Iotawatt self-reboots often and then influxdb doesn't restart automatically (since latest MINOR release)
Since release 02_03_20, I have iotawatt self-rebooting from time to time for “Heap memory has degraded below safe minimum, restarting”, and then additionally influxdb stops working, but emoncms continues working. Here the logs:
Here latest status message in Status/influxdb: (and that time is not correct, latest status was 1/20/2019 02:38:00.
Stopped, Last update 12/29/2018 12:00:00 AM
while EmonCMS status is running:
Running, Last update 1/20/2019 7:28:10 PM
Here the full logs since installation end of last year. Notice how since update, it self-restarts often, and how each time i have to re-save the influxdb settings to restart it (this time hit the Start button and it started fine, adding latest logs as second quotation):
`12/28/18 23:38:55 dataLog: service started.
12/28/18 23:38:55 dataLog: Last log entry 12/28/18 19:07:15
12/28/18 23:38:55 historyLog: service started.
12/28/18 23:38:55 historyLog: Last log entry 12/28/18 19:07:00
12/28/18 23:39:07 Updater: Auto-update is current for class MINOR.
12/29/18 16:05:46 EmonService: started. url=10.2.0.200:9092, node=IotaWatt, interval=10
12/29/18 16:05:47 EmonService: Node doesn’t yet exist.
12/29/18 16:05:47 EmonService: Start posting at 12/29/18 00:00:10
12/29/18 17:58:20 EmonService: HTTP response -4, retrying.
12/29/18 17:58:27 EmonService: Retry successful after 15 attempts.
12/29/18 18:03:53 EmonService: HTTP response -4, retrying.
12/29/18 18:03:53 EmonService: Retry successful after 3 attempts.
12/29/18 21:51:19 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
12/29/18 21:51:20 influxDB: Start posting at 12/29/18 00:00:10
12/30/18 23:53:13 EmonService: HTTP response -14, retrying.
12/30/18 23:57:00 influxDB: Post Failed: -4
12/31/18 00:04:04 EmonService: Retry successful after 49 attempts.
1/01/19 01:39:30 EmonService: HTTP response -4, retrying.
1/01/19 01:39:42 EmonService: Retry successful after 19 attempts.
1/01/19 02:33:40 EmonService: HTTP response -4, retrying.
1/01/19 02:34:26 EmonService: Retry successful after 34 attempts.
1/01/19 02:57:10 EmonService: HTTP response -4, retrying.
1/01/19 02:57:50 EmonService: Retry successful after 32 attempts.
1/01/19 22:13:22 EmonService: HTTP response -4, retrying.
1/01/19 22:14:47 EmonService: Retry successful after 7 attempts.
1/02/19 18:50:02 Updater: Update from 02_03_18 to 02_03_20
1/02/19 18:50:02 Updater: download 02_03_20
1/02/19 18:50:15 Updater: Release downloaded 13374ms, size 660192
1/02/19 18:50:24 Updater: Update downloaded and signature verified
1/02/19 18:50:30 Updater: firmware upgraded to version 02_03_20
1/02/19 18:50:30 Firmware updated, restarting.
1/02/19 17:50:37z Real Time Clock is running. Unix time 1546451437
1/02/19 17:50:37z Version 02_03_20
1/02/19 17:50:37z Updater: Installing update files for version 02_03_20
1/02/19 17:50:37z Updater: Installing GRAPH.HTM
1/02/19 17:50:37z Updater: Installing GRAPH.JS
1/02/19 17:50:37z Updater: Installing INDEX.HTM
1/02/19 17:50:38z Updater: Installing TABLES.TXT
1/02/19 17:50:38z Updater: Installing CNFSTYLE.CSS
1/02/19 17:50:38z Updater: Installing EDIT.HTM
1/02/19 17:50:38z Updater: Installation complete.
1/02/19 17:50:38z Reset reason: Software/System restart
1/02/19 17:50:38z Trace: 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5]
1/02/19 17:50:38z ESP8266 ChipID: 8529514
1/02/19 17:50:39z SPIFFS mounted.
1/02/19 18:50:40 Local time zone: +1:00
1/02/19 18:50:40 device name: IotaWatt
1/02/19 18:50:40 MDNS responder started for hostname IotaWatt
1/02/19 18:50:40 LLMNR responder started for hostname IotaWatt
1/02/19 18:50:40 HTTP server started
1/02/19 18:50:40 WiFi connected. SSID=Bruyere, IP=10.1.0.219, channel=2, RSSI -79db
1/02/19 18:50:40 timeSync: service started.
