Emoncms is missing the data.
Here is the message log - note it was 5/06/20 17:54:56 when I re-seated the SD card and tried again.
4/28/20 08:25:11 EmonService: query open failed.
4/28/20 08:26:11 EmonService: query open failed.
4/28/20 08:27:08 Updater: Unrecognized auto-update class MINOR.
4/28/20 08:27:12 EmonService: Start posting at 04/28/20 07:57:00
4/28/20 08:27:12 PVoutput: System Owarra Solar, interval 5, freeload mode
4/28/20 08:27:12 PVoutput: Start status beginning 04/28/20 08:15:00
4/28/20 09:27:14 Updater: Unrecognized auto-update class MINOR.
4/28/20 10:27:20 Updater: Unrecognized auto-update class MINOR.
4/28/20 11:27:26 Updater: Unrecognized auto-update class MINOR.
4/28/20 12:27:32 Updater: Unrecognized auto-update class MINOR.
4/28/20 13:14:08 Heap memory has degraded below safe minimum, restarting.
4/28/20 03:14:10z Real Time Clock is running. Unix time 1588043650
4/28/20 03:14:10z Reset reason: Software/System restart
4/28/20 03:14:10z Trace: 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
4/28/20 03:14:10z ESP8266 ChipID: 6145636
4/28/20 03:14:10z IoTaWatt 5.0, Firmware version 02_05_08
4/28/20 03:14:10z SPIFFS mounted.
4/28/20 13:14:10 Local time zone: +10:00
4/28/20 13:14:10 device name: IotaWatt
4/28/20 13:14:10 HTTP server started
4/28/20 13:14:10 timeSync: service started.
4/28/20 13:14:10 statService: started.
4/28/20 13:14:10 dataLog: service started.
4/28/20 13:14:10 dataLog: Last log entry 04/28/20 13:14:05
4/28/20 13:14:10 historyLog: service started.
4/28/20 13:14:11 historyLog: Last log entry 04/28/20 13:14:00
4/28/20 13:14:15 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10, encrypted
4/28/20 13:14:20 PVoutput: started
4/28/20 13:14:47 WiFi connected. SSID=dotheevolution, IP=192.168.1.54, channel=1, RSSI -81db
4/28/20 13:14:47 MDNS responder started for hostname IotaWatt
4/28/20 13:14:47 LLMNR responder started for hostname IotaWatt
4/28/20 13:14:47 Updater: service started. Auto-update class is MINOR
4/28/20 13:14:49 PVoutput: System Owarra Solar, interval 5, freeload mode
4/28/20 13:15:00 Updater: Unrecognized auto-update class MINOR.
4/28/20 13:15:06 PVoutput: Start status beginning 04/28/20 13:10:00
4/28/20 13:15:11 EmonService: Start posting at 04/28/20 13:12:10
4/28/20 14:15:06 Updater: Unrecognized auto-update class MINOR.
4/28/20 15:15:13 Updater: Unrecognized auto-update class MINOR.
4/28/20 15:29:16 Heap memory has degraded below safe minimum, restarting.
4/28/20 05:29:17z Real Time Clock is running. Unix time 1588051757
4/28/20 05:29:17z Reset reason: Software/System restart
4/28/20 05:29:17z Trace: 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
4/28/20 05:29:17z ESP8266 ChipID: 6145636
4/28/20 05:29:17z IoTaWatt 5.0, Firmware version 02_05_08
4/28/20 05:29:17z SPIFFS mounted.
4/28/20 15:29:17 Local time zone: +10:00
4/28/20 15:29:17 device name: IotaWatt
4/28/20 15:29:17 HTTP server started
4/28/20 15:29:17 timeSync: service started.
4/28/20 15:29:17 statService: started.
4/28/20 15:29:17 dataLog: service started.
4/28/20 15:29:17 dataLog: Last log entry 04/28/20 15:29:15
4/28/20 15:29:17 historyLog: service started.
4/28/20 15:29:18 historyLog: Last log entry 04/28/20 15:29:00
4/28/20 15:29:22 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10, encrypted
4/28/20 15:29:27 PVoutput: started
4/28/20 15:29:30 WiFi connected. SSID=dotheevolution, IP=192.168.1.54, channel=1, RSSI -80db
4/28/20 15:29:30 MDNS responder started for hostname IotaWatt
4/28/20 15:29:30 LLMNR responder started for hostname IotaWatt
4/28/20 15:29:30 Updater: service started. Auto-update class is MINOR
4/28/20 15:29:30 PVoutput: System Owarra Solar, interval 5, freeload mode
4/28/20 15:29:31 EmonService: Start posting at 04/28/20 15:28:20
4/28/20 15:29:31 PVoutput: Start status beginning 04/28/20 15:25:00
4/28/20 15:29:35 Updater: Unrecognized auto-update class MINOR.
4/28/20 16:29:41 Updater: Unrecognized auto-update class MINOR.
4/28/20 17:29:47 Updater: Unrecognized auto-update class MINOR.
4/28/20 18:29:53 Updater: Unrecognized auto-update class MINOR.
4/28/20 19:29:59 Updater: Unrecognized auto-update class MINOR.
