Can't Access Iotawatt from Web but can ping. Please Help
Six or eight months ago I was fortunate enough to purchase a iotawatt. Awesome product but unfortunately have been having some trouble.
I was having some trouble with the iotawatt (cant remember what it was, it was something small) so I decided I would change firmware version to the alpha branch. It worked for a but unfortunately seems to have locked up. The last file in the download folder is 02_03_09.
I think this might be a software issue since I have heard similar situations but have not come across a solutions. The particulars are as follows:
  • Contents of IOTAWATT directory are corrupted (I would really really like to recover the data if someone knows how).
  • Device powers up and turns on.
  • When powered up the LED is solid green. The device connects to the wifi access point.
  • I can ping the iotawatt.
  • I can not connect to the device in any other way (web, ssh etc)
My first reaction was that it is a bad card. Thought maybe I should create a fat32 partition on a good card and grab the appropriate files. Is this something I should try?
Is there anyway to update the firmware from the SD card? Or do a full reset from the sd card.
Just want to get the device working again and recover my data.
Thanks
Just wondering when was the last time you accessed the unit, because 02_03_09 has not been the ALPHA release for some time.
That your unit connects and ping is really not a function of the IotaWatt firmware, that’s something that the ESP does at a lower level.
You didn’t say how you know that the contents of the IotaWatt directory are corrupted. I’m guessing you opened it up and removed the SDcard. If that’s the case, then If you can access Iotawatt/iotamsgs.txt and post it, I can take a look.
Hi Overeasy,
Sorry I do not have a card reader on this system. I will type it out and get a card reader tomorrow.
It stopped working sometime in June.
Nothing stands out in the log it just ends with repeating:
Updater: Update from 02_03_06 to 02_03_07
Updater: download 02_03_07
Updater: Download failed HTTPcode
It looks like it tried to update for 5 days (about 400 lines) and the last line is:
Updat
This has all the makings of a long drawn out thread that could easily take longer to resolve than just sending me the box to test and reflash. Where are you located?
#5
Hi Overeasy, Did not mean to make it drawn out. My wife is 40 weeks pregnant and there have been lots of distractions. I am located in Canada. If there is something I can do here I would be more than willing to try. I assume it is running an arduino. I have installed the Arduino IDE (1.8.7) on a linux box. If you tell me how to process. I will give it a try. I also suspect that the SD card may have been the point of failure. I would like to rebuild that as well.
Btw here is latest section from the log file:
5/19/18 13:16:44z Real Time Clock is running. Unix time 1526735804
5/19/18 13:16:44z Version 02_03_06
5/19/18 13:16:44z Reset reason: Software/System restart
5/19/18 13:16:44z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5
5/19/18 13:16:44z ESP8266 ChipID: 191613
5/19/18 09:16:44 Local time zone: -4
5/19/18 09:16:44 device name: IotaWatt, version: 3
5/19/18 09:16:44 MDNS responder started
5/19/18 09:16:44 You can now connect to http://IotaWatt.local
5/19/18 09:16:44 HTTP server started
5/19/18 09:16:44 dataLog: service started.
5/19/18 09:16:44 dataLog: Last log entry: 1526735800
5/19/18 09:16:45 statService: started.
5/19/18 09:16:45 timeSync: service started.
5/19/18 09:16:45 WiFi connected. SSID: wifi24, IP: 192.168.1.144
5/19/18 09:16:45 Updater: started.
5/19/18 09:16:45 historyLog: service started.
5/19/18 09:16:45 historyLog: Last log entry 1526735760
5/19/18 09:16:49 influxDB: started.