1/02/19 18:50:40 statService: started.
1/02/19 18:50:40 Updater: service started. Auto-update class is MINOR
1/02/19 18:50:40 dataLog: service started.
1/02/19 18:50:40 dataLog: Last log entry 01/02/19 18:50:15
1/02/19 18:50:40 historyLog: service started.
1/02/19 18:50:40 historyLog: Last log entry 01/02/19 18:50:00
1/02/19 18:50:42 Updater: Auto-update is current for class MINOR.
1/02/19 18:50:45 EmonService: started. url=10.2.0.200:9092, node=IotaWatt, interval=10
1/02/19 18:50:45 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
1/02/19 18:50:46 EmonService: Start posting at 01/02/19 18:50:10
1/02/19 18:50:46 influxDB: Start posting at 01/02/19 18:50:10
1/12/19 22:51:42 EmonService: HTTP response -4, retrying.
1/12/19 22:52:00 influxDB: Post Failed: -4
1/13/19 02:18:23 EmonService: Retry successful after 501 attempts.
1/13/19 21:58:59 EmonService: HTTP response -11, retrying.
1/13/19 21:58:59 EmonService: Retry successful after 3 attempts.
1/14/19 02:27:25 EmonService: HTTP response -4, retrying.
1/14/19 02:28:50 EmonService: Retry successful after 7 attempts.
1/18/19 18:57:41 Heap memory has degraded below safe minimum, restarting.
1/18/19 17:57:43z Real Time Clock is running. Unix time 1547834263
1/18/19 17:57:43z Version 02_03_20
1/18/19 17:57:43z Reset reason: Software/System restart
1/18/19 17:57:43z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[21]
1/18/19 17:57:43z ESP8266 ChipID: 8529514
1/18/19 17:57:43z SPIFFS mounted.
1/18/19 18:57:44 Local time zone: +1:00
1/18/19 18:57:44 device name: IotaWatt
1/18/19 18:57:44 MDNS responder started for hostname IotaWatt
1/18/19 18:57:44 LLMNR responder started for hostname IotaWatt
1/18/19 18:57:44 HTTP server started
1/18/19 18:57:44 WiFi connected. SSID=Bruyere, IP=10.1.0.219, channel=2, RSSI -92db
1/18/19 18:57:44 timeSync: service started.
1/18/19 18:57:44 statService: started.
1/18/19 18:57:44 Updater: service started. Auto-update class is MINOR
1/18/19 18:57:44 dataLog: service started.
1/18/19 18:57:44 dataLog: Last log entry 01/18/19 18:57:40
1/18/19 18:57:44 historyLog: service started.
1/18/19 18:57:44 historyLog: Last log entry 01/18/19 18:57:00
1/18/19 18:57:46 Updater: Auto-update is current for class MINOR.
1/18/19 18:57:49 EmonService: started. url=10.2.0.200:9092, node=IotaWatt, interval=10
1/18/19 18:57:49 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
1/18/19 18:57:55 EmonService: Start posting at 01/18/19 18:57:40
1/18/19 18:57:58 influxDB: Start posting at 01/18/19 18:57:00
1/18/19 19:03:54 Heap memory has degraded below safe minimum, restarting.
1/18/19 18:03:56z Real Time Clock is running. Unix time 1547834636
1/18/19 18:03:56z Version 02_03_20
1/18/19 18:03:56z Reset reason: Software/System restart
1/18/19 18:03:56z Trace: 1:5[7], 7:0, 7:9, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:9, 1:6, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[7], 7:0, 7:9, 1:6, 1:3, 1:4, 1:5[21]
1/18/19 18:03:56z ESP8266 ChipID: 8529514
1/18/19 18:03:56z SPIFFS mounted.
1/18/19 19:03:57 Local time zone: +1:00
1/18/19 19:03:57 device name: IotaWatt
1/18/19 19:03:57 MDNS responder started for hostname IotaWatt
1/18/19 19:03:57 LLMNR responder started for hostname IotaWatt
1/18/19 19:03:57 HTTP server started
1/18/19 19:03:57 timeSync: service started.
1/18/19 19:03:58 statService: started.
1/18/19 19:03:58 dataLog: service started.
1/18/19 19:03:58 dataLog: Last log entry 01/18/19 19:03:50
1/18/19 19:03:58 historyLog: service started.
