Long time ago I created a data uploader, as I wanted to test uploading my data to Influx DB. But I really never used it. This uploader seems to degrade the performance of my iotawatt, so I like to delete or disable it.
In “Setup Data Uploaders” I see an “edit” behind the Influx_DB_v1 in the dropdown. I select that, and clicke the DELETE button at the bottom. The dialog closes right away, but nothing happens, the uploader doesn’t seem to get deleted. Restart doesn’t help either, and the log also shows that the uploader is still running.
Below my log file from the most recent restart.
How can I delete this uploader to improve my overall system performance?
Thanks
Hermann
10/01/21 15:35:33z Real Time Clock is running. Unix time 1633102533
10/01/21 15:35:33z Reset reason: Software/System restart
10/01/21 15:35:33z Trace: 1:3, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
10/01/21 15:35:33z ESP8266 ChipID: 6148248
10/01/21 15:35:33z IoTaWatt 5.0, Firmware version 02_06_05
10/01/21 15:35:33z SPIFFS mounted.
10/01/21 08:35:33 Local time zone: -8:00
10/01/21 08:35:33 Using Daylight Saving Time (BST) when in effect.
10/01/21 08:35:33 device name: IotaWatt
10/01/21 08:35:33 HTTP server started
10/01/21 08:35:33 influxDB_v1: Starting, interval:100, url:http://homeassistant.local:8086
10/01/21 08:35:33 timeSync: service started.
10/01/21 08:35:33 statService: started.
10/01/21 08:35:33 dataLog: service started.
10/01/21 08:35:35 dataLog: Last log entry 10/01/21 08:35:30
10/01/21 08:35:38 historyLog: service started.
10/01/21 08:35:38 historyLog: Last log entry 10/01/21 08:35:00
10/01/21 08:35:38 WiFi connected. SSID=2768-Ortona, IP=192.168.3.53, channel=6, RSSI -73db
10/01/21 08:35:38 MDNS responder started for hostname IotaWatt
10/01/21 08:35:38 LLMNR responder started for hostname IotaWatt
10/01/21 08:35:38 Updater: service started. Auto-update class is MINOR
10/01/21 08:35:45 influxDB_v1: stopped, Last post 02/05/06 22:28:16
10/01/21 08:35:47 Updater: Auto-update is current for class MINOR.