5/19/18 09:16:49 influxDB: last entry query failed: -4
5/19/18 09:16:49 influxDB: Stopped. Last post 2/18/18 00:00:00
5/19/18 19:17:07 timeSync: adjusting RTC by -2
5/21/18 15:18:00 timeSync: adjusting RTC by -2
5/23/18 14:23:54 timeSync: adjusting RTC by -2
5/25/18 11:24:10 timeSync: adjusting RTC by -2
5/27/18 11:24:26 timeSync: adjusting RTC by -2
5/29/18 11:24:44 timeSync: adjusting RTC by -2
5/31/18 08:25:01 timeSync: adjusting RTC by -2
6/02/18 09:25:19 timeSync: adjusting RTC by -2
6/04/18 03:25:38 timeSync: adjusting RTC by -2
6/04/18 09:23:10 Updater: Update from 02_03_06 to 02_03_07
6/04/18 09:23:10 Updater: download 02_03_07
6/04/18 09:23:26 Updater: Download failed HTTPcode
6/04/18 10:23:27 Updater: Update from 02_03_06 to 02_03_07
6/04/18 10:23:27 Updater: download 02_03_07
6/04/18 10:23:47 Updater: Download failed HTTPcode
6/04/18 11:23:48 Updater: Update from 02_03_06 to 02_03_07
6/04/18 11:23:48 Updater: download 02_03_07
6/04/18 11:24:08 Updater: Download failed HTTPcode
6/04/18 12:24:09 Updater: Update from 02_03_06 to 02_03_07
6/04/18 12:24:09 Updater: download 02_03_07
6/04/18 12:24:29 Updater: Download failed HTTPcode
6/04/18 13:24:30 Updater: Update from 02_03_06 to 02_03_07
6/04/18 13:24:30 Updater: download 02_03_07
6/04/18 13:24:51 Updater: Download failed HTTPcode
6/04/18 14:24:52 Updater: Update from 02_03_06 to 02_03_07
6/04/18 14:24:52 Updater: download 02_03_07
6/04/18 14:25:14 Updater: Download failed HTTPcode
6/04/18 15:25:15 Updater: Update from 02_03_06 to 02_03_07
6/04/18 15:25:15 Updater: download 02_03_07
6/04/18 15:25:36 Updater: Download failed HTTPcode
6/04/18 16:25:37 Updater: Update from 02_03_06 to 02_03_07
6/04/18 16:25:37 Updater: download 02_03_07
6/04/18 16:25:56 Updater: Download failed HTTPcode
6/04/18 17:25:57 Updater: Update from 02_03_06 to 02_03_07
6/04/18 17:25:57 Updater: download 02_03_07
6/04/18 17:26:16 Updater: Download failed HTTPcode
6/04/18 18:26:17 Updater: Update from 02_03_06 to 02_03_07
6/04/18 18:26:18 Updater: download 02_03_07
6/04/18 18:26:41 Updater: Download failed HTTPcode
6/04/18 19:26:42 Updater: Update from 02_03_06 to 02_03_07
6/04/18 19:26:42 Updater: download 02_03_07
6/04/18 19:27:01 Updater: Download failed HTTPcode
6/04/18 20:27:02 Updater: Update from 02_03_06 to 02_03_07
6/04/18 20:27:02 Updater: download 02_03_07
6/04/18 20:27:24 Updater: Download failed HTTPcode
6/04/18 21:27:25 Updater: Update from 02_03_06 to 02_03_07
6/04/18 21:27:25 Updater: download 02_03_07
6/04/18 21:27:41 Updater: Download failed HTTPcode
6/04/18 22:27:42 Updater: Update from 02_03_06 to 02_03_07
6/04/18 22:27:42 Updater: download 02_03_07
6/04/18 22:27:59 Updater: Download failed HTTPcode
6/04/18 23:28:00 Updater: Update from 02_03_06 to 02_03_07
6/04/18 23:28:00 Updater: download 02_03_07
6/04/18 23:28:17 Updater: Download failed HTTPcode
6/05/18 00:28:18 Updater: Update from 02_03_06 to 02_03_07
6/05/18 00:28:18 Updater: download 02_03_07
6/05/18 00:28:36 Updater: Download failed HTTPcode
6/05/18 01:28:37 Updater: Update from 02_03_06 to 02_03_07
6/05/18 01:28:37 Updater: download 02_03_07
6/05/18 01:28:59 Updater: Download failed HTTPcode
6/05/18 02:29:01 Updater: Update from 02_03_06 to 02_03_07
6/05/18 02:29:01 Updater: download 02_03_07
6/05/18 02:29:39 Updater: Download failed HTTPcode
6/05/18 03:29:40 Updater: Update from 02_03_06 to 02_03_07
6/05/18 03:29:40 Updater: download 02_03_07
6/05/18 03:30:01 Updater: Download failed HTTPcode
6/05/18 04:30:02 Updater: Update from 02_03_06 to 02_03_07
6/05/18 04:30:02 Updater: download 02_03_07
6/05/18 04:30:19 Updater: Download failed HTTPcode
6/05/18 05:30:20 Updater: Update from 02_03_06 to 02_03_07
6/05/18 05:30:20 Updater: download 02_03_07
6/05/18 05:30:38 Updater: Download failed HTTPcode
6/05/18 06:30:39 Updater: Update from 02_03_06 to 02_03_07
6/05/18 06:30:39 Updater: download 02_03_07
6/05/18 06:30:56 Updater: Download failed HTTPcode
6/05/18 07:30:57 Updater: Update from 02_03_06 to 02_03_07
6/05/18 07:30:57 Updater: download 02_03_07
6/05/18 07:31:15 Updater: Download failed HTTPcode
6/05/18 08:31:16 checkUpdate: Invalid response from server.
