Using Honeywell CT cslt6b100 for current readings
Hi All,
Has anyone been able to connect the Honeywell CSLT6b100 for current readings to their IoTaWatt unit?
I have dozen of them from another power system (SEGmeter) already fitted with 3.5mm jacks… and although I bought the standard CT from the IoTaWatt store, they are just big to safely fit into fuse board…
I can connect the CSLT6b100 with issues but try as I might, I cannot pick up ‘any’ readings… and datasheet (below) doesn’t state how many turns or phase the CTs are…
Datasheets here:
Any help greatly appreciated…
From a quick scan of the pdf, this product is a Hall Effect device not a current transformer which is why it can read both ac & dc currents. A current transformer is just that, a transformer, & will only work on ac circuits.
so sounds like it’s no dice at all then …
what’s what was puzzling me we that the old SEGmeter system could use either these CSLT6b100 or the SCT013 CT ammeters (which do work with the IoTA system)… but I can only assume that the inputs on the other system were programmable
Thanks for the heads up… going need to search out some smaller CT’s than stock supply version…
@stevenma is correct. IoTaWatt doesn’t work with hall effect sensors.
Take a close look at the SCT013 CTs that you have. It’s not clear from the old SEG site if those are voltage type or current type. Current type are SCT013-000 and are marked 100A/50mA. The voltage type would be something like 50A/1.0V. Their old website isn’t clear which but says the maximum is 60A, which would suggest a voltage type.
For small solid core CTs, the HWCT-004 or DL CT08CL2 (identical) are a good choice if you are willing to attach leads and a 3.5mm connector. They are good for 50A with IoTaWatt and have very good shift characteristics. 26mm OD, 8.7mm ID, 13mm wide.
#5
OverEasy many thanks for the heads up on the HWCT-004 and the CT08CL2 CT’s, I may give them a go, but I do have one daft question: you mentioned they were small, but do you know what their outer diameter size is (I’ll take inches or mm) and the maximum internal core size is?
I can find details on all the electrical characteristics, but i all the google searches there’s nothing on physical size… (which is really odd). For Australia, the only listing on ebay are from Chinese shipping addresses, so it will take 6 weeks to deliver, so although I can just order 20, so I have plenty spare, but don’t to do that and still find it’s still to tight in the fuse board ( I made that mistake on the IoTaWatt website and ordered solid core CT’s only to find they are just as big as the split CTs)
#6
Dimensions were in my original post:
#7
Sorry! so busy searching Google I didn’t read the full post.
I’m just go ahead and order them and find away to make them fit…
