I have a weird issue where the entire system freezes from time to time, for up to 8 minutes, resulting in data not being collected and logged. I first noticed it when I saw nulls in my data:
2022-06-19 06:54:00, 0.1, 1.9, 100.7, 5.6, 127.1, 13.2, 1.1, 5.8, 42.2, 0.1
2022-06-19 06:55:00, 0.1, 2.1, 99.8, 5.8, 127.2, 13.4, 1.2, 5.6, 43.3, 0.1
2022-06-19 06:56:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 06:57:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 06:58:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 06:59:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 07:00:00, 0.1, 2.0, 97.9, 5.6, 128.1, 13.3, 1.1, 5.9, 39.9, 0.1
2022-06-19 07:01:00, 0.1, 1.9, 100.0, 5.5, 131.2, 13.1, 1.1, 5.8, 39.8, 0.1
2022-06-19 08:00:00, 0.2, 1.2, 103.4, 842.4, 121.8, 13.0, 0.9, 5.8, 148.7, 0.1
2022-06-19 08:01:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 08:02:00, null, null, null, null, null, null, null, null, null, null
2022-06-19 08:03:00, 1.8, 1.9, 103.4, 844.3, 120.7, 13.1, 1.0, 5.9, 133.5, 0.1
Every now and again when querying the data I noticed it lock up and I need to reconnect it on the router to bring it back. The system is new (a couple days old) and is being queried by Home Assistant and uploading to InfluxDB. This happened before the Influx upload. There is sometimes nothing in the Message Log during this time, sometimes there seems to be a message dataLog: datalog WDT - restarting
6/18/22 21:23:36 LLMNR responder started for hostname IotaWatt
6/18/22 21:23:36 Updater: service started. Auto-update class is MINOR
6/18/22 21:23:38 influxDB_v2: Resume posting 06/18/22 21:18:00
6/18/22 21:23:40 Updater: Auto-update is current for class MINOR.
6/19/22 01:47:40 dataLog: datalog WDT - restarting
6/18/22 23:47:41z Real Time Clock is running. Unix time 1655596061
6/18/22 23:47:41z Reset reason: Software/System restart
6/18/22 23:47:41z Trace: 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:55, 25:56, 25:41, 25:42, 25:43, 10:57
6/18/22 23:47:41z ESP8266 ID: 15923351, RTC PCF8523 (68)
6/18/22 23:47:41z IoTaWatt 5.0, Firmware version 02_07_05
6/18/22 23:47:41z SPIFFS mounted.
6/19/22 01:47:41 Local time zone: +2:00
6/19/22 01:47:41 device name: IotaWatt
6/19/22 01:47:41 HTTP server started
6/19/22 01:47:41 influxDB_v2: Starting, interval:10, url:http://influx.wiersma.lan
6/19/22 01:47:41 timeSync: service started.
6/19/22 01:47:41 statService: started.
6/19/22 01:47:41 dataLog: service started.
6/19/22 01:47:41 dataLog: Last log entry 06/19/22 01:42:40
6/19/22 01:47:46 historyLog: service started.
6/19/22 01:47:46 historyLog: Last log entry 06/19/22 01:42:00
6/19/22 01:47:46 WiFi connected. SSID=StayOutIoT, IP=10.0.1.96, channel=1, RSSI -79db
6/19/22 01:47:46 MDNS responder started for hostname IotaWatt
6/19/22 01:47:46 LLMNR responder started for hostname IotaWatt
6/19/22 01:47:46 Updater: service started. Auto-update class is MINOR
6/19/22 01:47:48 influxDB_v2: Resume posting 06/19/22 01:42:40
6/19/22 01:47:50 Updater: Auto-update is current for class MINOR.
6/19/22 07:00:20 dataLog: datalog WDT - restarting
6/19/22 05:00:21z Real Time Clock is running. Unix time 1655614821
6/19/22 05:00:21z Reset reason: Software/System restart
6/19/22 05:00:21z Trace: 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:61, 25:64, 25:65, 25:55, 25:56, 25:41, 25:42, 25:41, 25:45, 25:41, 25:42, 25:41, 25:44, 10:57, 10:58, 25:20, 25:40, 25:41, 25:44, 10:56, 25:1, 25:1[2], 25:1[3], 10:59
6/19/22 05:00:21z ESP8266 ID: 15923351, RTC PCF8523 (68)
6/19/22 05:00:21z IoTaWatt 5.0, Firmware version 02_07_05
6/19/22 05:00:21z SPIFFS mounted.
6/19/22 07:00:21 Local time zone: +2:00
6/19/22 07:00:21 device name: IotaWatt
6/19/22 07:00:21 HTTP server started
6/19/22 07:00:21 influxDB_v2: Starting, interval:10, url:http://influx.wiersma.lan
6/19/22 07:00:21 timeSync: service started.
6/19/22 07:00:21 statService: started.
6/19/22 07:00:21 dataLog: service started.
6/19/22 07:00:21 dataLog: Last log entry 06/19/22 06:55:20
6/19/22 07:00:26 historyLog: service started.
6/19/22 07:00:26 historyLog: Last log entry 06/19/22 06:55:00
6/19/22 07:00:26 WiFi connected. SSID=StayOutIoT, IP=10.0.1.96, channel=1, RSSI -78db
6/19/22 07:00:26 MDNS responder started for hostname IotaWatt
6/19/22 07:00:26 LLMNR responder started for hostname IotaWatt
6/19/22 07:00:26 Updater: service started. Auto-update class is MINOR
6/19/22 07:00:28 influxDB_v2: Resume posting 06/19/22 06:55:10
6/19/22 07:00:30 Updater: Auto-update is current for class MINOR.
6/19/22 07:31:01 WiFi disconnected.
6/19/22 07:31:02 WiFi connected. SSID=StayOutIoT, IP=10.0.1.96, channel=1, RSSI -78db
My device is in the roof so not easily accessible to look at the lights during this time, but if needed I guess I could camp out there for an hour to see. Otherwise I have pocked around a little but not sure how to debug this further to work this out.
Any help would be appreciated. Thank you.
