Hi Bob,
I had my system on the ALPHA channel (I know, living on the edge!), and a day or so ago, it updated itself to 02_03_02. At that point, it stopped posting to a local emoncms server, with endless errors in the log:
EmonService: response not ok. Retrying.
It looks like you’ve added the ability to post to both emoncms & to InfluxDB - which I would indeed like to try!
I did try reverting to the BETA channel, but I get an error:
Update file format error.
Here’s the bottom of my current log:
No clock yet: SD initialized.
3/27/18 15:56:24 Real Time Clock is running. Unix time: 1522166184
3/27/18 15:56:24 Version: 02_03_02
3/27/18 15:56:24 Reset reason: Software Watchdog
3/27/18 15:56:24 Trace: 3:6, 3:6, 9:4, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5, 1:6, 1:1, 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:4, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5, 3:0, 3:6, 3:6, 1:6, 1:3, 1:4, 1:5, 3:0
3/27/18 15:56:24 ESP8266 ChipID:2870702
3/27/18 08:56:24 device name: IotaWatt, version: 3
3/27/18 08:56:24 Local time zone: -7
3/27/18 08:56:24 MDNS responder started
3/27/18 08:56:24 You can now connect to http://IotaWatt.local
3/27/18 08:56:24 HTTP server started
3/27/18 08:56:24 dataLog: service started.
3/27/18 08:56:25 dataLog: Last log entry:1522166155
3/27/18 08:56:25 statService: started.
3/27/18 08:56:25 timeSync: service started.
3/27/18 08:56:25 WiFi connected. SSID: BLACKBURN, IP: 192.168.2.45
3/27/18 08:56:25 Updater: started.
3/27/18 08:56:25 historyLog: service started.
3/27/18 08:56:26 historyLog: Last log entry:1522166160
3/27/18 08:56:26 EmonService: started.url: 192.168.2.44:80/emoncms, node: IotaWatt, post interval: 10, unsecure GET
3/27/18 08:56:27 EmonService: Start posting at 1522049640
3/27/18 08:56:27 Updater: Update from 02_03_02 to 02_03_01
3/27/18 08:56:27 Updater: download 02_03_01
3/27/18 08:56:40 Updater: Release downloaded 12754ms, size 591460
3/27/18 08:56:42 Update file format error.
3/27/18 08:56:46 EmonService: response not ok. Retrying.
3/27/18 08:56:47 EmonService: response not ok. Retrying.
3/27/18 08:56:48 EmonService: response not ok. Retrying.
3/27/18 08:56:49 EmonService: response not ok. Retrying.
3/27/18 08:56:50 EmonService: response not ok. Retrying.
3/27/18 08:56:51 EmonService: response not ok. Retrying.
3/27/18 08:56:52 EmonService: response not ok. Retrying.
Thanks!
Sandy
