The main led was solid green - although under flourescent lights it appears to have a fast flicker to it.
Craig
Craig
Solid green is running and sampling. Next time it happens, can you restart it by pressing the little restart button next to the usb connector, then after it has restarted, post the log?
will do - will keep an eye on it more closely
Craig
Still going strong at the moment Bob so who knows - will continue to monitor
Craig
No news is good news.
Not so fast !!
OK been running fine since the last report.
Went to the unit today to do some graphing (graph+) and it locked up
Went and had a look at tthe unit (still with the case off)
1 green, 2 red flashes (quite slow)
Pressed the Reset button for 1s and after about 10 seconds the same 1 green 2 red.
WIll try and 2nd time and wait until i hear back from your
Craig
OK left it for 10 minutes - no change still green red red
Did another reset with the onboard button - same thing
Pulled the power and re connected and it came up straight away
Log attached
8/10/21 03:03:32 device name: IotaWatt
8/10/21 03:03:32 HTTP server started
8/10/21 03:03:32 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/10/21 03:03:32 timeSync: service started.
8/10/21 03:03:32 statService: started.
8/10/21 03:03:32 dataLog: service started.
8/10/21 03:03:33 dataLog: Last log entry 08/10/21 02:58:30
8/10/21 03:03:37 historyLog: service started.
8/10/21 03:03:37 historyLog: Last log entry 08/10/21 02:58:00
8/09/21 17:08:46z Real Time Clock is running. Unix time 1628528926
8/09/21 17:08:46z Power failure detected.
8/09/21 17:08:46z Reset reason: External System
8/09/21 17:08:46z ESP8266 ChipID: 6346788
8/09/21 17:08:46z IoTaWatt 5.0, Firmware version 02_06_05
8/09/21 17:08:46z SPIFFS mounted.
8/10/21 03:08:46 Local time zone: +10:00
8/10/21 03:08:46 Using Daylight Saving Time (BST) when in effect.
8/10/21 03:08:46 device name: IotaWatt
8/10/21 03:08:49 Connecting with WiFiManager.
8/10/21 03:08:54 HTTP server started
8/10/21 03:08:54 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/10/21 03:08:54 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -75db
8/10/21 03:08:54 MDNS responder started for hostname IotaWatt
8/10/21 03:08:54 LLMNR responder started for hostname IotaWatt
8/10/21 03:08:54 timeSync: service started.
8/10/21 03:08:54 statService: started.
8/10/21 03:08:54 Updater: service started. Auto-update class is MINOR
8/10/21 03:08:54 influxDB_v1: stopped, Last post 08/10/21 02:57:40
8/10/21 03:08:54 dataLog: service started.
8/10/21 03:08:55 dataLog: Last log entry 08/10/21 03:03:35
8/10/21 03:08:59 historyLog: service started.
8/10/21 03:08:59 historyLog: Last log entry 08/10/21 03:01:00
8/10/21 03:08:59 Updater: Auto-update is current for class MINOR.
8/09/21 17:09:08z Real Time Clock is running. Unix time 1628528948
8/09/21 17:09:08z Power failure detected.
8/09/21 17:09:08z Reset reason: External System
8/09/21 17:09:08z ESP8266 ChipID: 6346788
8/09/21 17:09:08z IoTaWatt 5.0, Firmware version 02_06_05
8/09/21 17:09:08z SPIFFS mounted.
8/10/21 03:09:08 Local time zone: +10:00
8/10/21 03:09:08 Using Daylight Saving Time (BST) when in effect.
8/10/21 03:09:08 device name: IotaWatt
8/10/21 03:09:11 Connecting with WiFiManager.
8/10/21 03:09:16 HTTP server started
8/10/21 03:09:16 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/10/21 03:09:16 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -70db
8/10/21 03:09:16 MDNS responder started for hostname IotaWatt
8/10/21 03:09:16 LLMNR responder started for hostname IotaWatt
8/10/21 03:09:16 timeSync: service started.
8/10/21 03:09:16 statService: started.
8/10/21 03:09:16 Updater: service started. Auto-update class is MINOR
8/10/21 03:09:16 influxDB_v1: stopped, Last post 08/10/21 02:57:40
8/10/21 03:09:16 dataLog: service started.
8/10/21 03:09:17 dataLog: Last log entry 08/10/21 03:09:00
8/10/21 03:09:17 Updater: Auto-update is current for class MINOR.
8/10/21 03:09:21 historyLog: service started.
8/10/21 03:09:21 historyLog: Last log entry 08/10/21 03:09:00
8/10/21 10:10:02 Table file parse failed.
8/10/21 06:55:45z Real Time Clock is running. Unix time 1628578545
8/10/21 06:55:45z Power failure detected.