4/28/20 20:30:05 Updater: Unrecognized auto-update class MINOR.
4/28/20 21:30:11 Updater: Unrecognized auto-update class MINOR.
4/28/20 22:30:17 Updater: Unrecognized auto-update class MINOR.
4/28/20 23:30:23 Updater: Unrecognized auto-update class MINOR.
4/29/20 00:30:29 Updater: Unrecognized auto-update class MINOR.
4/29/20 01:30:35 Updater: Unrecognized auto-update class MINOR.
4/29/20 02:30:41 Updater: Unrecognized auto-update class MINOR.
4/29/20 03:30:47 Updater: Unrecognized auto-update class MINOR.
4/29/20 04:30:53 Updater: Unrecognized auto-update class MINOR.
4/29/20 05:30:59 Updater: Unrecognized auto-update class MINOR.
4/29/20 06:31:05 Updater: Unrecognized auto-update class MINOR.
4/29/20 07:31:11 Updater: Unrecognized auto-update class MINOR.
4/29/20 08:31:17 Updater: Unrecognized auto-update class MINOR.
4/29/20 09:31:23 Updater: Unrecognized auto-update class MINOR.
4/29/20 10:31:29 Updater: Unrecognized auto-update class MINOR.
4/29/20 11:31:35 Updater: Unrecognized auto-update class MINOR.
4/29/20 12:31:42 Updater: Unrecognized auto-update class MINOR.
4/29/20 13:31:48 Updater: Unrecognized auto-update class MINOR.
5/01/20 22:19:22z Real Time Clock is running. Unix time 1588371562
5/01/20 22:19:22z Power failure detected.
5/01/20 22:19:22z Reset reason: External System
5/01/20 22:19:22z ESP8266 ChipID: 6145636
5/01/20 22:19:22z IoTaWatt 5.0, Firmware version 02_05_08
5/01/20 22:19:22z SPIFFS mounted.
5/02/20 08:19:22 Local time zone: +10:00
5/02/20 08:19:22 device name: IotaWatt
5/02/20 08:19:25 HTTP server started
5/02/20 08:19:25 WiFi connected. SSID=dotheevolution, IP=192.168.1.54, channel=1, RSSI -70db
5/02/20 08:19:25 MDNS responder started for hostname IotaWatt
5/02/20 08:19:25 LLMNR responder started for hostname IotaWatt
5/02/20 08:19:25 timeSync: service started.
5/02/20 08:19:35 statService: started.
5/02/20 08:19:35 Updater: service started. Auto-update class is MINOR
5/02/20 08:19:35 dataLog: service started.
5/02/20 08:19:35 dataLog: Last log entry 05/02/20 08:19:10
5/02/20 08:19:35 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10, encrypted
5/02/20 08:19:36 historyLog: service started.
5/02/20 08:19:36 historyLog: Last log entry 05/02/20 08:19:00
5/02/20 08:19:46 PVoutput: started
5/02/20 08:19:50 Updater: Invalid response from server. HTTPcode: -4
5/02/20 08:20:30 PVoutput: System Owarra Solar, interval 5, freeload mode
5/02/20 08:20:30 PVoutput: Start status beginning 05/02/20 08:15:00
5/02/20 08:20:34 EmonService: Start posting at 05/02/20 08:19:10
5/02/20 09:19:42 Updater: Auto-update is current for class MINOR.
5/04/20 17:25:43 Updater: Invalid response from server. HTTPcode: -11
5/06/20 07:54:56z Real Time Clock is running. Unix time 1588751696
5/06/20 07:54:56z Power failure detected.
5/06/20 07:54:56z Reset reason: External System
5/06/20 07:54:56z ESP8266 ChipID: 6145636
5/06/20 07:54:56z IoTaWatt 5.0, Firmware version 02_05_08
5/06/20 07:54:56z SPIFFS mounted.
5/06/20 17:54:56 Local time zone: +10:00
5/06/20 17:54:56 device name: IotaWatt
5/06/20 17:54:59 HTTP server started
5/06/20 17:54:59 WiFi connected. SSID=dotheevolution, IP=192.168.1.54, channel=1, RSSI -47db
5/06/20 17:54:59 MDNS responder started for hostname IotaWatt
5/06/20 17:54:59 LLMNR responder started for hostname IotaWatt
5/06/20 17:54:59 timeSync: service started.
5/06/20 17:54:59 statService: started.
5/06/20 17:54:59 Updater: service started. Auto-update class is MINOR
5/06/20 17:54:59 dataLog: service started.
5/06/20 17:55:00 dataLog: Last log entry 05/05/20 14:31:40
5/06/20 17:55:00 historyLog: service started.
5/06/20 17:55:00 historyLog: Last log entry 05/05/20 14:31:00
5/06/20 17:55:01 Updater: Auto-update is current for class MINOR.
5/06/20 17:55:04 EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10, encrypted
5/06/20 17:55:05 EmonService: Start posting at 05/05/20 14:31:10
5/06/20 17:55:09 PVoutput: started
5/06/20 17:55:09 PVoutput: System Owarra Solar, interval 5, freeload mode
5/06/20 17:55:10 PVoutput: Start status beginning 05/05/20 14:30:00
