Hi Bob! Thanks for your great unit.
I’ve been successfully monitoring a 3 phase installation in Australia you previous assisted with. All good for about 12 months. On 6th Sept 2018, 6am (local), the unit stopped sending data to emoncms. It was flashing three green. No problems with my other iotawatt units.
I restarted (ie. power cycled) and got a steady green, and could see it on Wifi. However, its webserver was inaccessible and no data was sent to emoncms. I turned off the WiFi router and could access it via the AP. Tried again on Wifi and then a different Wifi but no luck - still no sending of data or webserver accessibility.
I removed the SD card and have attached the logs. You’ll see a software watchdog reset (9/05/18 21:27) and then my power cycling tests. I’ve attached my config file too. Nothing changed externally at the fail time and the SD card appears ok (since I could read the logs).
I haven’t tried a reset via the AP webserver interface. I’ve been unable to find this problem on the forum.
Can you assist? Thanks again.
Details:
IOTAMSGS and CONFIG.TXT (405.2 KB) combined as I can’t post 2 files.
Dashboard (broken as no logging): https://emoncms.org/dashboard/view&id=46548
Chip ID 1848778 Flash Chip ID 1458376
IDE Flash Size 4194304 bytes Real Flash Size 4194304 bytes
Soft AP IP 192.168.4.1
Soft AP MAC A2:20:A6:1C:35:CA
Station MAC A0:20:A6:1C:35:CA