8/10/21 06:55:45z Reset reason: External System
8/10/21 06:55:45z ESP8266 ChipID: 6346788
8/10/21 06:55:45z IoTaWatt 5.0, Firmware version 02_06_05
8/10/21 06:55:45z SPIFFS mounted.
8/10/21 16:55:45 Local time zone: +10:00
8/10/21 16:55:45 Using Daylight Saving Time (BST) when in effect.
8/10/21 16:55:45 device name: IotaWatt
8/10/21 16:55:48 Connecting with WiFiManager.
8/10/21 16:55:53 HTTP server started
8/10/21 16:55:53 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/10/21 16:55:53 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -74db
8/10/21 16:55:53 MDNS responder started for hostname IotaWatt
8/10/21 16:55:53 LLMNR responder started for hostname IotaWatt
8/10/21 16:55:53 timeSync: service started.
8/10/21 16:55:53 statService: started.
8/10/21 16:55:53 Updater: service started. Auto-update class is MINOR
8/10/21 16:55:53 Table file parse failed.
8/10/21 16:55:53 influxDB_v1: stopped, Last post 08/10/21 02:57:40
8/10/21 16:55:53 dataLog: service started.
8/10/21 16:55:53 dataLog: New current log created.
8/10/21 16:55:55 Updater: Auto-update is current for class MINOR.
8/10/21 16:55:55 Updater: update tables from invalid to 0.0.2
8/10/21 16:56:56 historyLog: service started.
8/10/21 16:56:56 historyLog: first entry 08/10/21 16:56:00
8/16/21 04:02:06z Real Time Clock is running. Unix time 1629086526
8/16/21 04:02:06z Power failure detected.
8/16/21 04:02:06z Reset reason: External System
8/16/21 04:02:06z ESP8266 ChipID: 6346788
8/16/21 04:02:06z IoTaWatt 5.0, Firmware version 02_06_05
8/16/21 04:02:06z SPIFFS mounted.
8/16/21 14:02:06 Local time zone: +10:00
8/16/21 14:02:06 Using Daylight Saving Time (BST) when in effect.
8/16/21 14:02:06 device name: IotaWatt
8/16/21 14:02:09 Connecting with WiFiManager.
8/16/21 14:02:14 HTTP server started
8/16/21 14:02:14 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/16/21 14:02:14 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -68db
8/16/21 14:02:14 MDNS responder started for hostname IotaWatt
8/16/21 14:02:14 LLMNR responder started for hostname IotaWatt
8/16/21 14:02:14 timeSync: service started.
8/16/21 14:02:14 statService: started.
8/16/21 14:02:14 Updater: service started. Auto-update class is MINOR
8/16/21 14:02:14 dataLog: service started.
8/16/21 14:02:14 dataLog: Last log entry 08/11/21 15:48:15
8/16/21 14:02:14 influxDB_v1: stopped, Last post 08/10/21 16:55:50
8/16/21 14:02:16 Updater: Auto-update is current for class MINOR.
8/16/21 14:02:19 historyLog: service started.
8/16/21 14:02:19 historyLog: Last log entry 08/11/21 15:48:00
8/19/21 02:53:16z Real Time Clock is running. Unix time 1629341596
8/19/21 02:53:16z Power failure detected.
8/19/21 02:53:16z Reset reason: Power On
8/19/21 02:53:16z ESP8266 ChipID: 6346788
8/19/21 02:53:16z IoTaWatt 5.0, Firmware version 02_06_05
8/19/21 02:53:16z SPIFFS mounted.
8/19/21 12:53:16 Local time zone: +10:00
8/19/21 12:53:16 Using Daylight Saving Time (BST) when in effect.
8/19/21 12:53:16 device name: IotaWatt
8/19/21 12:53:19 Connecting with WiFiManager.
8/19/21 12:55:27 Did not connect after power-fail. Restarting to reset WiFi.
8/19/21 02:55:29z Real Time Clock is running. Unix time 1629341729
8/19/21 02:55:29z Reset reason: Software/System restart
8/19/21 02:55:29z Trace: 11:21, 11:22, 11:21, 11:22, 11:21, 11:22, 11:20[4], 11:20[5], 11:20[6], 11:20[7], 11:25, 11:30, 11:31, 11:30, 11:35, 31:100, 31:100, 31:100, 31:100, 31:101, 31:102, 32:101, 32:101, 32:102, 32:103, 32:103, 31:105, 31:105, 31:106, 11:40, 11:45, 11:70
8/19/21 02:55:29z ESP8266 ChipID: 6346788
8/19/21 02:55:29z IoTaWatt 5.0, Firmware version 02_06_05
8/19/21 02:55:29z SPIFFS mounted.
