3/25/20 06:43:30z ESP8266 ChipID: 6144648
3/25/20 06:43:30z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:30z SPIFFS mounted.
3/25/20 07:43:30 Local time zone: +1:00
3/25/20 07:43:30 device name: IotaWatt
3/25/20 07:43:30 HTTP server started
3/25/20 07:43:30 timeSync: service started.
3/25/20 07:43:30 statService: started.
3/25/20 07:43:30 dataLog: service started.
3/25/20 07:43:31 dataLog: Last log entry 03/25/20 07:43:25
3/25/20 07:43:31 historyLog: service started.
3/25/20 07:43:31 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:43:35 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:43:35 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -57db
3/25/20 07:43:35 Updater: service started. Auto-update class is MINOR
3/25/20 06:43:36z Real Time Clock is running. Unix time 1585118616
3/25/20 06:43:36z Reset reason: Exception
3/25/20 06:43:36z Trace: 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:43:36z ESP8266 ChipID: 6144648
3/25/20 06:43:36z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:36z SPIFFS mounted.
3/25/20 07:43:36 Local time zone: +1:00
3/25/20 07:43:36 device name: IotaWatt
3/25/20 07:43:36 HTTP server started
3/25/20 07:43:36 timeSync: service started.
3/25/20 07:43:36 statService: started.
3/25/20 07:43:36 dataLog: service started.
3/25/20 07:43:37 dataLog: Last log entry 03/25/20 07:43:35
3/25/20 07:43:37 historyLog: service started.
3/25/20 07:43:37 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:43:41 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:43:41 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -56db
3/25/20 07:43:41 Updater: service started. Auto-update class is MINOR
3/25/20 06:43:41z Real Time Clock is running. Unix time 1585118621
3/25/20 06:43:41z Reset reason: Exception
3/25/20 06:43:41z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:43:41z ESP8266 ChipID: 6144648
3/25/20 06:43:41z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:41z SPIFFS mounted.
3/25/20 07:43:41 Local time zone: +1:00
3/25/20 07:43:41 device name: IotaWatt
3/25/20 07:43:41 HTTP server started
3/25/20 07:43:41 timeSync: service started.
3/25/20 07:43:41 statService: started.
3/25/20 07:43:41 dataLog: service started.
3/25/20 07:43:42 dataLog: Last log entry 03/25/20 07:43:40
3/25/20 07:43:42 historyLog: service started.
3/25/20 07:43:42 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:43:46 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:43:46 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -56db
3/25/20 07:43:46 Updater: service started. Auto-update class is MINOR
3/25/20 06:43:47z Real Time Clock is running. Unix time 1585118627
3/25/20 06:43:47z Reset reason: Exception
3/25/20 06:43:47z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:43:47z ESP8266 ChipID: 6144648
3/25/20 06:43:47z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:47z SPIFFS mounted.
3/25/20 07:43:47 Local time zone: +1:00
3/25/20 07:43:47 device name: IotaWatt
3/25/20 07:43:47 HTTP server started
3/25/20 07:43:47 timeSync: service started.
3/25/20 07:43:47 statService: started.
3/25/20 07:43:47 dataLog: service started.
3/25/20 07:43:48 dataLog: Last log entry 03/25/20 07:43:45
3/25/20 07:43:48 historyLog: service started.
3/25/20 07:43:48 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:43:52 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:43:52 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -55db
3/25/20 07:43:52 Updater: service started. Auto-update class is MINOR
3/25/20 06:43:53z Real Time Clock is running. Unix time 1585118633
3/25/20 06:43:53z Reset reason: Exception
3/25/20 06:43:53z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:43:53z ESP8266 ChipID: 6144648
3/25/20 06:43:53z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:53z SPIFFS mounted.
3/25/20 07:43:53 Local time zone: +1:00
3/25/20 07:43:53 device name: IotaWatt
3/25/20 07:43:53 HTTP server started
3/25/20 07:43:53 timeSync: service started.
3/25/20 07:43:53 statService: started.
3/25/20 07:43:53 dataLog: service started.
3/25/20 07:43:54 dataLog: Last log entry 03/25/20 07:43:50
3/25/20 07:43:54 historyLog: service started.
