Just received my unit in Australia and started playing with the inputs and outputs.
The AC voltage tracks with my Kill-A-Watt correctly and the CT I currently have spare - a YHDC voltage type converted to current type by removing the internal resistors - is tracking watts correctly.
My problem is that when I create an Output for amps using the Configure Output panel, the amps calculated are incorrect.
Sorry, coming from 10 years using Openenerymonitor and emoncms.
So I now gather that one does not need to use the Configure Output panel for calculations like amp = watts / volts and that this is already calculated using the values already present from the sensors.
Took your advice regarding renaming. Does make a lot more sense.
All as expected.
Thanks for your prompt assistance.
