thank you for the additional info (and for all your work on iotawatt- i really love it, and both of my units work perfectly for several months now!).
(and thanks for the clarification on the 15sec resolution- that is what i assumed to be the case, ie a “better” number for the 15 sec polling would be the average over the last 15 sec which the iota-uploader would output ) - but in my case im mainly trying to see if different devices are ON or OFF so a snapshot works for that.
as i said this is rough code below, mostly done by working with chatGPT alot and tweaking what im able to (so I strongly advise anyone against copying and pasting for their own environment).
but below Is what I’m running , and it polls that url/api every 5 seconds via python 2.7 on a Debian OS vm, which manages /runs it as a systemd service (or whatever you call systemctl status myIotaWattPoller).
you can see im using watt thresholds to then tell grafana if my variable speed air-condition unit is running off/low/medium/high - i could do that ALL over in grafana but i prefer this)
one example usage of this data are these which update in realtime (and wo dashboard reloads) over in grafana. i have several grafana dashboards displaying 24/7 on monitors - 1x set via a windows PCs + nativefier (browser app) and some using rasPIs 4b or pi-5’s accessing the dashboard url → a hdmi monitor at full screen): it all works very well and reliably. (im happy to share whatever, just ask/reply here)
(a note on rasPi’s in a un-attended setup - I have a few different use cases for raspberry pis that display XYZ 24/7, I have found that the best way to monitor if a ras-pi is doing what it’s supposed to be doing , is by monitoring bandwidth usage over its network interface. IE: if MB moved over prior 3 minutes drops below 5MB, then restart the service (or just reboot the entire rasPI) - assuming bw usage correlates to whatever your raspberry pie is displaying (like showing grafana dashboards, or displaying CCTV cameras / a VNC client session)
import requests
import time
import socket
import json
from websocket import create_connection, WebSocketConnectionClosedException
from threading import Thread, Event
import subprocess # Added for executing shell commands
GRAPHITE_SERVER = '172.17.69.40' # Replace with your Graphite server
GRAPHITE_PORT = 2003
GRAPHITE_PREFIX = 'telegraphFASTsnmp.iotaWatt.MainPanel' # Replace with your desired prefix
DEBUG = False # Set to True to enable debug mode - Script will only output to console and NOT send to Graphite OR Grafana Live.
GRAFANA_ENABLED = True # Set to True to enable Grafana streaming
SPECIFIED_METRICS = ['outputs.sum_bothMAINs', 'outputs.AC_1stFL_i9', 'inputs.inpt0_Input_0.Vrms', 'outputs.GarageFeed_i13'] # ONLY these will be live streamed to grafana
GRAFANA_LIVE_MEASUREMENTS_URL = 'ws://172.17.69.40:3000/api/live/push/iotaMain' # Grafana WebSocket URL
GRAFANA_API_TOKEN = 'glsa_Vz9qmAATNcXqXXX' # Replace with your Grafana API key
# Below is IOTAWATT URL to pull stats from
STATUS_URL = 'http://10.6.6.243/status?state&inputs&outputs&stats&wifi'
SERIES_URL = 'http://10.6.6.243/query?show=series'
channel_names = {}
stop_event = Event()
# Counters for failed connections
failed_connection_count = 0
MAX_FAILED_CONNECTIONS = 5 # Threshold for restarting the service
def fetch_channel_names():
global channel_names, failed_connection_count
while not stop_event.is_set():
try:
response = requests.get(SERIES_URL, timeout=5)
data = response.json()
series = data['series']
channel_names = {index: series[index]['name'] for index in range(len(series))}
if DEBUG:
print('Fetched channel names:', channel_names)
failed_connection_count = 0 # Reset the counter on success
except requests.RequestException as e:
failed_connection_count += 1
if DEBUG:
print('Error fetching channel names:', e)
if failed_connection_count >= MAX_FAILED_CONNECTIONS:
restart_service()
for _ in range(3 * 60 * 60): # Sleep for 3 hours in 1-second increments