6/05/18 09:31:17 Updater: Update from 02_03_06 to 02_03_07
6/05/18 09:31:17 Updater: download 02_03_07
6/05/18 09:31:34 Updater: Download failed HTTPcode
6/05/18 10:31:35 Updater: Update from 02_03_06 to 02_03_07
6/05/18 10:31:35 Updater: download 02_03_07
6/05/18 10:31:56 Updater: Download failed HTTPcode
6/05/18 11:31:57 Updater: Update from 02_03_06 to 02_03_07
6/05/18 11:31:57 Updater: download 02_03_07
6/05/18 11:32:21 Updater: Download failed HTTPcode
6/05/18 12:32:22 Updater: Update from 02_03_06 to 02_03_07
6/05/18 12:32:22 Updater: download 02_03_07
6/05/18 12:32:38 Updater: Download failed HTTPcode
6/05/18 13:32:39 Updater: Update from 02_03_06 to 02_03_07
6/05/18 13:32:39 Updater: download 02_03_07
6/05/18 13:32:55 Updater: Download failed HTTPcode
6/05/18 14:32:56 Updater: Update from 02_03_06 to 02_03_07
6/05/18 14:32:56 Updater: download 02_03_07
6/05/18 14:33:13 Updater: Download failed HTTPcode
6/05/18 15:33:15 Updater: Update from 02_03_06 to 02_03_07
6/05/18 15:33:15 Updater: download 02_03_07
6/05/18 15:33:32 Updater: Download failed HTTPcode
6/05/18 16:33:33 Updater: Update from 02_03_06 to 02_03_07
6/05/18 16:33:33 Updater: download 02_03_07
6/05/18 16:33:52 Updater: Download failed HTTPcode
6/05/18 17:33:53 Updater: Update from 02_03_06 to 02_03_07
6/05/18 17:33:53 Updater: download 02_03_07
6/05/18 17:34:10 Updater: Download failed HTTPcode
6/05/18 18:34:12 Updater: Update from 02_03_06 to 02_03_07
6/05/18 18:34:12 Updater: download 02_03_07
6/05/18 18:34:29 Updater: Download failed HTTPcode
6/05/18 19:34:30 Updater: Update from 02_03_06 to 02_03_07
6/05/18 19:34:30 Updater: download 02_03_07
6/05/18 19:34:46 Updater: Download failed HTTPcode
6/05/18 20:34:47 Updater: Update from 02_03_06 to 02_03_07
6/05/18 20:34:47 Updater: download 02_03_07
6/05/18 20:35:06 Updater: Download failed HTTPcode
6/05/18 21:35:07 Updater: Update from 02_03_06 to 02_03_07
6/05/18 21:35:07 Updater: download 02_03_07
6/05/18 21:35:27 Updater: Download failed HTTPcode
6/05/18 22:3\B5:29 UpdavEr: Uptate frOm 02_03_06 tg 02_03_07
6/05/18 22:35:29 Updater\BA do\F7nload 02_03_07
6/05/18$22:35:43 Updcter: Download failed HTTPcode
\B6/0u/10 27:35:44 Updater: Upatm fro\ED 02_3_07 to 02_03O07 6/05/18 23:5:4 Updat\E5r: download 02_03_07 6/0%/18 23:36:02 Updater: Downloal failld HTTPcode 6/06/\B18 02:32:03 Epdater:!Update \E6rm$02_03_06\00to 02_03]07 6/06/18 00::6:03 Updater: download 22_03_17 6/06/18 00:36:37 Updat%r: Download fa\E9led HTTPcode 6/06/1< 01:#6:38 Updatar: Update from 0203_07 ~o 02_03_07 6/06/18 01:36:38 Upda|er: download 02_03_07 J6/04/18 01:36:5u Uqdater: Download failed HTTPcode 6/06/18 02:36:56 Updater: Uxdate from 02_03_06 tk 02_03_0? 6/06/18 02:36:56 Upfaver: dgwndoad 02_0307 6/06/18 02:37:15 UpDqter: Download failed HTTPcode 6/06/18 03:37:16 Updater: UpdaTe from 02_03\DF06 to 02_03_07 6/06/18 03:37:16 Updater: downloaD 0:_03_07 7/06/18 03:37>36 Updater: Download failed HTTPcode 6/06/18 04:26:360timeSinc: adjusting RTCby -2
6/06/18 04:3’:37 Updater; Utd!te from 02_03_06 to 02_03_07
