So you’re saying that subsequent to the above log ending with
4/20/21 08:38:07 influxDB_v1: stopped, Last post 04/20/21 08:36:10
4/20/21 08:38:09 Updater: Auto-update is current for class ALPHA.
4/20/21 08:44:23 influxDB_v2: Start posting 04/20/20 08:44:30
You are seeing data uploaded to influx1 with no subsequent log entries?
Yes. Here is an updated log with IPs left in.
4/20/21 04:10:15z Real Time Clock is running. Unix time 1618891815
4/20/21 04:10:15z Reset reason: Software/System restart
4/20/21 04:10:15z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
4/20/21 04:10:15z ESP8266 ChipID: 6196660
4/20/21 04:10:15z IoTaWatt 5.0, Firmware version 02_06_02
4/20/21 04:10:15z SPIFFS mounted.
4/20/21 14:10:15 Local time zone: +10:00
4/20/21 14:10:15 Using Daylight Saving Time (BST) when in effect.
4/20/21 14:10:15 device name: IoTaWatt
4/20/21 14:10:15 HTTP server started
4/20/21 14:10:15 influxDB_v1: Starting, interval:10, url:http://192.168.1.101:8086
4/20/21 14:10:15 influxDB_v2: Starting, interval:5, url:http://192.168.1.252:8086/api/v2
4/20/21 14:10:15 timeSync: service started.
4/20/21 14:10:15 statService: started.
4/20/21 14:10:16 dataLog: service started.
4/20/21 14:10:18 dataLog: Last log entry 04/20/21 14:10:10
4/20/21 14:10:20 historyLog: service started.
4/20/21 14:10:20 historyLog: Last log entry 04/20/21 14:10:00
4/20/21 14:10:26 WiFi connected. SSID=CRYPT-IOT, IP=192.168.5.230, channel=11, RSSI -72db
4/20/21 14:10:26 MDNS responder started for hostname IoTaWatt
4/20/21 14:10:26 LLMNR responder started for hostname IoTaWatt
4/20/21 14:10:26 Updater: service started. Auto-update class is ALPHA
4/20/21 14:10:48 Updater: Auto-update is current for class ALPHA.
4/20/21 14:10:49 influxDB_v1: Start posting at 04/20/21 14:10:00
Argh!! My fault. IoT VLAN rules preventing communication… Thanks anyway @overeasy, sorry for the runaround.
A big thank you for supporting InfluxDB v2 in in order however!
02_06_02 is BETA auto-update as of 4/26/2021 4:30pm
02_06_02 is MINOR auto-update as of 5/3/2021 18:20 UTC
