Greetings,
I have recently been getting periodic Wi-Fi disconnects on my two IoTaWatt units, resulting in log entries like:
3/06/23 02:09:52 WiFi disconnected.
3/06/23 03:09:52 WiFi disconnected more than 60 minutes, restarting.
Is there someplace I can look (or a debug setting I can turn on) to find a more-detailed error message about what made the IoTaWatt disconnect from Wi-Fi?
Thanks in advance!
The log also indicates the RSSI on every Wi-Fi connection. What does it say?
Mine is in a low signal strength location and typically say -70dB, but has no problem maintaining a connection.
At -80dB devices typically have some difficulty. At -90dB devices typically have great difficulty connecting.
At -60dB or better (less negative number) signal strength is not the issue.
What router/AP do you have?
What environment are you in? Apartment with lots of Wi-Fi from neighbors? Isolated in a rural area with no other visible 2.4GHz activity? Someplace in between?