6/06/18 04:37:37 Updater: download 02_03_07
6/06/18 04:37:54 Updater: Download failed HTTPcode
6/06/18 05:37:55 Updater: Update from 02_03_06 to 02_03_07
6/06/18 05:37:55 Updater: download 02_03_07
6/06/18 05:38:14 Updater: Download failed HTTPcode
6/06/18 06:38:15 Updater: Update from 02_03_06 to 02_03_07
6/06/18 06:38:15 Updater: download 02_03_07
6/06/18 06:38:36 Updater: Download failed HTTPcode
6/06/18 07:38:37 Updater: Update from 02_03_06 to 02_03_07
6/06/18 07:38:37 Updater: download 02_03_07
6/06/18 07:38:52 Updater: Download failed HTTPcode
6/06/18 08:38:53 Updater: Update from 02_03_06 to 02_03_07
6/06/18 08:38:53 Updater: download 02_03_07
6/06/18 08:39:10 Updater: Download failed HTTPcode
6/06/18 09:39:11 Updater: Update from 02_03_06 to 02_03_07
6/06/18 09:39:11 Updater: download 02_03_07
6/06/18 09:39:30 Updater: Download failed HTTPcode
6/06/18 10:39:32 Updater: Update from 02_03_06 to 02_03_07
6/06/18 10:39:32 Updater: download 02_03_07
6/06/18 10:39:52 Updater: Download failed HTTPcode
6/06/18 11:39:53 Updater: Update from 02_03_06 to 02_03_07
6/06/18 11:39:53 Updater: download 02_03_07
6/06/18 11:40:11 Updater: Download failed HTTPcode
6/06/18 12:40:12 Updater: Update from 02_03_06 to 02_03_07
6/06/18 12:40:12 Updater: download 02_03_07
6/06/18 12:40:30 Updater: Download failed HTTPcode
6/06/18 13:40:31 Updater: Update from 02_03_06 to 02_03_07
6/06/18 13:40:31 Updater: download 02_03_07
6/06/18 13:40:47 Updater: Download failed HTTPcode
6/06/18 14:40:49 Updater: Update from 02_03_06 to 02_03_07
6/06/18 14:40:49 Updater: download 02_03_07
6/06/18 14:41:06 Updater: Download failed HTTPcode
6/06/18 15:41:07 Updater: Update from 02_03_06 to 02_03_07
6/06/18 15:41:07 Updater: download 02_03_07
6/06/18 15:41:23 Updater: Download failed HTTPcode
6/06/18 16:41:24 Updater: Update from 02_03_06 to 02_03_07
6/06/18 16:41:24 Updater: download 02_03_07
6/06/18 16:41:47 Updater: Download failed HTTPcode
6/06/18 17:41:48 Updater: Update from 02_03_06 to 02_03_07
6/06/18 17:41:48 Updater: download 02_03_07
6/06/18 17:42:05 Updater: Download failed HTTPcode
6/06/18 18:42:06 Updater: Update from 02_03_06 to 02_03_07
6/06/18 18:42:06 Updater: download 02_03_07
6/06/18 18:42:27 Updater: Download failed HTTPcode
6/06/18 19:42:28 Updater: Update from 02_03_06 to 02_03_07
6/06/18 19:42:28 Updater: download 02_03_07
6/06/18 19:42:50 Updater: Download failed HTTPcode
6/06/18 20:42:51 Updater: Update from 02_03_06 to 02_03_07
6/06/18 20:42:51 Updater: download 02_03_07
6/06/18 20:43:16 Updater: Download failed HTTPcode
6/06/18 21:43:17 Updater: Update from 02_03_06 to 02_03_07
6/06/18 21:43:17 Updater: download 02_03_07
6/06/18 21:43:36 Updater: Download failed HTTPcode
6/06/18 22:43:37 Updater: Update from 02_03_06 to 02_03_07
6/06/18 22:43:37 Updater: download 02_03_07
6/06/18 22:43:53 Updater: Download failed HTTPcode
6/06/18 23:43:54 Updater: Update from 02_03_06 to 02_03_07
6/06/18 23:43:54 Updater: download 02_03_07
6/06/18 23:44:17 Updater: Download failed HTTPcode
