Hey Bob,
My 2nd IOTAWATT has been flakey for some time. Dropping off the network and unable to be contacted.
I initially put it down to poor network coverage as it is in the basement of our home with the switchboard.
I recently replaced our wifi with a mesh system and placed a mesh repeater in the basement to give better coverage.
I reconfigured the IOTAWATT to connect to that mesh network and it is showing as a good strong signal
I did this change about a week ago and have still been experiencing the same issues - the IOTAWATT stop responding after a period of time.
I have since moved the USB power supply to a new powerboard (this runs off a business grade UPS)
I then replaced the USB power supply and cable and the problem still persists.
It happened yesterday and i powered the unit on and then off and it has happened again this morning
Here is a dump of the log
Any ideas ?
8/07/21 20:09:02 Using Daylight Saving Time (BST) when in effect.
8/07/21 20:09:02 device name: IotaWatt
8/07/21 20:09:02 HTTP server started
8/08/21 07:03:09z Real Time Clock is running. Unix time 1628406189
8/08/21 07:03:09z Power failure detected.
8/08/21 07:03:09z Reset reason: External System
8/08/21 07:03:09z ESP8266 ChipID: 6346788
8/08/21 07:03:09z IoTaWatt 5.0, Firmware version 02_06_02
8/08/21 07:03:09z SPIFFS mounted.
8/08/21 17:03:09 Local time zone: +10:00
8/08/21 17:03:09 Using Daylight Saving Time (BST) when in effect.
8/08/21 17:03:09 device name: IotaWatt
8/08/21 07:03:37z Real Time Clock is running. Unix time 1628406217
8/08/21 07:03:37z Power failure detected.
8/08/21 07:03:37z Reset reason: Power On
8/08/21 07:03:37z ESP8266 ChipID: 6346788
8/08/21 07:03:37z IoTaWatt 5.0, Firmware version 02_06_02
8/08/21 07:03:37z SPIFFS mounted.
8/08/21 17:03:37 Local time zone: +10:00
8/08/21 17:03:37 Using Daylight Saving Time (BST) when in effect.
8/08/21 17:03:37 device name: IotaWatt
8/08/21 17:03:40 Connecting with WiFiManager.
8/08/21 07:03:42z Real Time Clock is running. Unix time 1628406222
8/08/21 07:03:42z Power failure detected.
8/08/21 07:03:42z Reset reason: External System
8/08/21 07:03:42z ESP8266 ChipID: 6346788
8/08/21 07:03:42z IoTaWatt 5.0, Firmware version 02_06_02
8/08/21 07:03:42z SPIFFS mounted.
8/08/21 17:03:42 Local time zone: +10:00
8/08/21 17:03:42 Using Daylight Saving Time (BST) when in effect.
8/08/21 17:03:42 device name: IotaWatt
8/08/21 17:03:45 Connecting with WiFiManager.
8/08/21 17:03:50 HTTP server started
8/08/21 17:03:50 emoncms: Starting, interval:10, url:http://172.16.100.20/emoncms
8/08/21 17:03:50 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/08/21 17:03:50 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -76db
8/08/21 17:03:50 MDNS responder started for hostname IotaWatt
8/08/21 17:03:50 LLMNR responder started for hostname IotaWatt
8/08/21 17:03:50 timeSync: service started.
8/08/21 17:03:50 statService: started.
8/08/21 17:03:50 Updater: service started. Auto-update class is MINOR
8/08/21 17:03:50 dataLog: service started.
8/08/21 17:03:51 dataLog: Last log entry 08/07/21 20:08:55
8/08/21 17:03:51 emoncms: Start posting at 08/07/21 20:08:50
8/08/21 17:03:52 Updater: Update from 02_06_02 to 02_06_05
8/08/21 17:03:52 Updater: download 02_06_05
8/08/21 17:03:56 Updater: Release downloaded 4387ms, size 834296
8/08/21 17:03:56 influxDB_v1: Start posting at 08/07/21 20:08:50
8/08/21 17:03:56 historyLog: service started.
