user$ curl http://192.168.10.10/iotawatt/iotamsgs.txt?textpos=-10000
1/22/19 16:32:07 WiFi connected. SSID=****, IP=192.168.10.10, channel=6, RSSI -40db
1/22/19 16:32:08 Updater: service started. Auto-update class is MINOR
1/22/19 16:32:09 dataLog: service started.
1/22/19 16:32:10 dataLog: New current log created.
1/22/19 21:32:15z Real Time Clock is running. Unix time 1548192735
1/22/19 21:32:16z Version 02_03_18
1/22/19 21:32:16z Reset reason: Software Watchdog
1/22/19 21:32:17z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:32:19z ESP8266 ChipID: 191732
1/22/19 21:32:20z SPIFFS mounted.
1/22/19 16:32:22 EmonService: Invalid configuration.
1/22/19 16:32:22 Local time zone: -5
1/22/19 16:32:23 device name: , version: 3
1/22/19 16:32:24 MDNS responder started for hostname ****
1/22/19 16:32:25 LLMNR responder started for hostname ****
1/22/19 16:32:26 HTTP server started
1/22/19 16:32:27 timeSync: service started.
1/22/19 16:32:27 statService: started.
1/22/19 16:32:28 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -42db
1/22/19 16:32:29 Updater: service started. Auto-update class is MINOR
1/22/19 16:32:30 dataLog: service started.
1/22/19 16:32:31 dataLog: New current log created.
1/22/19 21:32:36z Real Time Clock is running. Unix time 1548192756
1/22/19 21:32:37z Version 02_03_18
1/22/19 21:32:37z Reset reason: Software Watchdog
1/22/19 21:32:38z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:32:40z ESP8266 ChipID: 191732
1/22/19 21:32:41z SPIFFS mounted.
1/22/19 16:32:43 EmonService: Invalid configuration.
1/22/19 16:32:43 Local time zone: -5
1/22/19 16:32:44 device name: , version: 3
1/22/19 16:32:45 MDNS responder started for hostname ****
1/22/19 16:32:46 LLMNR responder started for hostname ****
1/22/19 16:32:47 HTTP server started
1/22/19 16:32:48 timeSync: service started.
1/22/19 16:32:48 statService: started.
1/22/19 16:32:49 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -40db
1/22/19 16:32:50 Updater: service started. Auto-update class is MINOR
1/22/19 16:32:51 dataLog: service started.
1/22/19 16:32:52 dataLog: New current log created.
1/22/19 21:32:57z Real Time Clock is running. Unix time 1548192777
1/22/19 21:32:58z Version 02_03_18
1/22/19 21:32:58z Reset reason: Software Watchdog
1/22/19 21:32:59z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:33:01z ESP8266 ChipID: 191732
1/22/19 21:33:02z SPIFFS mounted.
1/22/19 16:33:04 EmonService: Invalid configuration.
1/22/19 16:33:04 Local time zone: -5
1/22/19 16:33:05 device name: , version: 3
1/22/19 16:33:06 MDNS responder started for hostname ****
1/22/19 16:33:07 LLMNR responder started for hostname ****
1/22/19 16:33:08 HTTP server started
1/22/19 16:33:09 timeSync: service started.
1/22/19 16:33:12 statService: started.
1/22/19 16:33:13 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -41db
1/22/19 16:33:14 Updater: service started. Auto-update class is MINOR
1/22/19 16:33:15 dataLog: service started.
1/22/19 16:33:16 dataLog: New current log created.
1/22/19 21:33:22z Real Time Clock is running. Unix time 1548192802
1/22/19 21:33:23z Version 02_03_18
1/22/19 21:33:23z Reset reason: Software Watchdog
1/22/19 21:33:24z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:33:26z ESP8266 ChipID: 191732
1/22/19 21:33:27z SPIFFS mounted.
1/22/19 16:33:29 EmonService: Invalid configuration.
1/22/19 16:33:29 Local time zone: -5
1/22/19 16:33:30 device name: , version: 3
1/22/19 16:33:31 MDNS responder started for hostname ****
1/22/19 16:33:32 LLMNR responder started for hostname ****
1/22/19 16:33:33 HTTP server started
1/22/19 16:33:34 timeSync: service started.
1/22/19 16:33:34 statService: started.
1/22/19 16:33:35 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -40db
1/22/19 16:33:36 Updater: service started. Auto-update class is MINOR
1/22/19 16:33:37 dataLog: service started.
1/22/19 16:33:38 dataLog: New current log created.
1/22/19 21:33:43z Real Time Clock is running. Unix time 1548192823
1/22/19 21:33:44z Version 02_03_18
1/22/19 21:33:44z Reset reason: Software Watchdog
1/22/19 21:33:45z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:33:47z ESP8266 ChipID: 191732
1/22/19 21:33:48z SPIFFS mounted.