6/07/18 00:44:18 Updater: Update from 02_03_06 to 02_03_07
6/07/18 00:44:18 Updater: download 02_03_07
6/07/18 00:44:36 Updater: Download failed HTTPcode
6/07/18 01:44:37 Updater: Update from 02_03_06 to 02_03_07
6/07/18 01:44:37 Updater: download 02_03_07
6/07/18 01:44:53 Updater: Download failed HTTPcode
6/07/18 02:44:54 Updater: Update from 02_03_06 to 02_03_07
6/07/18 02:44:54 Updater: download 02_03_07
6/07/18 02:45:15 Updater: Download failed HTTPcode
6/07/18 03:45:16 Updater: Update from 02_03_06 to 02_03_07
6/07/18 03:45:16 Updater: download 02_03_07
6/07/18 03:45:32 Updater: Download failed HTTPcode
6/07/18 04:45:33 Updater: Update from 02_03_06 to 02_03_07
6/07/18 04:45:33 Updater: download 02_03_07
6/07/18 04:45:50 Updater: Download failed HTTPcode
6/07/18 05:45:51 Updater: Update from 02_03_06 to 02_03_07
6/07/18 05:45:51 Updater: download 02_03_07
6/07/18 05:46:14 Updater: Download failed HTTPcode
6/07/18 06:46:15 Updater: Update from 02_03_06 to 02_03_07
6/07/18 06:46:15 Updater: download 02_03_07
6/07/18 06:46:35 Updater: Download failed HTTPcode
6/07/18 07:46:36 Updater: Update from 02_03_06 to 02_03_07
6/07/18 07:46:36 Updater: download 02_03_07
6/07/18 07:46:53 Updater: Download failed HTTPcode
6/07/18 08:46:54 Updater: Update from 02_03_06 to 02_03_07
6/07/18 08:46:54 Updater: download 02_03_07
6/07/18 08:47:24 Updater: Download failed HTTPcode
6/07/18 09:47:25 Updater: Update from 02_03_06 to 02_03_07
6/07/18 09:47:25 Updater: download 02_03_07
6/07/18 09:47:41 Updater: Download failed HTTPcode
6/07/18 10:47:42 Updater: Update from 02_03_06 to 02_03_07
6/07/18 10:47:42 Updater: download 02_03_07
6/07/18 10:48:01 Updater: Download failed HTTPcode
6/07/18 11:48:02 Updater: Update from 02_03_06 to 02_03_07
6/07/18 11:48:02 Updater: download 02_03_07
6/07/18 11:48:21 Updater: Download failed HTTPcode
6/07/18 12:48:22 Updater: Update from 02_03_06 to 02_03_07
6/07/18 12:48:22 Updater: download 02_03_07
6/07/18 12:48:48 Updater: Download failed HTTPcode
6/07/18 13:48:50 Updater: Update from 02_03_06 to 02_03_07
6/07/18 13:48:50 Updater: download 02_03_07
6/07/18 13:49:10 Updater: Download failed HTTPcode
6/07/18 14:49:11 Updater: Update from 02_03_06 to 02_03_07
6/07/18 14:49:11 Updater: download 02_03_07
6/07/18 14:49:26 Updater: Download failed HTTPcode
6/07/18 15:49:28 Updater: Update from 02_03_06 to 02_03_07
6/07/18 15:49:28 Updater: download 02_03_07
6/07/18 15:49:44 Updater: Download failed HTTPcode
6/07/18 16:49:46 Updater: Update from 02_03_06 to 02_03_07
6/07/18 16:49:46 Updater: download 02_03_07
6/07/18 16:50:02 Updater: Download failed HTTPcode
6/07/18 17:50:03 Updater: Update from 02_03_06 to 02_03_07
6/07/18 17:50:03 Updater: download 02_03_07
6/07/18 17:50:20 Updater: Download failed HTTPcode
6/07/18 18:50:21 Updater: Update from 02_03_06 to 02_03_07
6/07/18 18:50:21 Updater: download 02_03_07
6/07/18 18:50:38 Updater: Download failed HTTPcode
6/07/18 19:27:24 timeSync: adjusting RTC by -2
6/07/18 19:50:39 Updater: Update from 02_03_06 to 02_03_07