8/19/21 12:55:29 Local time zone: +10:00
8/19/21 12:55:29 Using Daylight Saving Time (BST) when in effect.
8/19/21 12:55:29 device name: IotaWatt
8/19/21 12:55:29 HTTP server started
8/19/21 12:55:29 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/19/21 12:55:29 timeSync: service started.
8/19/21 12:55:29 statService: started.
8/19/21 12:55:29 dataLog: service started.
8/19/21 12:55:29 dataLog: Last log entry 08/19/21 11:10:20
8/19/21 12:55:33 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=4, RSSI -66db
8/19/21 12:55:33 MDNS responder started for hostname IotaWatt
8/19/21 12:55:33 LLMNR responder started for hostname IotaWatt
8/19/21 12:55:33 Updater: service started. Auto-update class is MINOR
8/19/21 12:55:38 historyLog: service started.
8/19/21 12:55:38 historyLog: Last log entry 08/19/21 11:10:00
8/19/21 12:55:46 Updater: Invalid response from server. HTTPcode: -4
8/19/21 12:55:46 influxDB_v1: stopped, Last post 08/10/21 16:55:50
8/19/21 12:55:49 WiFi disconnected.
8/19/21 12:56:10 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=4, RSSI -68db
8/19/21 13:55:36 Updater: Auto-update is current for class MINOR.
8/21/21 03:59:31 Table file parse failed.
8/21/21 04:59:38 Updater: update tables from invalid to 0.0.2
8/24/21 02:50:39z Real Time Clock is running. Unix time 1629773439
8/24/21 02:50:39z Power failure detected.
8/24/21 02:50:39z Reset reason: External System
8/24/21 02:50:39z ESP8266 ChipID: 6346788
8/24/21 02:50:39z IoTaWatt 5.0, Firmware version 02_06_05
8/24/21 02:50:39z SPIFFS mounted.
8/24/21 12:50:39 Local time zone: +10:00
8/24/21 12:50:39 Using Daylight Saving Time (BST) when in effect.
8/24/21 12:50:39 device name: IotaWatt
8/24/21 12:50:42 Connecting with WiFiManager.
8/24/21 12:50:47 HTTP server started
8/24/21 12:50:47 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/24/21 12:50:47 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=4, RSSI -79db
8/24/21 12:50:47 MDNS responder started for hostname IotaWatt
8/24/21 12:50:47 LLMNR responder started for hostname IotaWatt
8/24/21 12:50:47 timeSync: service started.
8/24/21 12:50:47 statService: started.
8/24/21 12:50:47 Updater: service started. Auto-update class is MINOR
8/24/21 12:50:48 dataLog: service started.
8/24/21 12:50:48 dataLog: Last log entry 08/24/21 12:16:10
8/24/21 12:50:48 influxDB_v1: stopped, Last post 08/10/21 16:55:50
8/24/21 12:50:50 Updater: Auto-update is current for class MINOR.
8/24/21 12:50:52 historyLog: service started.
8/24/21 12:50:52 historyLog: Last log entry 08/24/21 12:16:00
Let me know what you think
Craig
Just to back-up a little here, am I right that you put a brand new SDcard into this unit?
Yes it is a new card
Why are you thinking it is a card issue again ?
I have another brand new 64GB card sitting here in the packaging for a RPi project that i could replace it with if you think that will make a difference.
Craig
Maybe. What has me wondering is that pressing reset does not clear the card condition, but power cycle does. Pressing the reset button does not restart the card, because it remains powered up. Power cycle will cause the card to restart, and that seems to get it working.
This doesnât seem to fit the profile of a bad SDsocket.
Youâre going to have to reformat that card anyway to use in the Rpi, so yeah, can you give it a try? Make sure itâs FAT32 before you load it.
Yep will do a little later today and report back
Craig
Bob just a follow up on this
The unit has been running fine since Aug 25 when i replaced the SD card.
It has now faild again.
Initially it was showing Green, Red Red and not available on the network
I pulled the power removed the SD card and reseated it.
Now it is just flashing 3 red flashes.
This was a brand new 16GB Sandisk Ultra.
It looks like this unit is killing SD cards somehow.
Actually - not true - i have just removed the SD card and placed it in my laptop and can read the contents fine.
Do you want me to upload any files for you to check out ? Or should i duplicate this to another SD card and try that ?
To recap on this
The unit is about 10 feet away from a WIFI mesh point on our network.
It is powered by a USB plug that provides 2.4 amps that is plugged into a UPS.
Craig
And here is a Shared Google Drive link with the logs from the SD card (i can read it fine on my Computer)
https://drive.google.com/drive/folders/1VlKIm6Pdaa2wNXdHZCKbogRaLY9X-EJE?usp=sharing
Craig