8/08/21 17:03:56 historyLog: Last log entry 08/07/21 20:08:00
8/08/21 17:04:04 Updater: signature verified
8/08/21 17:04:12 Updater: firmware upgraded to version 02_06_05
8/08/21 17:04:12 Updater: Firmware updated, restarting.
8/08/21 07:04:20z Real Time Clock is running. Unix time 1628406260
8/08/21 07:04:20z Reset reason: Software/System restart
8/08/21 07:04:20z Trace: 1:6[4], 14:0, 14:1, 14:2, 14:3, 1:6[6], 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
8/08/21 07:04:20z ESP8266 ChipID: 6346788
8/08/21 07:04:20z IoTaWatt 5.0, Firmware version 02_06_05
8/08/21 07:04:20z Updater: Installing update files for version 02_06_05
8/08/21 07:04:20z Updater: Installing GRAPH.HTM
8/08/21 07:04:20z Updater: Installing GRAPH.JS
8/08/21 07:04:20z Updater: Installing GRAPH2.HTM
8/08/21 07:04:20z Updater: Installing GRAPH2.JS
8/08/21 07:04:20z Updater: Installing INDEX.HTM
8/08/21 07:04:21z Updater: Installing TABLES.TXT
8/08/21 07:04:21z Updater: Installing CNFSTYLE.CSS
8/08/21 07:04:21z Updater: Installing EDIT.HTM
8/08/21 07:04:21z Updater: Installation complete.
8/08/21 07:04:21z SPIFFS mounted.
8/08/21 17:04:21 Local time zone: +10:00
8/08/21 17:04:21 Using Daylight Saving Time (BST) when in effect.
8/08/21 17:04:21 device name: IotaWatt
8/08/21 17:04:22 HTTP server started
8/08/21 17:04:22 emoncms: Starting, interval:10, url:http://172.16.100.20/emoncms
8/08/21 17:04:22 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/08/21 17:04:22 timeSync: service started.
8/08/21 17:04:22 statService: started.
8/08/21 17:04:22 dataLog: service started.
8/08/21 17:04:22 dataLog: Last log entry 08/08/21 17:03:55
8/08/21 17:04:27 historyLog: service started.
8/08/21 17:04:27 historyLog: Last log entry 08/07/21 20:08:00
8/08/21 17:04:28 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -68db
8/08/21 17:04:28 MDNS responder started for hostname IotaWatt
8/08/21 17:04:28 LLMNR responder started for hostname IotaWatt
8/08/21 17:04:28 Updater: service started. Auto-update class is MINOR
8/08/21 17:04:28 emoncms: Start posting at 08/07/21 20:08:50
8/08/21 17:04:29 influxDB_v1: Start posting at 08/07/21 20:08:50
8/08/21 17:04:29 Updater: Auto-update is current for class MINOR.
8/08/21 12:43:05z Real Time Clock is running. Unix time 1628426585
8/08/21 12:43:05z Reset reason: Exception
8/08/21 12:43:05z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
8/08/21 12:43:05z ESP8266 ChipID: 6346788
8/08/21 12:43:05z IoTaWatt 5.0, Firmware version 02_06_05
8/08/21 12:43:05z SPIFFS mounted.
8/08/21 22:43:05 Local time zone: +10:00
8/08/21 22:43:05 Using Daylight Saving Time (BST) when in effect.
8/08/21 22:43:05 device name: IotaWatt
8/08/21 22:43:05 HTTP server started
8/08/21 22:43:05 emoncms: Starting, interval:10, url:http://172.16.100.20/emoncms
8/08/21 22:43:05 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/08/21 22:43:05 timeSync: service started.
8/08/21 22:43:05 statService: started.
8/08/21 22:43:06 dataLog: service started.
8/08/21 22:43:06 dataLog: Last log entry 08/08/21 22:42:50
8/08/21 22:43:10 historyLog: service started.