6/07/18 19:50:39 Updater: download 02_03_07
6/07/18 19:50:56 Updater: Download failed HTTPcode
6/07/18 20:50:57 Updater: Update from 02_03_06 to 02_03_07
6/07/18 20:50:57 Updater: download 02_03_07
6/07/18 20:51:20 Updater: Download failed HTTPcode
6/07/18 21:51:21 Updater: Update from 02_03_06 to 02_03_07
6/07/18 21:51:21 Updater: download 02_03_07
6/07/18 21:51:37 Updater: Download failed HTTPcode
6/07/18 22:51:38 Updater: Update from 02_03_06 to 02_03_07
6/07/18 22:51:38 Updater: download 02_03_07
6/07/18 22:52:01 Updater: Download failed HTTPcode
6/07/18 23:52:02 Updater: Update from 02_03_06 to 02_03_07
6/07/18 23:52:02 Updater: download 02_03_07
6/07/18 23:52:19 Updater: Download failed HTTPcode
6/08/18 00:52:20 Updater: Update from 02_03_06 to 02_03_07
6/08/18 00:52:20 Updater: download 02_03_07
6/08/18 00:52:38 Updater: Download failed HTTPcode
6/08/18 01:52:39 Updater: Update from 02_03_06 to 02_03_07
6/08/18 01:52:39 Updater: download 02_03_07
6/08/18 01:52:59 Updater: Download failed HTTPcode
6/08/18 02:53:01 Updater: Update from 02_03_06 to 02_03_07
6/08/18 02:53:01 Updater: download 02_03_07
6/08/18 02:53:18 Updater: Download failed HTTPcode
6/08/18 03:53:19 Updater: Update from 02_03_06 to 02_03_07
6/08/18 03:53:19 Updater: download 02_03_07
6/08/18 03:53:34 Updater: Download failed HTTPcode
6/08/18 04:53:35 Updater: Update from 02_03_06 to 02_03_07
6/08/18 04:53:35 Updater: download 02_03_07
6/08/18 04:53:52 Updater: Download failed HTTPcode
6/08/18 05:53:53 Updater: Update from 02_03_06 to 02_03_07
6/08/18 05:53:53 Updater: download 02_03_07
6/08/18 05:54:10 Updater: Download failed HTTPcode
6/08/18 06:54:11 Updater: Update from 02_03_06 to 02_03_07
6/08/18 06:54:11 Updater: download 02_03_07
6/08/18 06:54:28 Updater: Download failed HTTPcode
6/08/18 07:54:29 Updater: Update from 02_03_06 to 02_03_07
6/08/18 07:54:29 Updater: download 02_03_07
6/08/18 07:54:45 Updater: Download failed HTTPcode
6/08/18 08:54:46 Updater: Update from 02_03_06 to 02_03_07
6/08/18 08:54:46 Updater: download 02_03_07
6/08/18 08:55:05 Updater: Download failed HTTPcode
6/08/18 09:55:06 Updater: Update from 02_03_06 to 02_03_07
6/08/18 09:55:06 Updater: download 02_03_07
6/08/18 09:55:22 Updater: Download failed HTTPcode
6/08/18 10:55:23 Updater: Update from 02_03_06 to 02_03_07
6/08/18 10:55:23 Updater: download 02_03_07
6/08/18 10:55:40 Updater: Download failed HTTPcode
6/08/18 11:55:41 Updater: Update from 02_03_06 to 02_03_07
6/08/18 11:55:41 Updater: download 02_03_07
6/08/18 11:56:01 Updater: Download failed HTTPcode
6/08/18 12:56:02 Updater: Update from 02_03_06 to 02_03_07
6/08/18 12:56:02 Updater: download 02_03_07
6/08/18 12:56:22 Updater: Download failed HTTPcode
6/08/18 13:56:23 Updater: Update from 02_03_06 to 02_03_07
6/08/18 13:56:23 Updater: download 02_03_07
6/08/18 13:56:42 Updater: Download failed HTTPcode
6/08/18 14:56:43 Updater: Update from 02_03_06 to 02_03_07
6/08/18 14:56:43 Updater: download 02_03_07
6/08/18 14:56:59 Updater: Download failed HTTPcode