1/18/19 19:03:58 historyLog: Last log entry 01/18/19 19:03:00
1/18/19 19:04:02 EmonService: started. url=10.2.0.200:9092, node=IotaWatt, interval=10
1/18/19 19:04:02 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
1/18/19 19:05:08 WiFi connected. SSID=Bruyere, IP=10.1.0.219, channel=2, RSSI -94db
1/18/19 19:05:08 Updater: service started. Auto-update class is MINOR
1/18/19 19:05:12 EmonService: Start posting at 01/18/19 19:04:00
1/18/19 19:05:16 Updater: Auto-update is current for class MINOR.
1/18/19 19:05:45 influxDB: last entry query failed: -11
1/18/19 19:05:45 influxDB: Stopped. Last post 01/18/19 19:03:20
1/18/19 19:47:10 EmonService: HTTP response -4, retrying.
1/18/19 19:47:33 EmonService: Retry successful after 4 attempts.
1/18/19 19:49:18 EmonService: HTTP response -11, retrying.
1/18/19 19:49:18 EmonService: Retry successful after 3 attempts.
1/19/19 01:57:03 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
1/19/19 01:57:04 influxDB: Start posting at 01/18/19 19:03:30
1/20/19 02:41:06 Heap memory has degraded below safe minimum, restarting.
1/20/19 01:41:08z Real Time Clock is running. Unix time 1547948468
1/20/19 01:41:08z Version 02_03_20
1/20/19 01:41:08z Reset reason: Software/System restart
1/20/19 01:41:08z Trace: 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[21]
1/20/19 01:41:08z ESP8266 ChipID: 8529514
1/20/19 01:41:08z SPIFFS mounted.
1/20/19 02:41:09 Local time zone: +1:00
1/20/19 02:41:09 device name: IotaWatt
1/20/19 02:41:09 MDNS responder started for hostname IotaWatt
1/20/19 02:41:09 LLMNR responder started for hostname IotaWatt
1/20/19 02:41:09 HTTP server started
1/20/19 02:41:09 WiFi connected. SSID=Bruyere, IP=10.1.0.219, channel=2, RSSI -92db
1/20/19 02:41:09 timeSync: service started.
1/20/19 02:41:09 statService: started.
1/20/19 02:41:09 Updater: service started. Auto-update class is MINOR
1/20/19 02:41:09 dataLog: service started.
1/20/19 02:41:09 dataLog: Last log entry 01/20/19 02:41:05
1/20/19 02:41:09 historyLog: service started.
1/20/19 02:41:09 historyLog: Last log entry 01/20/19 02:41:00
1/20/19 02:41:14 EmonService: started. url=10.2.0.200:9092, node=IotaWatt, interval=10
1/20/19 02:41:14 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10
1/20/19 02:41:20 EmonService: Start posting at 01/20/19 02:41:10
1/20/19 02:41:28 influxDB: last entry query failed: -11
1/20/19 02:41:28 influxDB: Stopped. Last post 12/29/18 00:00:00
1/20/19 02:41:32 Updater: Invalid response from server. HTTPcode: -4
1/20/19 03:01:13 EmonService: HTTP response -11, retrying.
1/20/19 03:01:17 EmonService: Retry successful after 3 attempts.
1/20/19 03:41:14 Updater: Auto-update is current for class MINOR.
1/20/19 19:34:59 influxDB: started, url=10.2.0.200:8086, db=bruyere, interval=10 1/20/19 19:35:00 influxDB: Start posting at 01/20/19 02:40:30
Any idea why it self-restarts so often ?
And why influxdb doesn’t auto-restart, while emonCMS does ?
There are two issues here:
The restarts due to heap degradation is characteristic of a lot of WiFi error recovery. The memory leak is hard to nail down and I think it happens in a lower part of the IP stack that I have no control over. These things don’t happen with strong WiFi. Id suggest you use one of the mainstream channels 1, 6, 11 and sometimes 4 works OK.
The problem with influx stopping is caused by WiFi errors, but the recovery isn’t robust enough. The new release 02_03_21 due out in ALPHA this week has improvements in that area that I expect will resolve that if the WiFi can be improved somewhat.
Thank you for your quick reply and planed improvement. The IotaWatt works awesome, other than this reboot and influxdb reconnect issue!
Wifi is indeed not very strong but not super-weak either in the basement. Will see if/how I can improve. An Ethernet connection or wired external USB-Ethernet adapter (as I understand no solution available at this stage?) would solve issue best in terms of connectivity and absence of electromagnetic radiations (electro-smog).