1/22/19 16:33:50 EmonService: Invalid configuration.
1/22/19 16:33:50 Local time zone: -5
1/22/19 16:33:51 device name: , version: 3
1/22/19 16:33:52 MDNS responder started for hostname ****
1/22/19 16:33:53 LLMNR responder started for hostname ****
1/22/19 16:33:54 HTTP server started
1/22/19 16:33:55 timeSync: service started.
1/22/19 16:33:55 statService: started.
1/22/19 16:33:56 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -41db
1/22/19 16:33:57 Updater: service started. Auto-update class is MINOR
1/22/19 16:33:58 dataLog: service started.
1/22/19 16:33:59 dataLog: New current log created.
1/22/19 21:34:04z Real Time Clock is running. Unix time 1548192844
1/22/19 21:34:05z Version 02_03_18
1/22/19 21:34:05z Reset reason: Software Watchdog
1/22/19 21:34:06z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:34:08z ESP8266 ChipID: 191732
1/22/19 21:34:09z SPIFFS mounted.
1/22/19 16:34:11 EmonService: Invalid configuration.
1/22/19 16:34:11 Local time zone: -5
1/22/19 16:34:12 device name: , version: 3
1/22/19 16:34:13 MDNS responder started for hostname ****
1/22/19 16:34:14 LLMNR responder started for hostname ****
1/22/19 16:34:15 HTTP server started
1/22/19 16:34:16 timeSync: service started.
1/22/19 16:34:16 statService: started.
1/22/19 16:34:17 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -41db
1/22/19 16:34:18 Updater: service started. Auto-update class is MINOR
1/22/19 16:34:19 dataLog: service started.
1/22/19 16:34:20 dataLog: New current log created.
1/22/19 21:34:25z Real Time Clock is running. Unix time 1548192865
1/22/19 21:34:26z Version 02_03_18
1/22/19 21:34:26z Reset reason: Software Watchdog
1/22/19 21:34:27z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:34:29z ESP8266 ChipID: 191732
1/22/19 21:34:30z SPIFFS mounted.
1/22/19 16:34:32 EmonService: Invalid configuration.
1/22/19 16:34:32 Local time zone: -5
1/22/19 16:34:33 device name: , version: 3
1/22/19 16:34:34 MDNS responder started for hostname ****
1/22/19 16:34:35 LLMNR responder started for hostname ****
1/22/19 16:34:36 HTTP server started
1/22/19 16:34:41 timeSync: service started.
1/22/19 16:34:42 statService: started.
1/22/19 16:34:43 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -41db
1/22/19 16:34:44 Updater: service started. Auto-update class is MINOR
1/22/19 16:34:50 dataLog: service started.
1/22/19 16:34:50 dataLog: New current log created.
1/22/19 21:34:55z Real Time Clock is running. Unix time 1548192895
1/22/19 21:34:56z Version 02_03_18
1/22/19 21:34:56z Reset reason: Software Watchdog
1/22/19 21:34:57z Trace: 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:13, 1:4, 1:5[19]
1/22/19 21:34:59z ESP8266 ChipID: 191732
1/22/19 21:35:00z SPIFFS mounted.
1/22/19 16:35:02 EmonService: Invalid configuration.
1/22/19 16:35:02 Local time zone: -5
1/22/19 16:35:03 device name: , version: 3
1/22/19 16:35:04 MDNS responder started for hostname ****
1/22/19 16:35:05 LLMNR responder started for hostname ****
1/22/19 16:35:06 HTTP server started
1/22/19 16:35:07 timeSync: service started.
1/22/19 16:35:07 statService: started.
1/22/19 16:35:08 WiFi connected. SSID=, IP=192.168.10.10, channel=6, RSSI -41db
1/22/19 16:35:09 Updater: service started. Auto-update class is MINOR
1/22/19 16:35:10 dataLog: service started.
1/22/19 16:35:11 dataLog: New current log created.
1/22/19 21:35:17z Real Time Clock is running. Unix time 1548192917
1/22/19 21:35:18z Version 02_03_18
1/22/19 21:35:18z Reset reason: Software Watchdog
1/22/19 21:35:19z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
1/22/19 21:35:21z ESP8266 ChipID: 191732
1/22/19 21:35:22z SPIFFS mounted.
1/22/19 16:35:24 EmonService: Invalid configuration.
1/22/19 16:35:24 Local time zone: -5
1/22/19 16:35:25 device name: ****, version: 3
1/22/19 16:35:26 MDNS responder started for hostname ****
1/22/19 16:35:27 LLMNR responder started for hostname ****
1/22/19 16:35:28 HTTP server started