6/08/18 15:57:00 Updater: Update from 02_03_06 to 02_03_07
6/08/18 15:57:00 Updater: download 02_03_07
6/08/18 15:57:17 Updater: Download failed HTTPcode
6/08/18 16:57:18 Updater: Update from 02_03_06 to 02_03_07
6/08/18 16:57:18 Updater: download 02_03_07
6/08/18 16:57:40 Updater: Download failed HTTPcode
6/08/18 17:57:41 Updater: Update from 02_03_06 to 02_03_07
6/08/18 17:57:41 Updater: download 02_03_07
6/08/18 17:57:57 Updater: Download failed HTTPcode
6/08/18 18:57:58 Updater: Update from 02_03_06 to 02_03_07
6/08/18 18:57:58 Updater: download 02_03_07
6/08/18 18:58:17 Updater: Download failed HTTPcode
6/08/18 19:58:18 Updater: Update from 02_03_06 to 02_03_07
6/08/18 19:58:18 Updater: download 02_03_07
6/08/18 19:58:34 Updater: Download failed HTTPcode
6/08/18 20:58:35 Updater: Update from 02_03_06 to 02_03_07
6/08/18 20:58:35 Updater: download 02_03_07
6/08/18 20:58:53 Updater: Download failed HTTPcode
6/08/18 21:58:54 Updater: Update from 02_03_06 to 02_03_07
6/08/18 21:58:54 Updater: download 02_03_07
6/08/18 21:59:13 Updater: Download failed HTTPcode
6/08/18 22:59:14 Updater: Update from 02_03_06 to 02_03_07
6/08/18 22:59:14 Updater: download 02_03_07
6/08/18 22:59:43 Updater: Download failed HTTPcode
6/08/18 23:59:44 Updater: Update from 02_03_06 to 02_03_07
6/08/18 23:59:44 Updater: download 02_03_07
6/09/18 00:00:06 Updater: Download failed HTTPcode
6/09/18 01:00:07 Updater: Update from 02_03_06 to 02_03_07
6/09/18 01:00:07 Updater: download 02_03_07
6/09/18 01:00:27 Updater: Download failed HTTPcode
6/09/18 02:00:28 Updater: Update from 02_03_06 to 02_03_07
6/09/18 02:00:28 Updater: download 02_03_07
6/09/18 02:00:45 Updater: Download failed HTTPcode
6/09/18 03:00:46 Updater: Update from 02_03_06 to 02_03_07
6/09/18 03:00:46 Updater: download 02_03_07
6/09/18 03:01:08 Updater: Download failed HTTPcode
6/09/18 04:01:09 Updater: Update from 02_03_06 to 02_03_07
6/09/18 04:01:09 Updater: download 02_03_07
6/09/18 04:01:27 Updater: Download failed HTTPcode
6/09/18 05:01:28 Updater: Update from 02_03_06 to 02_03_07
6/09/18 05:01:28 Updater: download 02_03_07
6/09/18 05:01:45 Updater: Download failed HTTPcode
6/09/18 06:01:46 Updater: Update from 02_03_06 to 02_03_07
6/09/18 06:01:46 Updater: download 02_03_07
6/09/18 06:02:06 Updater: Download failed HTTPcode
6/09/18 07:02:07 Updater: Update from 02_03_06 to 02_03_07
6/09/18 07:02:07 Updater: download 02_03_07
6/09/18 07:02:24 Updater: Download failed HTTPcode
6/09/18 08:02:25 Updater: Update from 02_03_06 to 02_03_07
6/09/18 08:02:25 Updater: download 02_03_07
6/09/18 08:02:41 Updater: Download failed HTTPcode
6/09/18 09:02:42 Updater: Update from 02_03_06 to 02_03_07
6/09/18 09:02:42 Updater: download 02_03_07
6/09/18 09:02:59 Updater: Download failed HTTPcode
6/09/18 10:03:00 Updater: Update from 02_03_06 to 02_03_07
6/09/18 10:03:00 Updater: download 02_03_07
6/09/18 10:03:16 Updater: Download failed HTTPcode
6/09/18 11:03:17 Updater: Update from 02_03_06 to 02_03_07
6/09/18 11:03:17 Updater: download 02_03_07
