I can get those special order from Echun in China. Usually takes about three weeks. They have 55mm with up to 1,000A rating and 80mm with up to 1,600 A rating. Based on old quotes they would be in the range of $150 each. PM if you are interested.
Typically such a service is a bundle of several smaller cables. If that’s the case, you can divide and conquer using several 400A or 600A (x 35mm). Each would require an input on the IoTaWatt. I have those in stock.