3/25/20 07:43:54 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:43:58 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:43:58 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -56db
3/25/20 07:43:58 Updater: service started. Auto-update class is MINOR
3/25/20 06:43:59z Real Time Clock is running. Unix time 1585118639
3/25/20 06:43:59z Reset reason: Exception
3/25/20 06:43:59z Trace: 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:43:59z ESP8266 ChipID: 6144648
3/25/20 06:43:59z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:43:59z SPIFFS mounted.
3/25/20 07:43:59 Local time zone: +1:00
3/25/20 07:43:59 device name: IotaWatt
3/25/20 07:43:59 HTTP server started
3/25/20 07:43:59 timeSync: service started.
3/25/20 07:43:59 statService: started.
3/25/20 07:43:59 dataLog: service started.
3/25/20 07:44:00 dataLog: Last log entry 03/25/20 07:43:55
3/25/20 07:44:00 historyLog: service started.
3/25/20 07:44:00 historyLog: Last log entry 03/25/20 07:43:00
3/25/20 07:44:04 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:44:04 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -56db
3/25/20 07:44:04 Updater: service started. Auto-update class is MINOR
3/25/20 06:44:05z Real Time Clock is running. Unix time 1585118645
3/25/20 06:44:05z Reset reason: Exception
3/25/20 06:44:05z Trace: 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:44:05z ESP8266 ChipID: 6144648
3/25/20 06:44:05z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:44:05z SPIFFS mounted.
3/25/20 07:44:05 Local time zone: +1:00
3/25/20 07:44:05 device name: IotaWatt
3/25/20 07:44:05 HTTP server started
3/25/20 07:44:05 timeSync: service started.
3/25/20 07:44:05 statService: started.
3/25/20 07:44:05 dataLog: service started.
3/25/20 07:44:06 dataLog: Last log entry 03/25/20 07:44:00
3/25/20 07:44:06 historyLog: service started.
3/25/20 07:44:06 historyLog: Last log entry 03/25/20 07:44:00
3/25/20 07:44:10 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:44:11 WiFi connected. SSID=Xxx, IP=192.168.2.7, channel=11, RSSI -57db
3/25/20 07:44:11 Updater: service started. Auto-update class is MINOR
3/25/20 06:44:12z Real Time Clock is running. Unix time 1585118652
3/25/20 06:44:12z Reset reason: Exception
3/25/20 06:44:12z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[3], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:44:12z ESP8266 ChipID: 6144648
3/25/20 06:44:12z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:44:12z SPIFFS mounted.
3/25/20 07:44:12 Local time zone: +1:00
3/25/20 07:44:12 device name: IotaWatt
3/25/20 07:44:12 HTTP server started
3/25/20 07:44:12 timeSync: service started.
3/25/20 07:44:12 statService: started.
3/25/20 07:44:12 dataLog: service started.
3/25/20 07:44:13 dataLog: Last log entry 03/25/20 07:44:10
3/25/20 07:44:13 historyLog: service started.
3/25/20 07:44:13 historyLog: Last log entry 03/25/20 07:44:00
3/25/20 07:44:17 EmonService: started. url=https://emoncms.org, node=IotaWatt, interval=5, encrypted
3/25/20 07:44:17 WiFi connected. SSID=xxx, IP=192.168.2.7, channel=11, RSSI -57db
3/25/20 07:44:17 Updater: service started. Auto-update class is MINOR
3/25/20 06:44:17z Real Time Clock is running. Unix time 1585118657
3/25/20 06:44:17z Reset reason: Exception
3/25/20 06:44:17z Trace: 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[5], 5:0, 5:1, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:3, 21:100[3], 21:101, 3:3, 3:3
3/25/20 06:44:17z ESP8266 ChipID: 6144648
3/25/20 06:44:17z IoTaWatt 5.0, Firmware version 02_05_05
3/25/20 06:44:17z SPIFFS mounted.
3/25/20 07:44:17 Local time zone: +1:00
3/25/20 07:44:17 device name: IotaWatt
3/25/20 07:44:17 HTTP server started
3/25/20 07:44:17 timeSync: service started.
3/25/20 07:44:17 statService: started.
3/25/20 07:44:17 dataLog: service started.
3/25/20 07:44:18 dataLog: Last log entry 03/25/20 07:44:15
3/25/20 07:44:18 historyLog: service started.
3/25/20 07:44:18 historyLog: Last log entry 03/25/20 07:44:00
This is the entire message log. There is nothing there.