6/09/18 11:03:35 Updater: Download failed HTTPcode
6/09/18 12:03:36 Updater: Update from 02_03_06 to 02_03_07
6/09/18 12:03:36 Updater: download 02_03_07
6/09/18 12:03:52 Updater: Download failed HTTPcode
6/09/18 13:03:53 Updater: Update from 02_03_06 to 02_03_07
6/09/18 13:03:53 Updater: download 02_03_07
6/09/18 13:04:12 Updater: Download failed HTTPcode
6/09/18 14:04:13 Updater: Update from 02_03_06 to 02_03_07
6/09/18 14:04:13 Updater: download 02_03_07
6/09/18 14:04:31 Updater: Download failed HTTPcode
6/09/18 15:04:32 Updater: Update from 02_03_06 to 02_03_07
6/09/18 15:04:32 Updater: download 02_03_07
6/09/18 15:04:49 Updater: Download failed HTTPcode
6/09/18 16:04:50 Updater: Update from 02_03_06 to 02_03_07
6/09/18 16:04:50 Updater: download 02_03_07
6/09/18 16:05:05 Updater: Download failed HTTPcode
6/09/18 17:05:06 Updater: Update from 02_03_06 to 02_03_07
6/09/18 17:05:06 Updater: download 02_03_07
6/09/18 17:05:24 Updater: Download failed HTTPcode
6/09/18 17:27:46 timeSync: adjusting RTC by -2
6/09/18 18:05:25 Updater: Update from 02_03_06 to 02_03_07
6/09/18 18:05:25 Updater: download 02_03_07
6/09/18 18:05:42 Updater: Download failed HTTPcode
6/09/18 19:05:43 Updater: Update from 02_03_06 to 02_03_07
6/09/18 19:05:43 Updater: download 02_03_07
6/09/18 19:06:00 Updater: Download failed HTTPcode
6/09/18 20:06:01 Updater: Update from 02_03_06 to 02_03_07
6/09/18 20:06:01 Updater: download 02_03_07
6/09/18 20:06:16 Updater: Download failed HTTPcode
6/09/18 21:06:17 Updater: Update from 02_03_06 to 02_03_07
6/09/18 21:06:17 Updater: download 02_03_07
6/09/18 21:06:33 Updater: Download failed HTTPcode
6/09/18 22:06:34 Updater: Update from 02_03_06 to 02_03_07
6/09/18 22:06:34 Updater: download 02_03_07
6/09/18 22:06:50 Updater: Download failed HTTPcode
6/09/18 23:06:52 Updater: Update from 02_03_06 to 02_03_07
6/09/18 23:06:52 Updater: download 02_03_07
6/09/18 23:07:16 Updater: Download failed HTTPcode
6/10/18 00:07:17 Updater: Update from 02_03_06 to 02_03_07
6/10/18 00:07:17 Updater: download 02_03_07
6/10/18 00:07:34 Updater: Download failed HTTPcode
6/10/18 01:07:35 Updater: Update from 02_03_06 to 02_03_07
6/10/18 01:07:35 Updater: download 02_03_07
6/10/18 01:07:52 Updater: Download failed HTTPcode
6/10/18 02:07:53 Updater: Update from 02_03_06 to 02_03_07
6/10/18 02:07:53 Updater: download 02_03_07
6/10/18 02:08:10 Updater: Download failed HTTPcode
6/10/18 03:08:12 Updater: Update from 02_03_06 to 02_03_07
6/10/18 03:08:12 Updater: download 02_03_07
6/10/18 03:08:28 Updater: Download failed HTTPcode
6/10/18 04:08:29 Updater: Update from 02_03_06 to 02_03_07
6/10/18 04:08:29 Updater: download 02_03_07
6/10/18 04:08:45 Updater: Download failed HTTPcode
6/10/18 05:08:46 Updater: Update from 02_03_06 to 02_03_07
6/10/18 05:08:46 Updater: download 02_03_07
6/10/18 05:09:04 Updat
#6
It’s not an Arduino and I don’t have a Linux system to determine what tools you would need. It would be far easier if you just send me the box.
Iotawatt, inc.
PO Box 1679
Wolfeboro, NH 03894
USA
