Iotawatt is not connecting to the WiFi any more; might be because the base station configuration changed, or I don’t know what. So I need to reconfigure WiFi.
I thought there might be a “reset WiFi” button, but there doesn’t seem to be. Then I thought there might be a file on the SD card that has the WiFi info, but if so, I can’t find it. Then I connected via USB serial and I get “8/21/21 18:51:40z Connecting with WiFiManager.” but no further luck.
How do I set new WiFi info if I can’t access the network with the old WiFi configuration?
Update: After I while, the console output continues:
8/21/21 18:58:06z Did not connect after power-fail. Restarting to reset WiFi.
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x4010f000, len 1392, room 16
tail 0
chksum 0xd0
csum 0xd0
v3d128e5c
~ld
SPI started.
8/21/21 18:58:07z Real Time Clock is running. Unix time 1629572287
8/21/21 18:58:07z Reset reason: Software/System restart
8/21/21 18:58:07z Trace: 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 11:0, 11:4, 11:5, 11:5, 11:6, 11:7, 11:8, 11:9, 16:0, 16:1, 16:2, 16:3, 16:4, 16:5, 16:6, 16:7, 11:10, 11:11, 11:12, 11:12
8/21/21 18:58:07z ESP8266 ChipID: 6910209
8/21/21 18:58:07z IoTaWatt 4.x, Firmware version 02_05_09
8/21/21 18:58:07z SPIFFS mounted.
8/21/21 18:58:08z Local time zone: +0:00
8/21/21 18:58:08z device name: IotaWatt
8/21/21 18:58:08z HTTP server started
8/21/21 18:58:08z timeSync: service started.
8/21/21 18:58:08z statService: started.
8/21/21 18:58:08z dataLog: service started.
8/21/21 18:58:12z dataLog: Last log entry 08/21/21 18:55:55
8/21/21 18:58:13z EmonService: started. url=HTTP://emoncms.org, node=IotaWatt, interval=10, encrypted
Now the LED rapidly flashes red.