8/08/21 22:43:10 historyLog: Last log entry 08/08/21 22:42:00
8/08/21 12:43:23z Real Time Clock is running. Unix time 1628426603
8/08/21 12:43:23z Reset reason: Exception
8/08/21 12:43:23z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
8/08/21 12:43:23z ESP8266 ChipID: 6346788
8/08/21 12:43:23z IoTaWatt 5.0, Firmware version 02_06_05
8/08/21 12:43:23z SPIFFS mounted.
8/08/21 22:43:23 Local time zone: +10:00
8/08/21 22:43:23 Using Daylight Saving Time (BST) when in effect.
8/08/21 22:43:23 device name: IotaWatt
8/08/21 22:43:23 HTTP server started
8/08/21 22:43:23 emoncms: Starting, interval:10, url:http://172.16.100.20/emoncms
8/08/21 22:43:23 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/08/21 22:43:23 timeSync: service started.
8/08/21 22:43:23 statService: started.
8/08/21 22:43:23 dataLog: service started.
8/08/21 22:43:24 dataLog: Last log entry 08/08/21 22:43:10
8/08/21 22:43:28 historyLog: service started.
8/08/21 22:43:28 historyLog: Last log entry 08/08/21 22:43:00
8/08/21 22:43:29 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -68db
8/08/21 22:43:29 MDNS responder started for hostname IotaWatt
8/08/21 22:43:29 LLMNR responder started for hostname IotaWatt
8/08/21 22:43:29 Updater: service started. Auto-update class is MINOR
8/08/21 12:43:38z Real Time Clock is running. Unix time 1628426618
8/08/21 12:43:38z Reset reason: Exception
8/08/21 12:43:38z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[3], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
8/08/21 12:43:38z ESP8266 ChipID: 6346788
8/08/21 12:43:38z IoTaWatt 5.0, Firmware version 02_06_05
8/08/21 12:43:38z SPIFFS mounted.
8/08/21 22:43:38 Local time zone: +10:00
8/08/21 22:43:38 Using Daylight Saving Time (BST) when in effect.
8/08/21 22:43:38 device name: IotaWatt
8/09/21 03:42:06z Real Time Clock is running. Unix time 1628480526
8/09/21 03:42:06z Power failure detected.
8/09/21 03:42:06z Reset reason: External System
8/09/21 03:42:06z ESP8266 ChipID: 6346788
8/09/21 03:42:06z IoTaWatt 5.0, Firmware version 02_06_05
8/09/21 03:42:06z SPIFFS mounted.
8/09/21 13:42:06 Local time zone: +10:00
8/09/21 13:42:06 Using Daylight Saving Time (BST) when in effect.
8/09/21 13:42:06 device name: IotaWatt
8/09/21 13:42:09 Connecting with WiFiManager.
8/09/21 13:42:14 HTTP server started
8/09/21 13:42:14 emoncms: Starting, interval:10, url:http://172.16.100.20/emoncms
8/09/21 13:42:14 influxDB_v1: Starting, interval:10, url:http://172.16.100.37:8086
8/09/21 13:42:14 WiFi connected. SSID=CURTIN-MESH, IP=172.16.100.200, channel=10, RSSI -68db
8/09/21 13:42:14 MDNS responder started for hostname IotaWatt
8/09/21 13:42:14 LLMNR responder started for hostname IotaWatt
8/09/21 13:42:14 timeSync: service started.
8/09/21 13:42:14 statService: started.
8/09/21 13:42:14 Updater: service started. Auto-update class is MINOR
8/09/21 13:42:15 dataLog: service started.
8/09/21 13:42:15 dataLog: Last log entry 08/08/21 22:43:25
8/09/21 13:42:15 emoncms: Start posting at 08/08/21 22:42:50
8/09/21 13:42:15 influxDB_v1: Start posting at 08/08/21 22:42:30
8/09/21 13:42:17 Updater: Auto-update is current for class MINOR.
8/09/21 13:42:19 historyLog: service started.
8/09/21 13:42:19 historyLog: Last log entry 08/08/21 22:43:00