if stop_event.is_set():
break
time.sleep(1)
def is_numeric(value):
try:
float(value)
return True
except ValueError:
return False
def convert_value(value):
if isinstance(value, bool):
return int(value)
if is_numeric(value):
return float(value)
return None
def send_to_graphite(path, value, timestamp):
global failed_connection_count
value = convert_value(value)
if value is None:
return
full_path = '{}.{}'.format(GRAPHITE_PREFIX, path)
message = '{} {} {}\n'.format(full_path, value, timestamp)
message = ' '.join(message.split())
if DEBUG:
print(message)
else:
try:
sock = socket.socket()
sock.settimeout(5) # Added timeout
sock.connect((GRAPHITE_SERVER, GRAPHITE_PORT))
sock.sendall((message + '\n').encode('utf-8'))
sock.close()
failed_connection_count = 0 # Reset on success
except (socket.error, socket.timeout) as e:
if DEBUG:
print('Socket error:', e)
log_error('Socket error: {}'.format(e))
restart_service()
failed_connection_count = 0 # Reset after restarting
def send_to_grafana(metric, value, timestamp, ws):
if value is None:
return # Skip non-numeric data
line_protocol = '{},metric={} value={} {}'.format(GRAPHITE_PREFIX, metric, value, timestamp * 1000000000)
if DEBUG:
print(line_protocol)
else:
try:
ws.send(line_protocol)
except (WebSocketConnectionClosedException, socket.error, socket.timeout) as e:
if DEBUG:
print("WebSocket error: {}, attempting to reconnect".format(e))
ws.close()
try:
ws = create_connection(GRAFANA_LIVE_MEASUREMENTS_URL, header=["Authorization: Bearer {}".format(GRAFANA_API_TOKEN)], timeout=5)
except Exception as e:
if DEBUG:
print("Failed to reconnect WebSocket:", e)
restart_service()
def should_send_to_grafana(metric):
for specified_metric in SPECIFIED_METRICS:
if metric.startswith(specified_metric):
return True
return False
def parse_and_send_data(ws):
if not channel_names:
return
try:
response = requests.get(STATUS_URL, timeout=5)
timestamp = int(time.time())
stats = data['stats']
for key, value in stats.items():
metric = 'stats.{}'.format(key)
send_to_graphite(metric, value, timestamp)
if should_send_to_grafana(metric):
inputs = data['inputs']
for index, input_data in enumerate(inputs):
channel = input_data["channel"]
channel_name = channel_names.get(index, 'channel{}'.format(channel))
for key, value in input_data.items():
if key != 'channel':
metric = 'inputs.inpt{}_{}.{}'.format(channel, channel_name, key)
outputs = data['outputs']
for output_data in outputs:
name = output_data['name']
metric = 'outputs.{}'.format(name)
send_to_graphite(metric, output_data['value'], timestamp)
send_to_grafana(metric, output_data['value'], timestamp, ws)
if 'AC_1stFL_i9' in name:
ac_status_value = output_data['value']
if 0 <= ac_status_value < 400:
ac_status = 0
elif 400 <= ac_status_value < 1200:
ac_status = 1
elif 1200 <= ac_status_value < 4000:
ac_status = 2
else:
ac_status = -1
send_to_graphite('ACs_ON_OFF_Status.AC_1stFL_i9', ac_status, timestamp)
send_to_grafana('ACs_ON_OFF-AC_1stFL_i9', ac_status, timestamp, ws)
wifi = data['wifi']
for key, value in wifi.items():
metric = 'wifi.{}'.format(key)
else:
if DEBUG:
print('Skipping non-numeric wifi data:', metric, value)
if DEBUG:
print('Error fetching data:', e)
restart_service()
time.sleep(5)
def restart_service():
try:
result = subprocess.call(['service', 'iotaWattMAIN_pythonTO_graphite', 'restart'])
if DEBUG:
if result == 0:
print("Service iotaWattMAIN_pythonTO_graphite restarted successfully.")
else:
print("Failed to restart service with exit code: {}".format(result))
if DEBUG:
print("Failed to restart service: {}".format(e))
def main():
if GRAFANA_ENABLED and not DEBUG:
try:
if DEBUG:
print("Failed to establish WebSocket connection:", e)
ws = None
else:
ws = None
fetch_thread = Thread(target=fetch_channel_names)
fetch_thread.start()
try:
for _ in range(4):
break
time.sleep(1)
except KeyboardInterrupt:
stop_event.set()
finally:
stop_event.set()
fetch_thread.join()
if ws:
ws.close()
if __name__ == '__main__':
main()
