:8086, db=iotawatt, interval=10
11/20/19 08:44:16 WiFi connected. SSID=supermassive 24, IP=192.168.50.244, channel=9, RSSI -54db
11/20/19 08:44:16 Updater: service started. Auto-update class is BETA
11/20/19 08:44:17 EmonService: Start posting at 11/20/19 08:43:55
11/20/19 08:44:17 influxDB: Start posting at 11/20/19 08:43:20
11/20/19 08:44:19 Updater: Auto-update is current for class BETA.
11/20/19 08:45:09 historyLog: service started.
11/20/19 08:45:09 historyLog: Last log entry 11/20/19 08:43:00
11/20/19 08:45:09 PVoutput: started
11/20/19 08:45:10 PVoutput: System supermassive 7.25kW, interval 5, donator mode
11/20/19 08:45:11 PVoutput: Start status beginning 11/20/19 08:40:00
Perhaps when I “come back later” the device happens to have been reset and graphs start working again.
